Sponsored by: CARiD
Timing chain starting to rattle at start up
Old Oct 21, 2022 | 09:34 AM
martz's Avatar
German
Greetings to all
2013 E350 - Engine number 276952 30 210062
Could anyone recommend a good independent shop in NOVA that you would highly recommend to do the Check valves and Tensionsers.
Would prefer to avoid the stealerships..
Thank you in advance
Old Oct 21, 2022 | 10:13 AM
Fliplegend's Avatar
S212 E350 Estate
When I lived in NoVa, I took my german cars to RRT (Road Racing Technologies).
https://www.rrtautomotive.com/
Old Oct 21, 2022 | 01:46 PM
martz's Avatar
German
Also, if I may add, does not necessarily need to be just NoVa . Anywhere in the DMW area would good too.
Thank you!
Old Oct 21, 2022 | 04:25 PM
AllPhonesAretap's Avatar
2013 W212 E350 RWD
Originally Posted by martz
Greetings to all
How many miles?
Old Oct 21, 2022 | 04:41 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
lock pin damage
VVT gear set may come your way next.
Old Oct 24, 2022 | 11:38 AM
martz's Avatar
German
83k
Old Oct 24, 2022 | 11:39 AM
martz's Avatar
German
Cali Benz... kindly elaborate. You stating more to consider to replaced?
Old Oct 24, 2022 | 12:25 PM
Don't be surprised if the shop tells you: both Intake VVT gears are history but do question "all four" VVT being bad though.
Replacing the tensioners brings the technician to align engine timing marks and witness the VVT skipping forward if unlocked... ie. bad VVT.
This is inevitable wear with this setup. You can delay it with good engine oil but not avoid it.
