Sponsored by: CARiD
2010 E550 w212 Air intake duct hose
Old Aug 31, 2020 | 11:00 PM
Noe Anzaldua's Avatar
E550
Hello, I have two big holes on both intake duct hoses from I’m guessing heat and being a old vehicle. I just want to find replacements, but everywhere I look for a “2010 Mercedes E550 air intake duct hose” results for a E350 pop up. Was wondering if they are the same even though it says they don’t or if anyone else ran into this problem and found a solution. I even called the dealership and they can’t do nothing but give me a part number and that is useless when everything keeps bringing up for the 350’s.
Old Sep 1, 2020 | 09:06 AM
konigstiger's Avatar
'71 Pinto
Dealer is correct no longer available from MB, search part 2730902582 & 2730902682.
Old Sep 1, 2020 | 10:15 AM
E550
everywhere I look it says it’s discontinued.
Old Sep 1, 2020 | 12:45 PM
Bern6389's Avatar
2014 GL350 Bluetec X166
https://www.carparts.com/details/Mer...E&gclsrc=aw.ds
Old Sep 1, 2020 | 12:56 PM
E550
that’s for a E350 or does it fit the 550’s as well?
Old Sep 1, 2020 | 02:33 PM
'71 Pinto
Reusing MB connections try to find adaptable aftermarket hose replacement.
Old Sep 1, 2020 | 02:34 PM
Bern6389's Avatar
I just searched the PN from konigstiger.
Old Sep 2, 2020 | 07:01 PM
nota_amg's Avatar
2013 SL550 BiTurbo
HERE
Better hurry, only 2 sets left! lol
Old Sep 2, 2020 | 07:24 PM
E550
Originally Posted by nota_amg
HERE
says it’s for a 2012 - 2017
Old Jul 17, 2021 | 05:19 AM
Dangahigh40's Avatar
2010 Mercedes e550 4matic
Intake hoses
did you ever find those intake hoses. I'm having the same problem with my 2010 E550
Old Jul 17, 2021 | 09:35 AM
Stephen Durham's Avatar
2010 E550, 1985 300D
I bought the ones for the 350, took them apart and used the tube sections with the 550 end pieces. They work great no more disintegrating plastic bits.
I just bought some cheap ones off Amazon since I wasn’t sure it would work out. Since I’m just using he tube part, I would probably do the same next time. Hopefully though I don’t have to replace them.
Old Jul 21, 2021 | 11:20 AM
GatorGang's Avatar
2011 E550 4 Matic
I purchased this for my 2011 E550 4 matic, then I just replaced the filters with K&N, they fit perfectly. From autohausAZ.com
Mann Air Filter Set SET of 2 Kit: 300350INTKIT
P/N: 1120940604
1
x
$20.99 AJUSA Air Cleaner Seal Kit: 300350INTKIT
P/N: AJ-2720940080
1
x
$7.99 URO Parts Air Intake Hose Left; Shroud to Air Filter Housing Kit: 300350INTKIT
P/N: UR-2720903582
1
x
$37.99 URO Parts Air Intake Hose Right; Shroud to Air Filter Housing Kit: 300350INTKIT
P/N: UR-2720903682
Old Jul 21, 2021 | 03:07 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Just in case you still looking for those
https://www.ebay.com/itm/Genuine-OEM...75.c1#viTabs_0
I would contact the seller, and verify they are new and exactly for your car.
Old Nov 8, 2023 | 07:51 PM
krese's Avatar
E550
Originally Posted by konigstiger;[url=tel:8146820
8146820]Dealer is correct no longer available from MB, search part 2730902582 & 2730902682.
What part number is 350? mine is cracked.
Old Dec 17, 2023 | 07:26 PM
Pantheon17's Avatar
E550
For anyone who ends up finding this thread, I found a YouTube video that showed the installation of the aftermarket Spectre air intake hose. I just did mine and it was actually really easy.
Here are my before and after photos:
Old Dec 19, 2023 | 11:58 AM
nocodesmo's Avatar
2010 E550 4matic
Awesome. What a timely post. I noticed that my pass side hose was deteriorating and also found that the part is no longer available. This looks like a great and affordable solution AND it looks like my local O'Reilly has them in stock.
Thanks for posting!
Old Oct 31, 2024 | 12:40 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Hey all. So I have a CLK550 and suffer the same issue the 2010 and 2011 E550 suffer regarding the rear portion of the intake hoses deteriorating. While doing research, I noticed it's a similar design for the 10 - 11 E550's and both hoses for that model have been discontinued, but there are aftermarket replacements available unlike the CLK550. So while searching online during that time, I came across the below on Etsy.
https://www.etsy.com/listing/1613874...w212-2009-2012
The information should read for 2010 - 2011 E550 as 2009 was the W211 and 2012 changed to the M278 twin turbo engine (Both of which don't have that deteriorating accordion piece issue), but I decided to go ahead and order one for my drivers side to see if it will work for the CLK550 so hopefully it can work for my application as well.
Old Nov 1, 2024 | 12:48 AM
slickman's Avatar
E550 Cabriolet
Got mine here for my 2012, fit perfectly. https://www.ebay.com/itm/364304663143
