Sponsored by: CARiD
Drop to Neutral from Drive
Old Jul 26, 2020 | 09:16 AM
icta's Avatar
W212
Originally Posted by ChrisB
The car was at MB Service shop for a day ... they could not replicate the condition. They could not figure out the problem.
Xentry Diagnostics testing done.
Stored fault codes P1709, P0705, P0606.
Examined ISM connector - wiring OK.
Checked for water or moisture under front carpets - none found.
Unable to find conclusive fault.
So I will be driving till the incidences become way more frequent - or something breaks completely.
Have to not rely on acceleration to remain safe when driving ... it might not be there.
Hi Chris
as mentioned, I have similar problems. Just changed the transmission conductor plate. 1 week on, still counting. So far so good.
Old Jul 28, 2020 | 12:06 AM
ChrisB's Avatar
1999 SL 500 & 2011 E 550 4Matic
Originally Posted by icta
Hi Chris
I hope that works ... I have been driving for quite a few weeks - without an incident. No reason for this - because it has failed several times since the last attempt to fix.
Old Aug 28, 2020 | 09:20 PM
ChrisB's Avatar
... without touching shifter or paddles ... on the exit ramp - all of a sudden the motor began free revving ... as if it had been shifted to neutral - which I had not done.
I coasted to a stop and played with the paddles (they have at times shifted on their own to a low gear) & with the shifter stock. Nothing.
I then I shut the car off & restarted ... everything back to normal. Except now the “Check Engine” light is on & will not go away.
Well even after the two attempts to fix this condition - it still occurs. 3 times in 1.5 weeks recently.
Has been happening when idling ... when creeping into a parking stall ... when entering my driveway.
So I am arranging to drop the car off at a MB shop for a week. Giving them a full accounting of the work done & the 13 instances of this happening.
Also describing to them how - occasionally at Low speeds the car will, on its own, shift out of drive into 1st gear. And will respond to paddle shifters to shift back up to Drive.
I hope MB will be able to diagnose & fix.
Old Aug 29, 2020 | 09:25 AM
icta's Avatar
W212
Been a month for me. Seems to be ok.
Old Aug 29, 2020 | 09:46 PM
ChrisB's Avatar
When you wrote “I have similar problems. Just changed the transmission conductor plate” ... is that an expensive MB Shop fix? You made it sound as if you did it yourself.
Old Aug 29, 2020 | 11:36 PM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Has anyone consider the auxiliary battery. It controls the shifter.
Old Aug 30, 2020 | 12:26 AM
  #32
ChrisB's Avatar
I just had to pay for a new Main Battery.
it could be something that simple!?
Old Aug 30, 2020 | 01:29 PM
  #33
S. Madman's Avatar
My main battery died a while back and when I swapped it the car would not shift out of N. Had to sit for 10 minutes waiting for the aux battery to charge. Shut the car off turned it back on and it started shifting again. That was 1.5 years ago.
Old Sep 3, 2020 | 09:02 PM
  #34
ChrisB's Avatar
MB Shop came up with these repair suggestions.
An Old Republic inspector visited the shop and gave
authorisation for replacement of (3) items on one claim;
- transmission valve body
- engine mounts
- oil separator
I need to pay for extra labour - 2.0 for valve body and 2.5 hours for motor mounts. I have to pay $ 200.00 deductible and $49.99 for shop supplies + taxes. Total cost to me say $ 800 Cdn.
Total payable by Old Republic $ 5,270 Cdn.
Total cost = $ 6,100 Cdn.
Again - very Glad I bought the bumper to bumper extended warranty.
I presume the motor mounts and oil separator were contributing to the problem. Can any one explain that to me?
Old Sep 5, 2020 | 08:04 AM
  #35
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I don't see the mechanism by which the engine mounts or oil separators cause the car to shift gears from N to D.
Old Sep 16, 2020 | 08:15 PM
  #36
ChrisB's Avatar
MB advised yesterday (after a 5 day shop closure - due to COVID testing) that a solenoid on the steering rack, upon removal, has separated.
And so they have to replace the complete steering rack. A back order item that will take 2 weeks to be delivered.
They accept it as a shop risk and there will be no charge to me for this.
Old Aug 29, 2023 | 03:18 PM
  #37
letchik87's Avatar
2010 e550
did the solenoid fix the issue?
Old Aug 2, 2024 | 08:26 PM
  #38
Benny2024!'s Avatar
glk250
I was driving to work this AM In Drive, sport mode - the usual.
While exiting the freeway ... without touching shifter or paddles ... on the exit ramp - all of a sudden the motor began free revving ... as if it had been shifted to neutral - which I had not done.
