Sponsored by: CARiD
Ac / heat not blowing
Old May 23, 2022 | 01:07 AM
donny79's Avatar
e350
I having this issue during the winter the heat would turn on sometimes now it’s summer and nothing blowing out? I’m thinking it’s the blower, anyone have any other ideas?
Old May 23, 2022 | 03:41 AM
BenzV12's Avatar
W212 FL
Check the freon level or R134 .
I hope that's an easy fix for you
Old May 23, 2022 | 02:55 PM
donny79's Avatar
e350
This morning I got in and it was full blown power A/C now it not working again…. Would w bad resistor cause the working then not that’s going on?
Old May 23, 2022 | 02:58 PM
donny79's Avatar
e350
Bad regulator I meant not resistor
Old May 23, 2022 | 04:23 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
MB stop using freon about 30 years ago, but some old-timers still call refrigerant that.
You need scanner for troubleshooting.
Good scanner will have self-guiding page , for it, but if you have cheaper 1, that can pull live data, read all temp sensors in the morning, before engine start and then check refrigerant pressure on hot afternoon with AC on.
Old May 23, 2022 | 06:33 PM
donny79's Avatar
e350
I put it on scan tool nothing popped up, it worked this morning a lot of air then later nothing, idk what it could be
Old May 24, 2022 | 01:03 AM
kajtek1's Avatar
Nothing pops up on my scanners neither. I have to scroll the menu to the page I want to read.
Old Jun 13, 2022 | 09:02 AM
MIKE1402's Avatar
2012 e550 coupe
I'm having the same problem with my 2012 e550 coupe. It's like my a/c works when it's wants to. Did you ever find a solution to your problem.
Old Jun 13, 2022 | 04:16 PM
NuMBS500er's Avatar
2014 E350 4matic sedan
I have the same issue today, It is 90 degree out, but the blower is not working. Turned the fan up, nothing. Any suggestion of where to look first/
Old Jun 13, 2022 | 06:40 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Arrow blower calls for attention
On a hot day you turn on AC and manually crank up fan speed... but no air comes out, fan stays Off.
Have you scanned AAC, checked the fuse and probed for voltage at the regulator In/Out.
W212 smart blower driver
Have you noticed if your blower was noisy and the old cabin filter was all plugged up - - if so chances are your blower regulator got toasty !
Once diagnosed... you can try a 1¢ FIX on the bad driver circuit board... just test and BYPASS the inline thermal-fuse to get back on the road + remove cabin filter to ensure AIRFLOW at all cost.
