Sponsored by: CARiD
W212 E350 2013 4matic shimming noise between 15-48 mph
Old Jan 2, 2021 | 05:51 PM
andynmaas's Avatar
Mercedes 2013 E350 4matic, 2013 ML350
W212 E350 2013 4matic shimming noise between 15-48 mph. Noise volume reduced after replacing 2 idle pulley, belt, and tensioner pulley. No noise when engine running but stopped.
Old Jan 2, 2021 | 07:58 PM
MBNUT1's Avatar
2010 E350 4Matic
Does the noise change if you shift gears?
Old Jan 2, 2021 | 09:50 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
What does that mean? You only hear the noise when the car is in motion? When the car is in park or in gear, idling, no noise? Do you feel vibration or only noise?
Old Jan 3, 2021 | 11:20 AM
andynmaas's Avatar
No. Noise significantly louder when accelerate before I replace last part tensioner pulley. But now after tensioner pulley rep0lace noise more significant when slowing down.
Before any fix done it very loud. First I replaced the idle pulley above tensioner pulley. This car didn't have power steering pulley. Noise not reduced. Then I replace pulley on top of alternator and belt serpentine and noise reduced. Then last piece tensioner pulley which make noise if I rotate manually but after replaced noise still there but not loud anymore. The noise only happened when car moving. I start engine and still in Park increase RPM until 3500 and no noise.
W212.088 M276 E350 2013 4matic
Old Jan 3, 2021 | 12:09 PM
RA72825's Avatar
Never heard of any noise described as shimming, so I’m at a loss. Everything you have replaced would create noises at idle, under acceleration, standing still, while moving, etc. You get my drift.
Noises while moving could be collapsed motor mounts, bad axle(s), hub, dragging brake, differential, transfer case, etc.
No power steering belt because it is an electric assist motor.
Old Jan 3, 2021 | 12:51 PM
As @KEY08 states, I wouldn't describe a sound as shimming... that's why I asked if it something you feel and/or hear as well. You could have multiple issues going on... How many miles on the car?
Sounds like you fixed one issue, worn accessory belt components (idler pulleys, tensioner and belt), which usually is heard audibly at idle as squeaks. Now you have a separate issue of noise only while in motion. So again, you only hear noise? No vibration is seat, floor by pedals, steering wheel, etc..? Is it RPM related, is it speed related, while coasting, while accelerating, while decelerating, while braking, while turning, slow speed turns in parking lot, etc...
Has the noise started after any recent maintenance?
Old Jan 3, 2021 | 01:27 PM
andynmaas's Avatar
Maybe I choose wrong word for the sound. Attached the video with the sound.
The car had history of front axel break and I think it create same sound before it break. It happened around one year after I hit pot hole around 2 inches deep which that time blow out front tire and bend both front and rear wheel on passenger side. It make noise until it broke loose and hit catalytic converter
I bring to the shop repaired the axle but he suspect belt system. with below estimate
The part very expensive and it easy to do so I replace myself.
One idle pulley I bought from Mercedes which is very expensive US $87.50. The second pulley is OEM Litens (900667A) bought from Advance Auto Part which is identical bearing as the original from Mercedes for US $ 30. Belt is Dayco 5060840 6PK2135 around $32 from Advance and Tensioner INA 276 200 03 70 which had Gates brand on the product and it label as OEM around $60 from Advance which bought the same day from wholesaler WordPac cheaper than Mercedes which want it for $250.
Old Jan 3, 2021 | 01:34 PM
andynmaas's Avatar
Actually first I suspect something on related to axel because it only sound when car moving. But European shop estimate for complete set 2 idle pulley, tensioner and belt. Mercedes dealer estimate for idle pulley only around $300 but for complete set around $950. Car had 185000 miles and it didn't happened after recent maintenance. No vibration just only happened when accelerate or decelerate. It quite after reach above 50 mph steady speed.
