Sponsored by: CARiD
Engine coolant in transmission
Old Feb 16, 2021 | 01:56 PM
WhathaveIdone's Avatar
2013 E350
I recently experienced an overheating problem. The car was towed to the local MB garage.
It was misdiagnosed as an oil cooler seal failure. Oil cooler was replaced. Coolent pressure tested - held pressure.
Test drive experienced extremely hard shifting (never had this problem), then they dropped the pan to find coolant in the transmission oil.
The radiator / tranmission oil cooler had failed allowing coolant into the trany.
I am now told it shifts very hard after flushing it multiple times and installing a new radiator.
Anybody ever have this problem?
The car has perfect maintenance record, no coes. This just happened out the blue!
Old Feb 16, 2021 | 02:43 PM
RA72825's Avatar
See post #14 in this thread regarding the Torque Convertor clutch:
https://mbworld.org/forums/mercedes-...r-failure.html
Old Feb 16, 2021 | 03:20 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Back when you were experiencing an overheating condition, you did some troubleshooting. Did you ever notice a "sheen" in the reservoir on the coolant surface? Unfortunately the combination engine/trans cooler MB has used for decades poses this risk if/when it fails. I've seen plenty of failed radiators in my time working on MBs and typically they start leaking at the crimped ends... these are on cars that are 10/100k+ (year/miles) made between the 80s and early 2000s. I doubt the newer radiators are constructed any differently. I can't recall many, that had failed "internally" causing a mix of fluids... but, things happen.
Old Feb 16, 2021 | 03:47 PM
It started hard shifting after they replaced the oil cooler [and seal] and pressure tested the coolant system? Seem coincidental.... however them replacing the oil cooler for a sporadic overheat doesn't make sense either to me. If anything, the seal leaking [oil] is a common issue on M272/273, not sure if the M276 shares the same design.
The trans fluid has been flushed a few times, besides checking codes, maybe they should try to readapt the transmission, like this:
Old Feb 16, 2021 | 03:58 PM
2013 E350
Thanks for the great comments. Yes, it was readapted, still hard shifts, and slipping, unlike before the repair.
I am wondering if I should just swap out the tranny how to avoid the next failure.
Old Feb 16, 2021 | 06:33 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
I know this doesn't help, but for posterity's sake will post that the ~2003 MY series of c-class cars had a well documented issue with one version of the radiator mixing the tranny fluid and coolant. In all the cases I read, the tranny was fine after being flushed.
Old Feb 16, 2021 | 06:42 PM
E55Greasemonkey's Avatar
This place is a joke.
Find another shop that knows what they're doing. This is an uncommon occurrence but it happens on the 212 chassis. Your transmission is ruined from the glycol. No amount of flushing will save it. Several other components of the cooling system also are ruined by the transmission oil. This requires an extensive repair costing approx. $10k-$12k at the dealership.
Old Feb 18, 2021 | 11:46 PM
nota_amg's Avatar
2013 SL550 BiTurbo
It's the water that kills the transmission. The friction material on the clutches is attached with a water soluble glue, too much mixing of water in the transmission fluid and the clutch material just comes off...sorry, but you need a new trans.
If you're concerned about a possible future failure, you can run an aftermarket transmission cooler and just remove the lines from the radiator and run extensions to the new cooler.
When I was a tech in the 2000's, we did have issues with certain radiators. I changed many under warranty and a few that were found during servicing. Never had a transmission fail, but I know we did have other techs that did have total failures in some of the transmissions on cars that came in with bad leaks. Afaik, the issue was fixed then as I didn't see any more failures after we addressed all the bulletins/vehicles and replaced all the bad radiators.
Good luck!
Old Feb 21, 2021 | 04:30 PM
MBNUT1's Avatar
2010 E350 4Matic
Saw lots of postings on the W211 forums for radiator failure contamination of the transmission fluid but I haven't really seen postings for W212's
Old Feb 22, 2021 | 12:36 AM
Senecan's Avatar
1983 Nissan SHlTBOX
I ran an aftermarket Mishimoto tranny cooler with a fan on my 2003 Nissan Maxima during a 2016 engine swap project I completed a year and a half ago. Nissan used an integrated tranny cooler also. I replaced the stock radiator with a ginormous, dual row aluminum Mishimoto radiator that didn't have an integrated tranny cooler. I live in Tampa, so I didn't want any cooling issues.
Piping and mounting the cooler was about as simple as it gets. I haven't even wired up the fan and the tranny stays at or below coolant temp. Do you think the W212 would be safer in the long-run with an external cooler? Do you believe the risk factor is high enough to warrant an external cooler as a safety measure? I want to keep mine forever, and I'd rather not have to replace a $7k tranny that should last the life of the vehicle. Thanks!
Old Feb 22, 2021 | 12:04 PM
nota_amg's Avatar
2013 SL550 BiTurbo
I feel it's absolutely safer with an external trans cooler. There is NO WAY it can fail and mix the fluid if they are seperated. It doesn't seem to be a huge problem, but it certainly won't hurt anything either.
Old Feb 22, 2021 | 02:46 PM
Senecan's Avatar
1983 Nissan SHlTBOX
I agree. I really like the Mishimoto cooler that I have on my Maxima. There's also plenty of space between the condenser and the front bumper cover/grille. I'll poke around and look into it. First thing on my list with this new car is timing chain tensioners and cam solenoid O-rings. I have the dreaded oil leak on both banks at 85k on mine and it has never been done. I may order a passive heat exchanger rather than a fan-cooled unit for the Benz.
Old Feb 23, 2021 | 02:33 PM
2013 E350
Thanks Senecan and nota amg, the local shop did the work and installed the OEM radiator with integral trany cooler. I'll see if there is room to install the Mishimoto cooler. I believe there is. They also installed new cam solenoids and o-rings as mine were leaking. 84k mile on it now.
Old Feb 23, 2021 | 05:32 PM
Senecan's Avatar
1983 Nissan SHlTBOX
That's fantastic! I have the exact mileage on mine. I just started a thread regarding solenoid seal replacement last night. I'll be doing the work myself and documenting it to finish the DIY thread.
https://mbworld.org/forums/e-class-w...ls-repair.html
