Auxillary Battery Malfunction (Trunk) - Easy/Cheap Replacement DIY
Old 04-01-2021, 08:30 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Here's my video DIY of the replacement, of course its very straight forward:
Link of battery used in description. $40 replacement vs $130 OEM battery, and of course not including dealer premium.
Hope this helps.
The following 5 users liked this post by Adi-Benz:
1SickGLC (04-03-2021), Benzallo (09-06-2021), CaliBenzDriver (04-01-2021), DFWdude (04-01-2021), Fliplegend (04-02-2021)
Old 04-01-2021, 08:50 PM
DFWdude's Avatar
Received 1,753 Likes on 1,123 Posts
2016 E350 Sport
Nicely produced. Thanks, Adi...
Adi-Benz (04-01-2021)
Old 04-01-2021, 08:53 PM
Adi-Benz's Avatar
I appreciate it!
Old 04-01-2021, 09:45 PM
Left Coast Geek's Avatar
Received 1,296 Likes on 886 Posts
2016 E350 4Matic wagon, 2019 Ford Expedition 4x4
did the overflow drain work?
pierrejoliat (04-02-2021)
Old 04-01-2021, 10:07 PM
Adi-Benz's Avatar
Vent tube? Or are you referring to something else?
Old 04-01-2021, 10:08 PM
bmwpowere36m3's Avatar
Received 1,008 Likes on 675 Posts
'11 E350, '11 E550, '98 M3, '95 E320
Yes, it seems the replacement lacks a connection for the vent tube.
Old 04-01-2021, 10:18 PM
Adi-Benz's Avatar
From what I understood, is this was a sealed battery as opposed to the vented, however I will look at it tomorrow when I get a chance.
Old 04-01-2021, 10:22 PM
kajtek1's Avatar
Received 1,742 Likes on 1,389 Posts
1922 Ford Model T / no OBD
This is "non-spillable" battery. Doesn't need drain tube.
Old 04-01-2021, 10:26 PM
Adi-Benz's Avatar
Regardless, I will add a disclaimer.
I know the reasons behind venting and whatnot, so I will leave it up to individuals choice. Between this and pricier alternative replacements without vents, there were no reported issues.
If you do not know, venting is important for batteries in passenger compartments; because this is in the trunk, *technically* it counts. While the battery style is slightly different (eg agm etc) if you are more comfortable with OEM battery, you can still purchase direct replacement on Amazon.
Old 04-01-2021, 10:44 PM
kajtek1's Avatar
The main purpose for designing AMG batteries was to make them non-spillable, so they can work upside down and on its side.
I have AMG batteries with no hole in them and looks like the one here doesn't have it neither?
Why some AMG batteries have vent hoses? Beats me. I would not loose sleep over it, especially with battery in the trunk.
Adi-Benz (04-02-2021)
Old 04-01-2021, 11:15 PM
AGM batteres are also known as Valve Regulated Lead Acid. NORMALLY they don't outgas but if they overheat due to bad conditions, they can outgas and those gasses are highly corrosive.
The following 2 users liked this post by Left Coast Geek:
Adi-Benz (04-02-2021), pierrejoliat (04-02-2021)
Old 04-02-2021, 12:54 AM
Alandf's Avatar
2016 E350 Sedan
We have cars that cost over 60K new. I bought mine used for 35K. Why would I try to save $100 or so on an aftermarket UNVENTED battery.
It cost me over $70 just to buy gas yesterday in CA
I don't get it
The following 2 users liked this post by Alandf:
Left Coast Geek (04-02-2021), pierrejoliat (04-02-2021)
Old 04-02-2021, 08:06 AM
Adi-Benz's Avatar
I don't get it
For the same reason some of us do our own oil changes...I personally don't care if I use Mobil-1 instead of Mercedes-Benz oil, as long as it is the same spec and performs similarly.
It's evident that there are thousands of people using similar batteries, if there was a problem, we would definitely have seen it. People are more likely to post when something goes WRONG than write a good review.
Old 04-02-2021, 09:18 AM
I enjoy DIY'ing and "saving" money in labor, but not necessarily the parts. OEM alternatives vs. OE, definitely. Joking about saving money, because for me the amount of money invested in a garage, tools, etc... realistically I could pay someone to do the work and be ahead for a LONG time hahaa
I'd be inclined to find a Yuasa battery of similar spec. My experience with these off-brand batteries on Amazon is really hit or miss (not with Start/Stop).... I bought a few AGM VRLAs for my dual sport bike and they last all but 6 months before not wanting to take a charge ($40 vs $100 for Yuasa).
Old 04-02-2021, 09:47 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Not to mention explosive. Maybe going Hindenberg is a German thing (wait... our cars are German) but hydrogen gas burns nicely given a chance. Not to rag on the OP but I've always considered it worth getting the best I can afford. I can afford this car, I can afford the proper parts to keep it in good trim.
