Sponsored by: CARiD
W212 Buzzing sound need fix?
Old Oct 23, 2019 | 07:52 AM
212swe's Avatar
W124 W212
He guys have a buzzing sound in the car in front instrument any know the solution to this problem?
Thanks in advance!
Old Oct 23, 2019 | 08:00 AM
DFWdude's Avatar
2016 E350 Sport
I'm no expert, but this sounds like speaker "clipping" to me.
Old Oct 23, 2019 | 08:37 AM
212swe's Avatar
W124 W212
Hmm was thinking about that but when motor it’s off it’s no sound at all. Its there even a speaker there in the front? Door speaker are fine.
Old Oct 23, 2019 | 12:12 PM
212swe's Avatar
W124 W212
Any here that can send PDF how to remove front galler? Pretty sure the buzz coming from there. I don't hope to take apart complete dashboard...
Old Oct 23, 2019 | 01:41 PM
Arrie's Avatar
https://www.youtube.com/watch?v=SbwUiMBFNFM
Thanks in advance!
Sure it is not coming from the cabin blower?
Old Oct 23, 2019 | 02:55 PM
212swe's Avatar
W124 W212
Try with blower turned off still sound. What can be behind that cover plate!?
Old Oct 23, 2019 | 02:57 PM
DFWdude's Avatar
2016 E350 Sport
I was thinking the upper tweeter in the forward wing of the door, not the big speaker down below. You might open the door (to separate door from dash) and listen closely over the dash, and then at the speaker.
I think it's speaker related, because your video shows the ticking only starts once the Comand system powers up. You can test this by turning the car off, then back on, watching the Comand screen as it powers up. If the ticking begins after Comand completes booting, then you can suspect it's the Comand system and related speakers. With it ticking, then power off Comand entirely (center knob in dash). If the ticking stops, then you have the culprit...
Old Oct 23, 2019 | 04:05 PM
212swe's Avatar
W124 W212
Yess agree with you its sound like some kind of speaker problem! Try this now.
- Command and music with car not running = No buzzing
- Command off and car running = buzzing
- Command on and car running = buzzing
Its like as soon the car starts running buzzing sound coming not all the time sometimes it take a few seconds before it starts. Try multiple different things on/off command.. hmm
Tweeter in door no buzzing sound. Pretty sure it comes from where I put the red arrow and there in should not be any speaker don't even here music from there!
It may be a speaker in the center white arrow but not sure if this care have speaker there can not here any music.
One thing I noticed when I start car with command off it does 3 fast almost silent dunks, same if I only start command with no key in the car.
Was reading these people having problem with melted speakers but here we have like max 70F at summer most of the time 60F..
Can say its like 90% change buzz coming from where the red arrow are.
Thanks for your help mate!
Old Oct 24, 2019 | 03:24 AM
212swe's Avatar
W124 W212
Ok guys removed a-pillar in the garage to have a better look. Started car and no sound as soon i drove car out it starts to buzz. Can it be like GPS module that are broken and pick up the noise?
Old Oct 24, 2019 | 05:06 AM
212swe's Avatar
W124 W212
Started car in garage and drove for like 20min no buzzing! As soon I did a restart utside it began to buzz.. Be tankfull if i can get pdf how to remove front galler not sure how clips are. And not hade access right now to mb WIS!
Old Oct 24, 2019 | 07:45 AM
212swe's Avatar
W124 W212
Figured out to remove front plastic was a hard one many clips few broken :/ But nothing to see there..
Old Oct 25, 2019 | 12:59 PM
ClasseMiaMadra's Avatar
2016 S212
Maybe far fetched by today's standards but I do remember some time ago that some AT&T blackberry devices caused radio interference that sounded like a rhythmic buzzing. Could it be a phone or other electronic that causes this as radio interference?
Old Oct 25, 2019 | 01:22 PM
212swe's Avatar
W124 W212
Thanks for answer was thinking about that but should not interfere. It definitely have something to do with engine on as soon my start stop goes on in red light buzz goes away and same indoors I work perfectly so some kind of interfere but try google it and can not fiend any one with same problem
Old Sep 27, 2022 | 03:18 PM
jaisonline's Avatar
Was MB 2009 E350 AWD. Now 2016 MB E350 AWD
Hi. I might be having the same issue now. Do you still have the video ? The YouTube link no longer works
Thanks in advance!
Old Nov 28, 2022 | 08:30 AM
Ianyeo65's Avatar
W207
look for Flexx garage. This problem is related to cabin temperature sensor fan unit.
