Sponsored by: CARiD
Problem with left headlight. SAM issue?
Old Aug 14, 2020 | 04:32 PM
AW81's Avatar
Mercedes E220, 2012
I thought i had a broken bulb, but it did'nt help to replace it. So i got to my local work shop and got diagnosis. Error code B1005 lightcontrol signal error (my own translation from norwegian). They said it could be broken sam module, but i have to take my car to a Mercedes dealership for further troubleshooting. My car has bixenon and ILS. E220 2012. It sounds very expensive. Have anyone had the same issue?
Old Aug 14, 2020 | 05:15 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Sounds like a ballast issue - where is the ballast on one of these lights? Surely it is not internal?
Old Aug 14, 2020 | 05:31 PM
AW81's Avatar
Mercedes E220, 2012
Is'nt ballast in the bulb? D1s xenon bulb
https://www.eurodel.no/xenonpaere-os...QaAnrcEALw_wcB
Old Aug 14, 2020 | 09:56 PM
cetialpha5's Avatar
There's a separate ballast for the bulb. You would probably have to post the vin to get the exact part but probably something like this:
https://www.rockauto.com/en/moreinfo...503787&jsn=515
Old Aug 15, 2020 | 03:32 AM
AW81's Avatar
Mercedes E220, 2012
Ok, i hope it might be this simple. But why did they say that the SAM unit was probably broken?
They even called Mercedes and asked. But my car has no other symptoms and i find it strange... But if it is the ballast, could that give can bus (communication) error?
The strangest thing about this is that i had my car at the garage for a different problem a few weeks ago. When i got my car back the left headlight did'nt work, the back lid was off and the lamp was full of condense. The next day it suddenly started to work again, but after a day or two it was out again. I changed the bulb 8 months ago after it started blinking and after a few weeks it died.
Old Aug 15, 2020 | 07:15 AM
LILBENZ230's Avatar
Yeah the thing attached to the bulb is the igniter. Obviously you've ruled that out already.
I am not sure why they told you the SAM is broken. It does sound like you might have more issues, but no reason not to start with the simplest first.
Old Aug 15, 2020 | 11:42 AM
cetialpha5's Avatar
They scanned it and that's the error codes they were getting, it's still possible that it's the sam but less likely. As mentioned earlier, the basic troubleshooting is swap bulbs from one side to the other. Usually it's either the bulb or ballast. Bad sam is less likely.
Old Aug 15, 2020 | 12:25 PM
AW81's Avatar
Mercedes E220, 2012
It is not the bulb. I tried with a brand new one.
But i might be the ballast. Is it possible to access without taking out the lamp?
Old Aug 15, 2020 | 03:40 PM
konigstiger's Avatar
'71 Pinto
VIN, I will confirm lamp unit and attachments. Following shop’s lead you can pull SAM to check connectors/connections below as highlighted.
File Type: pdf
Old Aug 16, 2020 | 05:40 AM
AW81's Avatar
Mercedes E220, 2012
Is the highlighted connections (yellow) for the lamp and ILS? Is it easy to lift out without ****ing anything up? And regarding ballast. I read somewhere that this is in the D1s bulb. If there is a separate as mentioned above, is it accessable without removibg the bumper?
Old Aug 16, 2020 | 08:05 AM
LILBENZ230's Avatar
The D1S bulb has the igniter built in, not the ballast.
Old Aug 16, 2020 | 10:23 AM
AW81's Avatar
Mercedes E220, 2012
Ok thanks👌 Crossing my fingers for broken ballast. Do i have to take out the lamp?
Old Aug 16, 2020 | 01:24 PM
belarus27's Avatar
2010 e550 p2
Most likely the ballast , if the back lid was off and you saw condensation , 99% its that.
Old Aug 17, 2020 | 05:32 AM
AW81's Avatar
Mercedes E220, 2012
I got a replay from my local garage after they spoke to a Mercedes dealership. The ballast or control unit under the lamp do not control the light....
