Sponsored by: CARiD
Tensioner, 2 pulleys and serpentine belt - New vs Old
Old Sep 27, 2022 | 02:43 PM
S-Prihadi's Avatar
Continued from this thread : https://mbworld.org/forums/e-class-w...ng-torque.html
Tensioner, to counterclockwise it a tiny bit to remove tight tension to belt.
OLD = 35 Nm
New = 40 Nm
Tensioner, to hit full stop ( spin counter clockwise ), spring maximum power.
OLD = 56 Nm
New = 71 Nm
5 newton meters difference in pre-tension is visible from the shaky-shaky
Funny, the new belt seems not 100% true-perfect in its dimensional shape, obvious seeing its grooves ( while moving ) on the tensioner smooth pulley
Old Sep 27, 2022 | 06:56 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Belt quality...
Is this a Continental serpentine doing this weird sideway walking... ? I wonder if this is to help promote ribs friction?
Old Sep 28, 2022 | 12:33 AM
S-Prihadi's Avatar
Yes, it is Continental for Mercedes. Same as old one.
OLD
NEW
Side Walking, yes that's a better description. Thank you.
If I recall correctly, I need to do 3 x 360 degrees spin on the main crankshaft pulley to get 1 full revolution of the belt.
Why is it everytime I pay close attention to something, I discovered some unpleasant facts ?
The multiple V shape of the belt groove itsel is the friction maker by design, isn't it ?
I know long belts like conveyor ( super flat , no grooves), which is custom glued/joint on work location, can have slight misalignment at the glued/joint if the cut + gluing placement is not perfect.
Old Sep 28, 2022 | 02:56 AM
inquisitive mindset...
......pics....
Surya says: "Why is it everytime I pay close attention to something, I discovered some unpleasant facts?"
--> Because you are able to analyze objects to collect and understand data.
You ask yourself interesting questions in search of rational facts....
-- Typical questions such as:
- How does this work?
- What are the stressors
- What makes this fail?
I think you got the manufacturing defect figured out with the two ends junction improperly matched. That's pretty bad for a leading German brand!
This lateral load strains all bearings: compressor, alternator, water pump, plastic idlers... ouch 👎
Could this be the right time to step up to a perfect "Mitsuboshi belt": you get twice the mileage for 1/2 the price. They are Honda's OEM belt.
(Same thing with Bosch plugs vs. NGK/Denso spark plugs!)
Old Sep 28, 2022 | 05:16 AM
S-Prihadi's Avatar
Before I declared that the belt is the bad dude, I done some other WHAT IF scenario verification.
01. Does the pulley itself has OUT and INNER face for its installation ? I can say YES.
I googled the bearing number NSK 6203DUM18A just to make sure, if this bearing has a requirement which side is to be installed as OUT or INNER face ?
Can't find any data and it seems, the bearing is not pushed into plastic pulley housing, but its seems it is pre-molded. Look at the outer race is so thin, I bet some of it is embedded inside the pullley when injection moulded.
Googllng NSK 6203DUM18A will get you pulley and not the bearing stand alone. European or Japanese cars use this NSK 6203DUM18A.
So perhaps NSK made these for car OEM including the pulley and everything bolt,washeryada yada....plug and play.
A bearing outside race would be this thick/wide. Source : https://www.qualitybearingsonline.co...gs-17x40x12mm/
Below is NSK 6203DU family
Did MB or NSK worker screw up during bearing placement on the bolt and wrong face installed ?
Well.................. it seems so
I don't know which is the correct version as far as PULLEY OUT facing face, pulley no 7 or pulley no 6 ?
My gut feeling is to choose the "R" for inner face. What do you think Cali ?
Even using straight edge, there is no way to measure the difference or misalignment between using L or R as OUT side face or INNER face, which is approx 0.35mm difference only.
0.25mm from pulley groove and 0.1mm from the bearing installed depth.
