Sponsored by: CARiD
Access to trunk question
Old May 28, 2021 | 02:36 PM
Steel.Grey.MB's Avatar
2010 E550
My trunk actuator stopped working. I cannot open the trunk via remote, driver side panel button or trunk handle. All it makes is a clicking sound. I tried inserting the key to manually open the trunk but no luck. Is there any way to access the trunk besides breaking the lock? Any help would be appreciated. Thanks
Old May 28, 2021 | 03:46 PM
cetialpha5's Avatar
Did you try lifting up on it? Sometimes it vacuums down the lid so that it doesn't pop up, but if you lift, it should still open. Otherwise on the key, not sure if you're using it right, you might have to turn it and lift it while it's turned.
Old May 28, 2021 | 03:47 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
The skeleton key is tricky to use, you must turn it all the way, one way locks so find that first, then turn the other way pretty far, sometimes it helps to have a key ring on the skeleton key to facilitate this, wouldn't hurt to lubricate prior to turning key either.
Old May 28, 2021 | 03:49 PM
RA72825's Avatar
Did you try pressing down hard on the trunk while pressing the fob? Maybe the latch moved somehow. Maybe a battery disconnect reset? A .45 slug directly into the lock, with a yee-ha!
Old May 28, 2021 | 03:53 PM
Yes, I was wondering if it was fully closed as well. Luckily there is no soft close air assist!
Old May 28, 2021 | 07:10 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
There is an emergency release button on the trunk inner side. Try pushing it with a broomstick through the rear seat opening door -
I wonder if the trunk key only drives an electric switch or if it does actually pull on the release cable -
Old May 29, 2021 | 11:48 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Mechanical blade suppose to open the trunk without electricity.
It is common with remotes that mechanical tumblers get gummed up from no use, but a can of WD40, some napkins and a lot of patience will make them working again.
Once you done with WD40, wipe it off and use graphite lubricant.
Old May 29, 2021 | 04:47 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
ugh, never use wd40 on locks, while it might work short term, it will gum them up worse long term.
get some of that liquid graphite sold as Lock-Ease, available at most any hardware store.
Amazon Amazon
I always keep a rag handy to wipe up any drips, squirt a little in the lock, dribble a little on the key, then run the key in and out a bunch of times before turning it, then turn it back and forth a bunch to ensure the stuff spreads everywhere inside before the carrier evaporates and leaves just the graphite.
Old May 29, 2021 | 09:15 PM
2010 E550
Thanks for the suggestions. I broke the middle access panel behind the cup holder to access the green emergency button. Unfortunately that did not work all I heard was a spinning of the actuator. I sprayed the key hole with some WD40 fast drying electrical spray and inserted and rotated the key CCW. still no luck. I kept pushing the button and having someone lift up the trunk. Still no luck. I tried to lock/arm the car then turned the manual key CCW and kept lifting the trunk. Fortunately the trunk opened and the alarm sounded. I took apart the actuator and a piece of plastic dropped. Needless to say I'll be swapping this out for a new one. Sorry for the long story. Thanks again. I thought I was going to have to make a trip to the stealership for repair.
Old May 29, 2021 | 10:19 PM
RA72825's Avatar
Thanks for the update!
Old May 29, 2021 | 11:30 PM
great
... Thanks again. I thought I was going to have to make a trip to the stealership for repair.
You reconquered your trunk and saved a nice tab for a weekend out of town !!👏
Now you can post your fixing the failed actuator?
What would you say caused the latch to pop a plastic chunk... any pictures?
Old May 30, 2021 | 03:29 PM
Fixed side LATCH....
while I had my dirty hand on, I took a stab at my noisy trunk latch
Trunk mechanism has 3 sub-components:
1-- moving side catch & release
2-- fixed side latch & close
3-- trunk lid motor
I think OP solved an issue with #1. Here I deal with the receiving end: the noisy No2 mechanism.
This is a good item to deal with around 60 to 80kMi.
Main issue: lack of any lube in key places...pivot points, shaft bearings and the like.
motorised cable puller
the output shaft has ZERO LUBE on the load side 😏
tough latch 'n lock with dry pivots
this metal part is the business end of the trunk lock. It is tasked with squeezing down the surrounding trunk seal. It's pretty easy to maintain it even without pulling any plastic cover....
5mn easy maintenance:
shower this clunky assembly with a spay can of dry lithium grease. Specially the right side with the 2 spring loaded shafts.
When the lock is allowed to operate more smoothly, the plastic cable puller with see a longer lifespan.
(To remove your threshold plastic liner pull up to release 4 plastic snaps then unscrew 2x plastic #10 nuts at the bottom end.)