Old Jan 3, 2021 | 01:57 PM
RA72825's Avatar
dd Post
Old Jan 3, 2021 | 02:03 PM
RA72825's Avatar
Thanks for the video. Sound is violent and I can see the cabin shaking while you are trying to capture it on your phone. Seems like Axle(s) to me. The noise and vibration can be rpm specific with these. Come and go. That’s my guess.
185,000 miles Wow!
Old Jan 3, 2021 | 02:24 PM
dbldpr's Avatar
Veteran: Navy
Have you checked motor mounts?
Old Jan 3, 2021 | 10:15 PM
andynmaas's Avatar
Motor mount looks ok vibration not increased after car make noise
Old Jan 3, 2021 | 10:57 PM
I also hear a chirping in the background, is the HVAC on? Sounds like a dying blower fan. On the second "run" the main noise does increase in frequency with speed. Reminds me of an old train riding down tracks, clacking away.
Looking at motor mounts isn't a way to diagnose them. From the video, that's not your "noise" issue. It could be a separate issue as well, that's a lot of miles without knowing full history.
Old Jan 4, 2021 | 12:18 PM
andynmaas's Avatar
The old train you hear is cause by concrete road in Dallas for local or small road they made junction between block of concrete road not smooth so it will sound like train pass connecting rail. I think I have to check drive shaft bearing and flex disc which may be damaged too after I hit pot hole more than a year ago which cause front axle broke around July 2019 which hit and broke catalytics and oxygen sensor close to that. That time it also make noise and I think the noise is similar but louder.
Old Jan 4, 2021 | 12:34 PM
RA72825's Avatar
Suffice to say, this is a drivetrain issue and not a pulley and belt issue. Could be anything that is in motion when driving including worn tires. Driveshaft also and everything else I mentioned above. You need more drive and less train. Plus at 185K maybe it’s time to let go of this car.
Old Jan 5, 2021 | 10:27 PM
Arrie's Avatar
it is a 4Matic so would the transfer case be a good candidate for the problem like for so many other 4Matic drivers?
Old Jan 6, 2021 | 03:20 PM
RA72825's Avatar
of course it is. Already on the laundry list.
Old Jan 15, 2021 | 09:34 AM
andynmaas's Avatar
What is the symptom of transfer case problem?
Is transfer case is body of transmission gear?
Old Jan 15, 2021 | 05:04 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
the transfer case is part of the transmission, and drives the front driveshaft, while the main output of the transmission runs the rear drive shaft.
Old Jan 15, 2021 | 09:49 PM
MBNUT1's Avatar
2010 E350 4Matic
High pitched whining noise above 30 MPH that is tied to speed. It is the result of failing bearings.
Old Apr 11, 2021 | 09:09 AM
andynmaas's Avatar
Hi I found out what make noise it is again front driveshaft failed again around 172000 after replaced at 120000
I had Mercedes E350 2013 4Matic bought 2016 with 43000 miles. At 121000 on 2/7/2019 front driveshaft broke after making sound for around 3 months. It broke catalytic converter and oxygen sensor. Actually it broke when mechanic drive tested it. Can we blame to shop? I don't we can right. So it fixed for around $2500. Then now at 172000 miles 4/10/2021 it left me stranded around 140 miles and cost me $500 for towing to home. The closest shop is 46 miles but it about to close on Sat and will open Monday. Geico tow is scam they claimed it cover up to 100 miles but only to close shop and didn't care if shop will close if more than that they only cover 20 miles. So lesson learned get AAA for around 100 per year for up to 200 miles with no condition.
Look like it common problem because I seen in youtube same problem E350 2013 4matic
Also C300 2010
Also for w211
Old Aug 24, 2021 | 11:51 PM
mercyfan's Avatar
Mercedes 2013 E350 4matic, 2013 ML350 RWD
I resolved the humming noise. I found one of clip that hold the oxygen sensor is loose so it hanging and it make noise when car running because of wind blow on it. I just found it accidentally when I fix problem in transfer case which I have to open the front exhaust on passenger side. The shop that fixed front drive shaft few months ago didn't properly hook the oxygen sensor and left one of them unhook and it hanging loose. I did replace belt, idle pulley and tensioner pulley and still not resolved the noise.