Edited to add: Auxiliary not auxillary
The following 2 users liked this post by rapidoxidation:
CaliBenzDriver (04-02-2021), pierrejoliat (04-02-2021)
Old 04-02-2021, 09:57 AM
kajtek1's Avatar
I don't get it
There has to be a limit to everything. I am religious about buying MB fluids. That is something I can't test or measure, while buying cheaper equivalents can have disasters results.
Typical is that owners put Zerex coolant for $5 savings. I often drive in 120-130F environment and my cars never overheat, even when they do have high mileage.
I just got $3800 estimate for my Sprinter exhaust leak repair. Did I go for it? NO WAY ! I am buying $170 flex pipe and will have muffler shop cut off the old one and weld aftermarket copy.
When it comes to this battery - again this is no spill battery that doesn't have vent. Maybe it is better design than OE battery?
Regardless the MB batteries don't have good reputation, so if that one will last 3 or more years it makes lot of sense. Not like aux battery failure will stop you in your travel.
One more note - if you have alarm system in your house, you do have 1 of those batteries somewhere in your closet. Is it vented?
Same with computer backup power.
Old 04-02-2021, 10:38 AM
Adi-Benz's Avatar
Well, that's the point of me posting on a forum I guess. To think outside the box, do something different, get some constructive criticism.
You guys and Geek had constructive criticism. If people didn't know, they learned something, as well as now you've got the idea to pursue a different option. That's why a forum is best, it's /usually/ people who know more things in depth about the car than the average owner, or "Facebook group" member. If I wanted those kinds of low level comments, I could go elsewhere. What am I supposed to say, my car is more expensive than his? Does that help anyone? Nope. Constructive criticism is different than shallow criticism.
Obviously I will be the test bunny for this battery. You can take a look at my posts and "thanks" and you'll see I'm not going anywhere. I'll gladly update this thread when anything changes. As for now, I'm confident in the replacement.
kajtek1 (04-02-2021)
Old 04-02-2021, 11:18 AM
Adi-Benz's Avatar
Another thing I noticed during my research is there is at least 3 different companies that made the oem aux batteries. Mine was made in Thailand, I don't remember the other 2 or any differences, but they might be different depending on where the vehicle was made...
KEY08 (04-02-2021)
Old 04-02-2021, 12:40 PM
CaliBenzDriver's Avatar
Received 3,448 Likes on 2,297 Posts
MY'14 W212 M276 3.5NA @60kMi
kaboom...
go look in the trunk where the 2x fat red cables meet: this is a fat RELAY with old fashioned contact points (not solid state) and given a chance a spark!
I don't think the air in area around the spare tire is at all vented the way both trunk sides are with flaps.
The Ingineeers idea to route AGM gases outside serves as warning. These AGM batteries can see deep cycle duties and some over-charge if the car charging system goes crazy. There is no battery sensor on the rear auxiliary to measure Temp, current to stop a runaway condition.
The load current out of this battery is in the 30 to 50Amp range when it supplies the whole car minus the starter 100Amp. load.load.... keeping a proper vent tube looks like a good policy.
Old 04-02-2021, 01:56 PM
Adi-Benz's Avatar
There are rubber plugs on the metal with some small holes near them, and the hose will still serve as a port for gasses, not acid
that relay is tucked away as well
I believe air is exhausted underneath the rear window from the cabin into the trunk and out the rear wheels. There will never be enough buildup of gases for anything to occur. You're really looking for a perfect formula; I'm not saying it can't happen but I don't think exaggerated circumstances will occur in most cases
Old 04-02-2021, 02:07 PM
Adi-Benz's Avatar
Also I have just noticed that the new OEM replacement batteries state they are "AGM upgrade for vehicles equipped with lead acid battery..."
Old 04-02-2021, 02:10 PM
Lead-acid chemistry
AGM are gel lead-acid batteries... when you pick a part replacement it's a good idea to match specifications.
Here the Amp/hour load rating is key
Old 04-02-2021, 02:26 PM
Adi-Benz's Avatar
Yes, but if it's "upgraded" as "sealed" then that would make 4 variations of the battery already
Old 04-02-2021, 02:56 PM
pierrejoliat's Avatar
Received 1,128 Likes on 754 Posts
12 E350 4Matic 13 E350 4Matic AMG Sport
https://www.sciencedirect.com/topics...sion:sadwavey:
Old 04-02-2021, 03:03 PM
Adi-Benz's Avatar
https://mbworld.org/forums/sl-class-...ole-where.html
Quick Reply: Auxillary Battery Malfunction (Trunk) - Easy/Cheap Replacement DIY
