Sponsored by: CARiD
Parking brake see owners manual
Old Sep 14, 2021 | 04:17 PM
abz5's Avatar
e class 2016
Hi All
I wonder if somebody could help me my 2016 e class e220d automatic Electronic parking brake (Hold)not working also dash showing Parking Brake see owners manual and yellow parking light on dash.This has occurred after I have changed front brake disk and pads.What could this issue be and what do I need to do.Thank you for your kind help
Edit
This is the sign on dashboard
Old Sep 14, 2021 | 04:23 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
https://www.youcanic.com/wiki/merced...manual-warning
Have you read the article above?
Old Sep 14, 2021 | 04:54 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
huh, that dash doesn't look anything like my 2016 E
Old Sep 14, 2021 | 04:57 PM
JCM_MB's Avatar
Definitely different, is it not?
https://www.carmagazine.co.uk/car-re...d-2016-review/
Old Sep 14, 2021 | 04:58 PM
W205C43PFL's Avatar
That's a W213 with the standard display.
Old Sep 14, 2021 | 05:01 PM
ah, W213 was new in MY 2017 here.
Old Sep 14, 2021 | 05:02 PM
W205C43PFL's Avatar
OP, your issue sounds similar to someone with a W205 has experienced:
https://mbworld.org/forums/c-class-w...e-warning.html
In short, it could be that the parking brake didn't retract fully and the parking brake button was not depressed fully.
Another thing is your door might not be closed firmly.
For details, please take a look at the thread.
Old Sep 14, 2021 | 05:03 PM
W205C43PFL's Avatar
Same, it was a MY17 here too in Canada, North American market is always one model year behind the European counterpart.
Old Sep 14, 2021 | 05:07 PM
W205C43PFL's Avatar
OP, if the thread doesn't provide the answers you need then continue asking. I also suggest posting in the W213 forum as yours is a W213, hopefully someone will come across your thread and answer your questions.
https://mbworld.org/forums/e-class-w213-208/
Old Sep 14, 2021 | 05:25 PM
fwiw, I get occasional parking brake warnings upon starting the car when its cold, and putting it in D, but its just the warning that the brake is set, grabbing the release handle clears it even tho it wasn't set. next time its in the shop, I'll have my mechanic check the adjustments
I'm pretty sure the parking brake on a 212 is mechanical, not electric, at least it sure feels like it when I set it by stomping on the pedal.... checks the parts catalog, yup, mechanical on E350...
Old Sep 14, 2021 | 05:53 PM
strife's Avatar
560SL, 380SL, E350
I have had the parking brake warning go off if my foot even BRUSHES the parking brake pedal while getting in the car. Pulling the handle resets it.
Old Sep 14, 2021 | 05:56 PM
abz5's Avatar
e class 2016
Originally Posted by juanmor40
yes I have
Old Sep 14, 2021 | 05:58 PM
abz5's Avatar
e class 2016
thank you will do
Old Sep 14, 2021 | 06:11 PM
JCM_MB's Avatar
Though mine is a 2014 W212, it used to have a problem with the parking brake (which I always use) not releasing completely. It had a soft return, and the warning light stayed lit. Mentioned to the SA during a service visit (@20K), the first time they probably lubricated it, but the 2nd time I mentioned they just replaced the mechanism under warranty ( #10 in the diagram). It is about 70K and still working. I guess a reject from QA
If I recall correctly, it used to be an issue with some W212. Discussed here in the forum
https://mbworld.org/forums/e-class-w...ml#post7038938
Old Sep 14, 2021 | 06:21 PM
I do note that, at least for my VIN, the pedal assembly (10) in the diagram above has part number A2044200984 superceded by A2044201584...
but none of this relates to the electronic parking brake on the OP's W213.
Old Sep 14, 2021 | 06:49 PM
abz5's Avatar
e class 2016
thank you
Old Sep 15, 2021 | 11:05 AM
konigstiger's Avatar
'71 Pinto
Try revisiting pad change mode in an attempt to reset. Parking brake consists of two actuators @ rear brake calipers.
File Type: pdf
Old Sep 15, 2021 | 12:19 PM
S-Prihadi's Avatar
I hate electric operated parking brake.
Does MB one can increase force as per push/click value on the foot lever ( like our conventional parking brake )....or it is an OPEN/LOCK kind of dumb-azz brake action ?
Old May 22, 2023 | 10:22 AM
mechatony11's Avatar
mercedez
I apologize for bringing up this old thread. I had a similar issue with my car, and it turns out that I got my wire harness damaged. I visually checked the wiring harness then I found out that the wires were cut. I did a lot of searches on this issue and came on in depth article which may be worth reading, search for "Mercedes Benz parking brake see owner’s manual on YOUCANIC" and you will see an article that goes over common causes and possible fixes, you can read about it yourself. I hope this information can assist someone else with a similar issue.
