Sponsored by: CARiD
Rear View Mirror not dimming
Old Mar 20, 2021 | 04:52 PM
mrtnhu's Avatar
W212 E350 CDI
Hey guys! After driving home tonight I noticed that my rear view mirror is not dimming, only the driver’s side. The reading lights and the ambient lights are both working, what can be the problem?
Old Mar 20, 2021 | 05:01 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Are the center mirror and passenger side mirror dimming properly? Are all mirrors clear and bright in the daytime? Any codes?
Old Mar 20, 2021 | 05:07 PM
mrtnhu's Avatar
W212 E350 CDI
only the center mirror is not dimming, driver’s side worked perfectly and if i’m correct passenger’s side are not dimming normally?
Old Mar 20, 2021 | 05:17 PM
2013 ML350 Bluetec
Is the light sensor on the center rear view mirror clean? Is there anything in the back window that would stop the sensor from being able to see light from cars behind you?
Codes... a good scanner will likely give you codes.
Old Mar 20, 2021 | 05:30 PM
mrtnhu's Avatar
W212 E350 CDI
I don’t have a code reader unfortunately :/
and no the mirror and back window are both clean, and like I said the driver’s side mirror was working perfectly, it dimmed when there were cars behind me, but the center mirror didn’t
Old Mar 20, 2021 | 06:37 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The passenger side door mirror is not autodimming in my W212.
The driver mirror dimming normally means no sensor issue since, IIRC, they both use the same sensor.
Interesting. Never heard of this happening before. No sign of leaking fluid, right?
Old Mar 20, 2021 | 11:02 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
crap. was going to look up some parts in XEntry Parts Information and I'm getting...
Information
Your user preferences are not configured completely.
Please contact the relevant Mercedes-Benz market representative.
Thank you for your understanding.
Old Mar 21, 2021 | 11:44 AM
Arrie's Avatar
You can disable the dimming feature from one of the buttons on the mirror but I would think it would disable both the inside and outside mirrors but I’m not sure.
The dimming function just broke on that inside mirror? It is an electrical “gizmo”.
Old Mar 21, 2021 | 01:20 PM
DFWdude's Avatar
2016 E350 Sport
Arrie, I've read through both the standard and digital manuals, and I can't find the notes about disabling the antiglare feature using one of those buttons. All three buttons appear dedicated to use of the Homelink garage door integration.
I'm not saying antiglare can't be disabled, because page 122 (digital manual) shows the center mirror with a lever to manually redirect the mirror. But for cars with the automatic antiglare mirrors, the lever disappears and the manuals don't show how to disable antiglare at all. If this is a true "secret sauce" easter egg, can you enlighten us please on how to do it?
Old Mar 21, 2021 | 01:30 PM
DFWdude's Avatar
2016 E350 Sport
This is what the digital manual says about the antiglare mirrors (Page 124). The basic owner's manual has no information and refers the reader to the digital manual...
Automatic anti-glare mirrors
"The rear-view mirror and the exterior mirror
on the driver's side automatically go into antiglare
mode if the following conditions are met
simultaneously:
1- the ignition is switched on and
2-incident light from headlamps strikes the
sensor in the rear-view mirror.
The mirrors do not go into anti-glare mode if
reverse gear is engaged or if the interior
lighting is switched on."
Old Mar 21, 2021 | 04:58 PM
LILBENZ230's Avatar
Yeah I have not had any way to disable it in any of my Mercedes cars that I'm aware of. All of my other cars from different brands had power buttons for it.
Old Mar 21, 2021 | 07:49 PM
decorily's Avatar
GLC 300d 4matic
Yes ....I don't think the passenger side mirror should dim .
Old Mar 22, 2021 | 11:57 AM
konigstiger's Avatar
'71 Pinto
Could be internal sensor requiring mirror replacement but you can check connector/pins @ overhead control panel for precaution.
File Type: pdf
File Type: pdf
Old Mar 22, 2021 | 12:25 PM
DFWdude's Avatar
2016 E350 Sport
In post #10, there is no mention of passenger side mirror in the manual.. so it definitely doesn't dim.
Old Mar 23, 2021 | 01:27 PM
Arrie's Avatar
You are right, I'm wrong. I could have sworn I can turn the dimming off from a button but this is not the case. I remember now turning it off with my thumb on the sensor. What threw me off was that I drove a rental car a few weeks ago that did have a button for it and I mixed it with the compass button on my mirror.
But you can turn it OFF by turning the cabin lights ON... but who would like to drive like that in the dark...
Old Mar 23, 2021 | 01:49 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Passenger mirror doesn’t dim on either of our ‘11s... it’s easy to spot the dimming area if you look closely at the mirror. There’s a clear edge around the perimeter and a slightly tinted or different shade within, even with dimming not activated.
Old Jul 28, 2021 | 08:28 PM
vitop's Avatar
2006 E320CDI, 2012 E350 Bluetec, 2013 E350 Bluetec
I am adding folding mirrors and have been checking my mirror functionality to be sure I get the right mirror frame. The only way I was able to get mine to work in order to test it was to start the car in the dark and then shine a flashlight at the inside mirror after moving the car to drive. It definitely got darker. Then you can toggle between reverse and drive to see the difference.
