Bakup camera inop
Fuse Box Diagram Mercedes-Benz E-Class (W212; 2010-2016) (fuse-box.info)
> Next you're gona use a scanner to diagnose the camera itself. Can you reach the cam module?
> Also you can go ahead and remove the liner off the trunk lid to trace signals. Trunk "Open/close" cycles tend to chop the trunk harness.
> Next you can indulge in Reset therapy after diagnosing CAN errors.
(AFAIK the camera super long CAN line is real good at picking up noise and piling up errors. The resistors are likely too far remote from that location. However it can work.)
I have no way of knowing how thorough the scan or the harness examination was but they say that they did these things.
No code to them means bad camera module.
I will be pulling the trunk liner to examine harness as much as my untrained eye can see.
Anyway you're gonna need to remove the liner for access, you might as well poke your trunk harness for signals.
Good luck 🤞
This exemplifies what I have heard about these cars. The major mechanicals like engines and transmissions will last a long time. It is the electronics and accessories that will make the decision whether the car is a long term keeper or not.
Pls let us know how it went to get this resolved.
