Sponsored by: CARiD
What is electric box next to spare tyre
Old Mar 3, 2022 | 02:40 PM
gussy81's Avatar
W212 E Class 220D
Hi,
When I lift the floor of my boot I see a spare wheel and to the right there is a large electric box of some sort with cables hanging out if it. Does anyone know what this is?
Old Mar 3, 2022 | 04:28 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
AUX...
Originally Posted by gussy81
Hi,
This I believe is your 12Volts AUX battery flanked by its SSR Mgt relay where fat cables are terminated.
Some W212 models have their MAIN batt there to keep people guessing I suppose
Having found that location, you can now conveniently charge both batteries directly from there by switching the (+) lead from one big red cable to the other.
This trick becomes handy when the MAIN is flat and you can't pop the hood open easily.
Old Mar 3, 2022 | 05:13 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
Hi,
a photo of this would be helpful, as there's a number of possible things there.... the rear SAM, the HK Logic7 subwoofer, a stereo amplifier, and yes, the aux battery if you have push-to-start (if you don't, a much smaller aux battery is located under the driver side instrument panel).
this is under the rear deck of a US 2016 model E350 wagon (aka estate aka touring), the black plastic thing that says "harman/kardon" is the subwoofer, and the thing below it is the R-SAM and aux battery.
Old Mar 6, 2022 | 08:27 AM
gussy81's Avatar
W212 E Class 220D
This is what I am referring to. Thanks
Old Mar 6, 2022 | 09:02 AM
DFWdude's Avatar
2016 E350 Sport
Nothing has changed... It's your Auxiliary battery... Tons of threads about it here, some good, others not so much...
Old Mar 6, 2022 | 09:37 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
What country you are in?
My US E250 Bluetec doesn't have spare as they fit DEF tank in the space. So beside tank and battery on the side, I also have DEF module there.
Old Mar 6, 2022 | 09:46 AM
hyperion667's Avatar
2012 CLS63
Don't listen to these guys, that's part of the missile guidance system that isn't hooked up from the factory as you have to purchase armory from your authorized weapons dealer, check your local/county guidelines for state and local regulations.
Old Mar 6, 2022 | 10:47 AM
Baby battery boot ports...
2-In-1 port for CTEK trickle charging
This is your 12Volts AUX battery flanked by its SSR Mgt relay where fat cables are terminated.
Your car uses 2x batteries. The Main battery up front does the important work and may benefit from CTEK maintenance.
Take your time to search this forum for tons of existing knowledge.
Old Mar 6, 2022 | 11:52 AM
kajtek1's Avatar
DARN, the salesman lied to me that this operate passenger ejection seat.
Old Mar 6, 2022 | 01:54 PM
gussy81's Avatar
W212 E Class 220D
I am located in Ireland. Car imported from UK