Bloody hell, need to remove aftercooler again. Sooner or later I will break some plastic fittings for sure and the rubber short & thick hoses on my aftercooler ( 2 units ) and for the throttle body ( 1 unit ) may
eventually get worn out from too much assembly and dis-asssembly . But at year 10th ( 2 more years ) , I will replace them anyway.
Old Sep 28, 2022 | 12:26 PM
S-Prihadi's Avatar
I have ordered 2 of 6PK2120, 2120mm. The MB one is 6PK212, or 2125mm which is 5mm longer . 5mm shorter by Bando or Optibelt won't matter, the tensioner can handle that.
One is by Bando Japan. One more is by Optibelt Germany.
Funny is that no brand carry 2125mm .... not even Mitsiboshi. All are 2120mm for 6PK.
I am still trying to find the Mitsuboshi one. Shorter ones available but MB length seems not common.
If indeed the pulley #6 assembled wrong for its inner face side by MB or NSK, how can 0.35mm misalignemnt look so obvious side-walking the belt ?
I think I agree with you that this Conti is probably the culprit.
Old Sep 28, 2022 | 12:34 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
First, I would make sure you are not falling under visual impression, where different colors on the belt makes impression of it moving sideways.
Bearings for generations are build with very high precision, so not likely you will find 1 with factory defect, what brings the issue of plastic run under the belt.
I can't say from the pictures, but are your ribs running on smooth pulley? That is not recommended, so I wonder if that is a case?
I am not familiar with this engine, but pulleys 6 and 7 looks identical and should be run either direction.
Old Sep 28, 2022 | 01:26 PM
S-Prihadi's Avatar
K1,
I slow-mo the video for easier viewing.
I did not say the bearing is defective, I said pulley 6 and 7 was not assembled the same for its inner facing side and hence there already 0.35mm misalignment between pulley 6 to 7.
The tensioner is designed to use the smooth side of the belt not the rib, and tensioner's pulley is also smooth. Use a big PC screen 27" to view video or photos, don't use smartphone or even tablet, our eyes are old
The belt does have a slight side walking.
Also true as you said, different colors on the belt made impression that the belt is MUCH side walking, while actually only minor side walking. Still , it is doing side walking.
Old Sep 28, 2022 | 01:30 PM
kajtek1's Avatar
Again, even with slow-motion, I can see the belt changing color along the run, but I can't say if it is walking.
Rubber belts and tires do have pretty loose tolerances, so complaining about 1/4 mm play is splitting the hair.
I still don't like the design where ribs run over flat pulley, but if MB design it this way, it has to be acceptable.
Old Sep 28, 2022 | 01:39 PM
the bottom of this pickle....
Again here you got us focussed on interesting facts about the carefully crafted serpentine issues.
Since I got my car new, I can hear a cyclical "whoa-whoa-whoa" from my the belt train at low idle. This is a common sound of old neglected engines.
A normal belt sound should be smooooth or silent with no cyclical noise. I am sure you've heard this because you have an engineer's ear for noises to diagnose mechanical problems by sound.
Now we know why thanks to Conti amazing OEM serpentine as good as rebadged aftermarket.
This Conti serpentine issue examplifies my tag line about German carefully carving business opportunities with system designs.
Great quality is bad for business as great bottom line is built on repeat business.
They design perfect systems then introduce variables to forecast profits.
The poor pulley alignment and the belt walking I think are two separate issues.
The idlers circumference is like 6 Inches or 15Cm. When it off alignment, its a static problem that does not vary.
Wobbling comes from misguided alignment with excessive freeplay . Here very little true freeplay. The funny belt walking sideways helps wear out bearings to create freeplay. It primarily strains the two idlers before impacting components (A/C, ALT, PmP).
Once the idler bearings are wobbling then ALT gets a wild ride.
Surya says: " it takes 3 harmonic balancer revolutions to see the belt defect".
- I believe the circumference of crank pulley is smaller than 1/3 belt length, more like 1/6 right?
- Perhaps there are more than one "sideway feature" per belt.
Let's put the belt defect to bed then deal with idler misalignment so we don't get everything mixed up.