I checked the gas cap - is on tight.
Is this an indication that I have transmission troubles looming? Electronic controls issues?
What do you think?
Fortunately I do have an after market Bumper to Bumper warrantee that will cover what ever it might be.
I would not want to be stranded if it happens worse next time ...
HI Chris,
I have the 2015 GLK250 and this exact thing is happening.
Driving down the highway - hit the pedal and the car drops into neutral. We coast to the side of the road and restart the vehicle and all is well.
Have you actually had a fix on this issue?
I see that your mechanics have tried a few things that I’ve noted.
The mercedes dealership service department is baffled as there are no codes showing up.
Please let me know if possible.
Thank you
Crystal
Calgary AB
Old Aug 3, 2024 | 10:17 AM
  #39
JettaRed's Avatar
Veteran: Army
PLEASE, PLEASE, PLEASE! Get your own Mercedes-specific scanner and scan for codes. It's a small investment and will pay for itself with a trip to the dealer. With something like the LAUNCH Creader Elite 2.0 BENZ, about $160 on Amazon, you can keep it in your car. Scan without first turning off the ignition. It will automatically scan all control modules.
Does the gear indicator actually show N or does it show D and just doesn't engage?
Old Aug 3, 2024 | 01:22 PM
  #40
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
killer LIMP MODE...
Originally Posted by Benny2024!
HI Chris,
Thank you
Crystal
Calgary AB
This sounds like a classic LIMP-MODE where CAN-C bus crashes and ECU/TCU quit while driving on highway.
This can quickly be a true killer.... stay off the roads safely while you can!
Don't underestimate what a good local MB specialist of your choice can do for your safety!!!!
​​​​​​We can provide free tips that may help or not: given this car is known unsafe: don't drive it on public roads.
The cause of this I believe comes down to either a discharge low ALT Voltage below 12.0V or marginal ESP Module crashing CGW bridge.
Don't expect useful fault codes on these premium issues.
TIP #1: drive with HEADLIGHTS:ON to trigger a normal voltage above 13.7V - This easily cancels the silent "drain by driving" without any faults.
> You'll need to scan your chassis as indicated above by JR @JettaRed to understand the condition your chassis is in.
TIP#2: set your display to show BATT data, Volts + Amps.
Whatch for ECU draining battery power with low voltage!!
TIP#3: Don't bother with this tough issue unless "you can work on cars"... this is Mercedes premium chaos ie. Not simple! This is not "a bad fuse".
+++ KNOWN UNKNOWNS....
We know the issue is CAN-C ECU/TCU crash.
The unknown is what exactly brings that condition about: low voltage or crashed ESP/ISM networking ???
+++++ Don't overlook the obvious:
Double triple-check obvious suspects: TCU + ISM in case live fault report could help progress...
Old Aug 6, 2024 | 02:04 PM
  #41
Benny2024!'s Avatar
glk250
HI Chris,
Thank you
Crystal
Calgary AB
Buying my own scanner is an interesting idea….I’ll talk to the MB shop foreman and maybe they’ll let me borrow theirs for a week and I can try to replicate the issue.
It seems most likely to drop into Neutral when relaxing the gas pedal for a few seconds and then quick acceleration - even moreso when driving up a ramp or hill.
To answer your question on what the display shows it being in neutral or drive, it actually has no gear highlighted…..the error messages just flash in the display screen (blind spot inoperative, run flat inoperative, pass airbag inoperative, service required)
Original thought was around the battery charging….we put a new battery in a year ago and also purchased a slow charger as we don’t drive the car everyday and its a diesel. I can watch the charge as suggested.
Any other tips would be appreciated. Thank you!
Old Aug 6, 2024 | 09:36 PM
  #42
JettaRed's Avatar
Veteran: Army
Good luck with that. A genuine SDS (XENTRY) is probably $5000 USD or more.
Old Aug 8, 2024 | 02:10 PM
  #43
Benny2024!'s Avatar
glk250
These are great tips…thank you so much!
I’ll pass along to the MB service team for their review.
Most comments I’ve read seem to think this is a simple solution once they nail the cause….so frustrating!
thx again - Crystal
Old Aug 8, 2024 | 05:16 PM
  #44
Benny2024!'s Avatar
glk250
Hi
Did changing out the transmission conductor plate fix the problem with your Benz dropping into neutral while driving?
Old Aug 9, 2024 | 01:37 PM
  #45
S-Prihadi's Avatar
Nope, US$35K is what I read, with licence yada yada
Euro 29K with 5 years activation
https://autodigitools.com/product/or...-tool/#reviews
