AUX static noise
P.S without ami cable noise is still there but less loud.
Whenever I just start ignition it has static when I start engine noise gets worse and when I rev its worst. I just noticed this as I installed roadtop kit which uses audio with ami cable, was using bt before. What should I look for to diagnose this?
These modern cars are loaded with strong noise sources (injectors, Ignition coils, FuelPump, Engine Fan, Alternator,...).
Try to use grounded shielded coaxial cabling for signals and capacitors to cleanup the power supply of your roadtop audio unit.
Also experiment taping power at different locations hopefully less noisy.
Try to figure if your electric noise gets in the power or the audio then concentrate on that.
You're saying that's where the noise is being picked up. The input is always noisy ... correct?
> S'nR: signal noise ratio:
Can you set a higher audio level into this input ?
This way you don't use a higher volume setting to amplify (low audio + high noise).
You want (high audio + low noise)
About 2nd part. aux comes from roadtop unit which is feeding audio with setting amplifies audio to max(my current setting) to ami so I believe it will cause high audio with lower noise compared to if I dial down setting so I am doing it properly I assume. On the other note on max volume I can't stand static but if you turn on music you cant even hear static lol so like I can technically let it slide but I am perfectionist and will get at root of this issue 100%
By the way. Once you have time, can you please try switching to aux at max volume to see if you hear static too? you have '14 car so you should have NTG 4.7 unit too.
I believe my whole interrior is rebuilt and someone f'd up wiring I am almost certain
How can you switch over to the Aux input???
There is an interface module in some of these cars, perhaps it's what introduces noise picked through unfiltered dirty 12v... or wire harness coupling travelling side-by-side ?
in my case that big square port is adapter to female 3.5mm so that I can plug in roadtop box output
Have you tried replacing the MB aux adapter cable? Mine had a kink and caused noise