I am not sure how to measure or visualize pulley static misalignment... we need a reference surface or perhaps an optical laser to project a line... there must be a time honored best-practice way to go about this old-fashioned chaos
Old Sep 28, 2022 | 01:48 PM
S-Prihadi's Avatar
K1,
The very last part of each video session you can see the belt slide into engine side and comes out to radiator side again. Yes minor but so irritating for a belt with beautiful 6 ribs.
Information between 4 brands, Bando - Optibelt - Mitsuboshi - Conti, Conti does mention this , but on the CONTI V MULTIRIB ELAS ( elastic, I think ) : Suitable for reverse flexing
On my engine, it is the CONTI V MULTIRIB.
They got another one CONTI V MULTI RIB POWER
ADD INFO :
Old Sep 28, 2022 | 01:54 PM
S-Prihadi's Avatar
Well, this fun Cali , I am actually enjoying it.
Old Sep 28, 2022 | 01:55 PM
kajtek1's Avatar
You think your air flow behind radiator can reach more than 80C ?
When I don't mind hair-splitting over technical issues, this is ... hair splitting.
Old Sep 28, 2022 | 02:01 PM
S-Prihadi's Avatar
It can hit 85C +. I logged it before.
I have a thermocouple at the airflow between radiator to engine block.
It is the T2 on the left diplay, at 89C
Old Sep 28, 2022 | 02:10 PM
LoL 🤡
knowledge: we like connecting dots 👏
Appearantly the automotive serpentine application benefits from a little elasticity to absorb A/C compressor load cycling.
The Conti. "power" is for fixed and steady loads.
A tiny bit of length wise stretching helps the tensioner carve a "pigeon hole" around average position. This is why belt and tensioner live and die together.
A new belt is best not used on a tired 80kMi tensioner! Less with frequent A/C users: now we know how and why!
Old Sep 28, 2022 | 02:16 PM
S-Prihadi's Avatar
Good thing my compressor is the variable one, so like a soft start
Old Sep 28, 2022 | 02:30 PM
soft start A/C load...
this modern compressor type has a smoother load but it spins non-stop!
You can add to check its bearing freeplay to your preventive maintenance list .
Promise yourself NOT to replace your compressor PWM solenoid when it gets jammed by goodies.
Junk the whole unit to save... ✌️
You don't want to deal with whole A/C system contamination by compressor shavings.
Old Sep 28, 2022 | 03:04 PM
kajtek1's Avatar
I never had to replace AC compressor, even some of MB I sold were over 200k miles and living in CA, now in Vegas, the AC on my cars works at least 75% of the annual driving.
Old Sep 28, 2022 | 03:22 PM
200kMi is a good deal 👍
Can this longevity has something to do with not redlining your diesels like a twin turbo -Or simply use of basic clutch compressors like on my California W212.
Low stress > long life !
Old Sep 28, 2022 | 04:58 PM
kajtek1's Avatar
I drive MB for over 25 years and if remember only W123 and W124 had clutches on compressor.
W123 AC was so-so and after I converted it to r134 I did not expect much, but W124 at 1 point had evaporator sensor failure and was creating layer of ice at the bottom of windshield.
We had to shut AC off from time to time as ice was covering driver view. Before I fixed the sensor that is.
Than W210 with digital controls was real performer. I sold it to fellow forum member and he replaced compressor above 250k miles, mostly as a precaution as the system had miniature leak he was dealing with, but was still cooling.
Our W212 is often park in 110F when we go out. I always find a shade, but 110 is 110. Still AC performs so well that I never had to precool the car before entering. It takes about 10 seconds for the AC to start blowing cold.
Old Sep 28, 2022 | 09:37 PM
Small world ✌️
Pelican sells Mitsuboshi for Porsche
The distinguished MBWorld sponsor knows what time it is...
Old Sep 29, 2022 | 10:38 AM
kajtek1's Avatar
Aftermarket is pretty strong those days.
I was just shopping for sway bar links for my W212, who I assume are rare parts to replace, yet amazon alone gave me about 5 aftermarket choices.
