Battery draining overnight
My first instinct is voltage regulator, but it’s not super obvious.
car is a 2014 E350 sedan - 65k miles.
Reading 5V on a new car battery sounds like skewed measurements, exactly what all the painted GND posts can deliver: drop voltage.
I don't believe these cars can run a "real 5V"... so it's got to be a "false 5V" reading, right?
Have you observed voltage on the iCluster while driving .... What does that show ???
As far as doing a "Battery Reset" we can asume it was done recently during the battery swap. It's usually good at helping crazy cars that drain batteries from "keep-awake".
Are you familiar with the electrical diagram between Prefuse and R-SAM... pull-it.
5V on a new car battery sounds like squewed measurent, exactly what painted GND posts can deliver. I don't think this car is able to run a "real 5V" so it's got to be a "false 5V".
Do you have the electrical diagram between Prefuse and R-SAM... pull-it.
it’s been at the indie shop since Monday AM - we’ve tested the battery and alternator which both check out. We tried clearing those error codes to see if they’d come back but last 2 days it has started up fine after the mechanic fully charged the battery back up and no errors or symptoms.
Also losing charge immediately, what does that mean? Do you suspect a parasitic draw? Car does not want or struggles to restart?
Since then the mechanic has charged the battery and validated the battery to be okay, as well as the alternator. It has been in the shop for 3 days now and the mechanic said it has started right up the last 2 days. We have also verified there at least isn’t an obvious parasitic draw.
I have some aftermarket “ghost lights” installed - essentially a light that goes in the door to shine the logo onto the ground when the door is open. Any chance those lights could be malfunctioning in a wat that would be intermittent or would it usually be an easy draw to spot?
Otherwise maybe its a firmware update and some weird software issue going on? I’ve heard the mbrace system being disabled causes issues after you do quicktests. Maybe the Rear-SAM has an issue? Maybe the fusebox itself or relay?
Incredibly frustrating to have this many question marks at this point. Otherwise been a great car, just hoping to get it back to being reliable again.
I hope you have a DC clamp meter and I am certain you have a digital voltmeter and a proper battery charger, to define your finding of OVERNIGHT BATTERY DRAINING.
Poor charging can be misread as OVERNIGHT BATTERY DRAINING, depends how and where you measure amps & voltage.
If you have the tools, I can point you where to start to first confirm OVERNIGHT BATTERY DRAINING , aside from potential poor/screw-up charging from your alternator.
I think these cars are like Japanese ORIGAMI folded papers... the complexity is hidden by the simplistic look.
Jokes asside, XENTRY has a provision to help troubleshoot "overnight drain" issues. These car computers can report their power consuption and sleep timings. This is made possible by a power shunt on the major modules... I know 'cause I resolder them when I see them.
