Passenger seat not moving forward or backward.
springy link L to R
> Motor linkeage vs. seat module:
- can you hear the seat motor humming but your seat does not move?
- Or is nothing much happening when you press the button?
In addition, seat back and head rest both work normally using the other door switches (3 switches, one for head rest, seat back and seat base - shaped like the seat)
Realize that seats are parts of car safety system. During a collision, front seats are moved at high speed to counter balance G-forces very effectively. So you want seat to be in repaired order.
I've been purposely rear-ended by a junkie... the smart driver seat in combination with ESP effectively saved my bacon 1st class.
> Options to consider:
-- You can confirm these suspicion using your compatible scanner look at seat module.
-- You can crack open the seat module for compromised solders on circuit board - (Seat is not a solderless module).
-- You can book a visit at you local MB specialist to work on seat unit.
-- You can try to swap module with new/used unit. I believe this module does not requires coding...
>> CAUTION / ACHTUNG! :
YLW AIRBAG CONNECTORS are married with seat unit... simply disconnect batteries for personal safety.
Any chance you have access to part #'s? @konigstiger
I called my local MB, they said i might need to replace my "seat track" which is $3800+tax CAD....yikes
Local mechanic suggested finding a replacement seat as its a lot of labour to take the seat apart, then have parts to test/try while its out etc. problem is hard to find a used seat.
I figured it would be one of the motors that needs to be changed. Unless you are implying the seat controller encomapss's these motors - im not too familair
At this point, I was under the impression it is not mechanical but module related - Your call.
Hopefully who gets to work on this issue won't first replace the $3800 parts before looking at the li'le controller module.
I am trying to work out how the mechanism actually works. Because I can't take the seat out, it's a bit challenging to find out what exactly happens when the button is pressed. Any hypotheses what might have gone wrong?
Posting here on the hope that the seat mechanism is the same as on the W212...
Thank you
Thank you
Based on your description that's the mechanism requiring service and parts.
I can bet the cable side got stuck in glue in what used to a light grease lubricant. Don't just replace the part without greasing the root cause after cleaning sticky mess.
Take a guess about driver seat... use it as your reference.
A good question you'll come across is about the normalization procedure of motor stops - (I dono
Thank you
I am not even positive if it's the back holder or the bottom rail - I am going to let this evolve until it becomes obvious which loose screw needs a drop of Loctite.
