Sponsored by: CARiD
Low beam bulb keep blowing
Old Sep 5, 2021 | 10:34 PM
bullpinn's Avatar
mercedes 96 e320
Replaced drivers side low beam on 2010 e350 coupe and it keeps blowing....
Old Sep 6, 2021 | 12:48 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
where do you buy your replacement bulbs?
how many?
Old Sep 6, 2021 | 07:58 AM
bullpinn's Avatar
mercedes 96 e320
autozone...... 2
Old Sep 6, 2021 | 01:07 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
does it blow immediately, or when you're driving ? assuming it doesn't blow immediately, is it the same brightness as the other side? does it flicker when you hit rough roads and/or bumps ?
Old Sep 6, 2021 | 02:48 PM
bullpinn's Avatar
mercedes 96 e320
it blows immediately. I ordered wiring harness cause the wire are exposed and I guessing that is causing it to short out.....
Old Sep 6, 2021 | 03:00 PM
rather surprised that doesn't blow fuses.
Old Sep 6, 2021 | 03:06 PM
bullpinn's Avatar
mercedes 96 e320
Old Sep 6, 2021 | 03:31 PM
HID or classic
What type of bulb is it?
I am guessing HID... A regular bulb would not blow immediately over basic 14VDC.
--> Ballast driver (serviceable ??)
Old Sep 6, 2021 | 04:18 PM
bullpinn's Avatar
mercedes 96 e320
halogen.....But like I say I think its the wiring harness.....
Old Sep 7, 2021 | 03:51 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Sorry, but if you have halogen lights, I will have to disagree on it being the "wiring harness." The wiring only brings power to the bulb. Wire, in itself, cannot "blow" a bulb. Only the power carried by that wire can blow the bulb. Measure the voltage at the terminals. For a halogen bulb, the voltage should only be somewhere between 12 and 14 volts. If it is within that range, the voltage cannot blow a bulb. If it is higher, it can. If the voltage is higher, you may be trying to use the wrong type of bulb.
If you do have high-intensity-discharge lights, DO NOT try to measure the voltage, as it will be very high and could shock you severely! If you have HID lights, you may need a new ballast (power supply) for the light.
Old Sep 7, 2021 | 03:55 PM
+1...
100%
Old Sep 7, 2021 | 07:28 PM
bullpinn's Avatar
mercedes 96 e320
Thanks . i will check the voltage and let you know....thanks again....
