Sponsored by: CARiD
disabling the "door open park" feature?
Old Mar 15, 2021 | 02:32 PM
bernard farquar's Avatar
2011 E350, 1998 ML320
I have searched around and not seen any answer to my issue. Has anyone managed to disable the "feature" where the car slams itself into park if you open the door while rolling? I open my door while reversing into my spot at work, while lining up for the car wash, and while checking side clearance in my driveway. I get that the shifter stalk thingy is non intuitive, but I feel like damaging my transmission over and over is a high price to protect against the outside chance that I get out of my car and wander off with it in gear.
I assume the dealer would consider it safety and not want to code it out, but was wondering if anyone who had STAR developer mode access could do so?
Anyone else as annoyed by this as I am?
Old Mar 15, 2021 | 03:47 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
I thought it wouldn't go into park unless the vehicle is at a full stop?!?
Old Mar 15, 2021 | 04:39 PM
RA72825's Avatar
it will automatically shift to park if you open the door with a bright red dash warning just as he said. This issue has come up several times and no one has ever posted a way to defeat it. Sorry
Old Mar 15, 2021 | 04:45 PM
hyperion667's Avatar
2012 CLS63
Open the door, let it go into park, then while door is open, shift into R again.
I'll never forget the time a tech did that in the service bay with another customers car.......that sheit was so cringe worthy He also was in R trying to see where he was going.
Old Mar 15, 2021 | 04:53 PM
RA72825's Avatar
Nice!! Mystery solved.
Old Mar 15, 2021 | 05:49 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
I hate that feature. One time I was coasting to a stop and opened the door to pull my safety belt that got caught in the door and before I knew what happened I almost left my front teeth on the steering wheel
Old Mar 15, 2021 | 06:15 PM
decorily's Avatar
GLC 300d 4matic
I don't have a W212 and know nothing about them!
I had a 2016 GLC that did this and also used to do the same if the passenger door was opened before coming to a complete stop. After the first service at 12 months the car no longer did it. I mentioned it to the dealer at a later date and was told that an update had been applied at the first service and that may have changed the feature.
Probably worth enquiring about such an update from your dealer.
Old Mar 15, 2021 | 06:52 PM
I don't want it to go into park in the first place, I know I can manipulate the lever after the fact, but this is a bug, not a feature as far as I'm concerned.
Old Mar 15, 2021 | 11:01 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
I'd have to agree. Why would MB want the car to shift into park when it's moving?
Old Mar 16, 2021 | 12:26 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Someone probably got run over after forgetting to put the car I park...
Old Mar 16, 2021 | 08:20 AM
2012 CLS63
I've seen footage of this happening on youtube
Old Mar 17, 2021 | 09:39 AM
VegasE's Avatar
2012 E350 sedan
Yeah, this happens a lot more often than you think.
At least I now know a solution thanks to this thread.
Old Mar 17, 2021 | 10:08 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Open the door while in drive, THEN shift into reverse.
You get roll away warning but you can drive.
I learned this last week, only had the car 2 weeks tho.
Old Mar 20, 2021 | 12:04 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Here is why
Old Mar 20, 2021 | 07:39 AM
2012 CLS63
Originally Posted by S. Madman
I've seen that one too, and the guy honking his horn seemed like a real fawkwad.......the older man didn't have to get out of his car though just to shake his fist, he could have gotten really hurt.
Old Mar 20, 2021 | 09:51 AM
YasS's Avatar
W212 E400
Weird that this 164 didn't engage park. I remember ours doing that and I had an E70 X5 that did that as well.
Old Mar 20, 2021 | 09:28 PM
Adi-Benz's Avatar
yikes. the guy who honked was in the wrong on this one imo, but everyone likes to rag on "mercedes" drivers because they are "entitled"
Old Jan 31, 2022 | 12:40 AM
MOHAMMED ASALI's Avatar
2010 R350
D Driver door
Hi did you try to disengage the door sensor
Old May 4, 2024 | 09:15 AM
PMB2504's Avatar
C300
I couldn't agree more!. Just bought a 2016 C300. On other cars I've opened my doors while moving to let mosquitos or bees out, or even to listen for sounds like a bolt or a rock stuck in my tires. What happens if you were to do this at 20 or more MPH?? I would like to disable this 'safety' feature.
Old May 31, 2024 | 02:16 PM
DeanMassy's Avatar
lexus
Old May 31, 2024 | 02:28 PM
I sold my W212 a while ago but if IIRC, you can't shift into park while the car is moving.
However, if you open the door, it immediately slams the car into park.
Old May 31, 2024 | 08:20 PM
JettaRed's Avatar
Veteran: Army
It will quickly come to a full stop.
Old Jun 1, 2024 | 10:39 AM
W205C43PFL's Avatar
Yup, very abruptly too and you heard a very loud noise sounds scary like something broke in the transmission. Had this experience in my friend's E 400 in the passenger seat.
Old Jun 1, 2024 | 11:23 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
If you watch the shift indicator on the IC you will see what gears the transmission will "allow" given current conditions. For example, reverse is unavailable (as is park) when you're rolling forward at 60mph. When you're going slowly, park becomes available at a defined speed - maybe 5mph? I haven't paid enough attention to know the exact speed. At any rate, I wonder if that defined speed at which Park is available can be redefined to "zero", thus eliminating the possibility of the car putting itself into park when it is rolling.
Old Jun 1, 2024 | 02:14 PM
W205C43PFL's Avatar
Yes that is around the speed as I know specifically (again my friend's car) he compliant that he pressed the Park button my accident at speeds below 10 KM/hr and the parking pawl starts ticking to a stop.
I also made this same mistake on a previous MB again with the column shifter. I forgot how I made such a mistake but it must be a bad reason as why was I touching the column shifter stalk when driving.
