Sponsored by: CARiD
Will these Alloys fit?
Old Oct 18, 2020 | 01:46 PM
L80OUS's Avatar
E Class E220 W213
Thinking of changing my 18" AMG night edition wheels for the below. I believe my current wheels are:
Front Wheels: 8.5Jx18 ET48 (p/n A2124010300647X21 - AMGA21240103007X21)
Rear Wheels: 9Jx18 ET54 (p/n A2124010400647X21 - AMGA21240104007X21)
The wheel I want are these:
Wheel Specification:
Pcd - 5x112
Width - 8.5J Front / 9.5J Rear
Offset - 42 Front / 45 Rear
Centre Bore - 66.6
Will these fit my car and will they sit in or out towards the arch's more?
Old Oct 18, 2020 | 01:53 PM
nota_amg's Avatar
2013 SL550 BiTurbo
New fronts will have 6mm more clearance inside and stick out 6mm more than what you have now.
New rears will have 9mm more clearance inside and stick out 9mm more than what you have now.
Basically everything will protrude more than what you have.
Old Oct 18, 2020 | 02:06 PM
L80OUS's Avatar
E Class E220 W213
Excellent thanks for your help, so looking how you worked that out - the difference in the smaller number means by how much further the wheels will stick out, deceasing the need for larger spacers? I was going to get 15mm spacers for the rear so would only need 6mm now to achieve the same look (even though there isn't a 6mm)
Old Oct 18, 2020 | 02:08 PM
L80OUS's Avatar
E Class E220 W213
Also with the rear's being 9.5 instead of 9 inch will I require a 275 tyre instead of a 265? If so I guess this won't be a problem?
Old Oct 18, 2020 | 03:41 PM
termite's Avatar
2013 E350 wagon cuprite brown; sold:2014 ML63; R500 Saks Edition; R500; more W124s than I can count
Works like a champ:
https://tiresize.com/wheel-offset-calculator/
Old Oct 18, 2020 | 06:35 PM
nota_amg's Avatar
2013 SL550 BiTurbo
Sorry, I did those calculation with your original wheels being 9.5", not 9.0"
Fronts are right
rears will be 3mm more clearance on the inside and stick out 15mm more than what you have now, so no need for spacers.
I fit 285's on a +39 wheel with a very slight rub on really big bumps, so you shouldn't have an issue with 275's on your new wheels since they are more inbound than mine are.
Old Oct 19, 2020 | 04:29 PM
L80OUS's Avatar
E Class E220 W213
Fronts are right
Thanks, do I need to worry about the 477 TPLWS when swapping to a bigger wheel?
Old Oct 19, 2020 | 06:23 PM
nota_amg's Avatar
2013 SL550 BiTurbo
with 477, no, nothing to worry about. That system uses the wheel speed sensors to monitor rotation speeds to locate low pressure in tires that turn faster due to smaller circumference.
Code 475 is the system that uses pressure monitoring sensors in each wheel, so no worries for you!
Old Oct 20, 2020 | 01:25 PM
L80OUS's Avatar
E Class E220 W213
Thanks for your help, I've placed the order
Old Oct 25, 2020 | 02:49 PM
L80OUS's Avatar
E Class E220 W213
New wheels now on the car....
Old Oct 27, 2020 | 12:20 AM
Johnny Rad's Avatar
W212 E550 4M P2
Bravo! Looks great,,, might follow your lead
Old Oct 27, 2020 | 06:56 AM
raja777m's Avatar
2014 E350 4M Diamond Silver
damn, the new (turbine) wheels are sexy. good job
Old Jul 18, 2022 | 06:56 AM
wilkwho212's Avatar
W212 E220
What tyres did you go for on this? I have exactly the same wheels and specs for my e220 and they look exactly how i'd like them. any help would be appreciated , thanks
