Sponsored by: CARiD
W212 clicking noise & squeezing while braking
Old Apr 26, 2021 | 09:05 AM
Mohd Saadi's Avatar
W212 2011
Hey,
1 - single clicking noise came out when pressing brakes from the rear
2- squeezing when pressing brakes while the car is on park also from the rear
( I've changed brake calipers on both sides and nothing happened 🙂 &#128148 + changing brake fluid because.....
Any suggestions
Regards k
This is the youtube video
Old Apr 26, 2021 | 10:26 AM
konigstiger's Avatar
'71 Pinto
Proper torquing?
File Type: pdf
Old Apr 26, 2021 | 01:52 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
if not the calibers, maybe a wheel was improperly torqued ?
Old Apr 26, 2021 | 02:29 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
caliper slides get'n rusty?
Old Apr 26, 2021 | 08:36 PM
Arrie's Avatar
Engage and release the emergency brake a few times. It could be that mechanism getting a bit rusty as it probably does not get used much.
Old May 17, 2021 | 02:08 PM
Mohd Saadi's Avatar
W212 2011
Update
Changed brake pads
And guess what clicking noise disappear
BUT THAG SQUEEZING THING STILL THERE 😭
HELP ☹️
Old May 17, 2021 | 02:22 PM
not sure what you mean by 'squeezing thing' here.
Old May 17, 2021 | 05:41 PM
2013 ML350 Bluetec
Have you followed through on any suggestions listed above?
Old May 22, 2021 | 09:06 AM
Mohd Saadi's Avatar
W212 2011
Please check the video in the first post
Old May 22, 2021 | 09:07 AM
Mohd Saadi's Avatar
W212 2011
Not actually what you suggest?
Old May 22, 2021 | 09:08 AM
Arrie's Avatar
Did you look into the emergency brake?
Old May 22, 2021 | 09:22 AM
Mohd Saadi's Avatar
W212 2011
Yes brakes shoes are new
After replacing brake pads clicking noise disappear
BUT this squeezing thing still ☹️
Old May 22, 2021 | 09:28 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
What if you press down on the rear corner of the car... does it also make that metallic creak? Fully applying the e-brake and then repeat your brake test... does it still make noise?
Old May 22, 2021 | 11:25 AM
ok, you mean a CREAKING noise.
when you changed the pads, did you lubricate the pins on the brake caliber ?
Old May 22, 2021 | 12:12 PM
S-Prihadi's Avatar
Try to hear it up close , but at the brake booster/master cylinder.
Old May 22, 2021 | 06:41 PM
Arrie's Avatar
I meant if you operated the emergency brake to see if it is causing the sound?
