M278 issues
I tried searching this and the CLS forums for a thread which has all the M278 issues but i couldn't find one (or they were buried). I'm conducting research as I want to take on the monumental task of putting an M278 in my W204 4matic C300.
I've done a lot of digging and the thing that keeps coming up is the tensions on the earlier M278 models. I also came across another scary thread of an engine from GL which had to have its cylinders honed at 70k miles because of low compression due to what appears to be Silitec coating wear resulting in scratches. The engines I keep finding on the market are at the 60-70k mile range and as so i wanted as much input from people who have dealt with this engine as possible.
As a whole, what are your impressions of the M278?
How many miles do you have on yours and have you had any major issues?
I have a slight drip from front cam adjuster cover plates that I need to reseal and I'll be doing the turbo waterlines, replacing the I/C pump with a CWA100 and replacing the t-stat/housing soon, just for preventive measures. Keep up on the maintenance and it'll treat you right.
s the drip from the cam adjuster something common?
I believe your C550 is going to run really well. I'll be following you to watch your progress on this. I'm running 11.3 @ 122 in the summer heat with high DA. With some stickier tires and cooler weather, looking to break into the 10's by EOY. Still on stock turbos
Where im going with this is, if i get a better deal on a RWD engine I'd rather do that and change the bottom part of it myself.
https://mbworld.org/forums/gl-class-...78-engine.html
https://mbworld.org/forums/gl-class-...rebuild-2.html
https://mbworld.org/forums/gl-class-...re-solved.html
-Piston scuffing: I'm not aware of personally and have not looked into.
-Timing chain: Here is a quote from another thread about effected engines-
"M278 engines affected as follows:
Engine 278:
1) Up to engine number 278 9xx 30 073273 install check valves and chain tensioners
2) From engine number 278 9xx 30 073274 up to engine number 278 9xx 30 103675 (February 2013) install check
valves only (optimized tensioners installed in this production range)"
Here is a link to a post with the bulletin info:
https://mbworld.org/forums/5738609-post153.html
-Oil in harness from cam sensors: this is a sensor issue. There a 4 cam sensors, just pull the connector and check it for oil. If there is oil, clean thoroughly with brake cleaner and allow to dry(use compressed air if possible). Then clean it again. Replace the cam sensors that are leaking oil and you should be good to go. I had oil in my harness and it actually wicked down to the driver's O2 sensor connector. I replaced all my sensors early on when I bought it last year. I had an engine light for Left Front(precat) O2 sensor and car started running like poo. Found oil in the connector when I replaced the sensor. Cleaned it very well, let it set disconnected overnight, recleaned it the next day and put everything back together. I pulled the exhaust back out for some other work 2 months later and checked the connector and it was still dry. Some people have had to pull motor and replace their harness, lucky mine was not that bad.
