Sponsored by: CARiD
Need help finding part # and soliciting advice
Old Nov 18, 2021 | 12:34 PM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
Hello all,
I'm planning on replacing the oil pump in my M272 over xmas break next month and need a bit of help and advice. The help portion is I can't find a gasket in EPC between the oil pump and block. I've got to imagine there's a gasket or o-ring or something to ensure a proper seal, but I'm not seeing it. Can someone help me get the part number or advise if there's in fact no gasket needed?
For the advice portion, I'm going to be replacing the pump, pickup tube, tensioning lever, and the oil pump control valve while I have it out, as well as the front differential (it's leaking pretty good and I found a low mileage replacement for a good price), engine mounts since I'll be dropping the subframe, the subframe and driveshaft bolts, and the driver axle bearing that's inside the oil pan. Is there anything else I should consider replacing while I'm in there? The control arms are still fairly new and the steering rack still looks to be in serviceable condition.
As for why I'm taking on this project (if you're curious), I'm trying to resolve the ticking the engine is making. From everything I've read it's fairly common with the M272 and it's an oiling problem and replacing the noisy tappet doesn't have any impact. I've noticed if I refill the engine after an oil change through the oil fill cap, it'll quiet down for a good 10 or 15 minutes of driving immediately afterward. If I fill through the oil filter opening, the tapping is unchanged. I heard from one guy that said he's had good luck replacing the oil pump to fix the issue, so I figure it's worth a go. My leaking differential needs to be addressed anyway I'll post some pictures when it's done and provide an update one way or the other.
TIA!
Old Nov 18, 2021 | 12:46 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
need a VIN to look up part numbers as there are SO many variations on the 212 family.
Old Nov 18, 2021 | 01:06 PM
atraudes's Avatar
D'oh! Of course
WDDHH8HB1BA169351
Old Nov 18, 2021 | 01:23 PM
drawing shows a seal between the pump and pickup tube, but nothing between the block and pump?
File Type: pdf
Old Nov 18, 2021 | 01:59 PM
atraudes's Avatar
Yeah that’s what I saw too :-/
Old Nov 18, 2021 | 02:49 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I'll be interested to hear if anything takes care of the ticking.
Old Nov 18, 2021 | 03:28 PM
atraudes's Avatar
It's this kind of ticking (knocking), for reference. You can tell it's just coming from that one corner of the engine.
Old Nov 18, 2021 | 03:56 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
May I ask which oil you are using for this vehicle?
Old Nov 18, 2021 | 04:37 PM
atraudes's Avatar
Mobil 1 European Formula (0w-40 I believe?) along with a MB-branded filter.
Old Nov 18, 2021 | 04:39 PM
are the MB filters still made by Mann ? On my older MBs, I always used Mann or Mahle, and never had any issues.
Old Nov 18, 2021 | 04:53 PM
atraudes's Avatar
Yeah 90% sure without looking. I only get the MB ones because I send em back to FCP every time, so why not?
