Sponsored by: CARiD
Multiple cylinder Misfires and black smoke in w212 with M278 engine
Old Oct 21, 2022 | 03:28 PM
Ash305's Avatar
e 550
Exclamation Multiple cylinder Misfires and black smoke in w212 with M278 engine
Hello Everyone,
I'm a new member to this community. I see there are many experts here who provide guidance and suggestion and I'm really loving that. I'm planning to buy a 2012 E550 in next few days. The car is very clean inside and out, up until 2020 it was a one owner. I have checked its vehicle history and see that it was regularly serviced at Mercedes dealership and mostly highway driven. I spoke to the dealership it was serviced at and they never had to service it for any major issues apart from the regular service A and service B maintanence.
However, the car somehow seems to neglected after 2020 by another owner. Here are the issues with the car
- The AC light blinks 3 times and shuts when turned on(went through mb forums and I'm guessing it low on freon gas).
- Takes a while for the car to start. Its not immediate. Even after warmup(or cold start) it takes good 8-10 cranks before it can start.
- The engine runs rough, shakes a lot and also has a CEL on. Had it scanned with a OBD tool and found all these codes : P0301, P0304, P0302, P0300, P0308.
- In park(did not drive it since it was throwing all red flags.), when you floor it, it blows black smoke as if there was oil burning inside.
I understand the first thought would be to get away from the car as all these signs are definitely a red flag but I'm no expert on Mercedes or any other car and wanted to see if anyone of you guys had these similar problems. Or what would be causing these issues. I'm willing to put down some money if its a tune up or cats issue. Just wanted to avoid a engine teardown.
Thanks in advance!!!
Old Oct 21, 2022 | 03:57 PM
PeterUbers's Avatar
Run away. Now. Not joking
Old Oct 21, 2022 | 04:05 PM
E55Greasemonkey's Avatar
This place is a joke.
Yes, run, and run fast. A replacement engine will cost more than the car is worth.
Old Oct 21, 2022 | 04:26 PM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Run faster.
Old Oct 21, 2022 | 04:30 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
resurrecting neglected bargain... or not ?
it does sound like this money pit needs attention.
You can almost fix anything on budget except cylinders scoring - No way to tell exactly about the tranny wear... they too need timely maintenance.
This project car is a gamble or a donor chassis - Perhaps all it needs is a fuel filter, plugs and a bit of luck
Old Oct 22, 2022 | 03:14 AM
BenzV12's Avatar
W212 FL
I was also told by the mechanics to buy a high mileage W221 S Class with M278 because turbos are alone would cost $$$$ to replace. In this case, if replacing engine would cost more than the value of S Class worth then in an E Class it would be . I didn't like what OP said about the car, I think it will need a major overhauling to fix everything
Old Oct 22, 2022 | 08:22 AM
Blkvip's Avatar
12' E559
just keep looking. wouldn't waste time on something that's already off to a bad start. Plenty more 550s out there
Old Oct 22, 2022 | 09:12 AM
DFWdude's Avatar
2016 E350 Sport
I'm NOT convinced that a second owner can mess-up a car through "neglect" in less than two years.
That said, you don't need to buy a car with known issues that you think are serious enough to question the car. So I would skip on this car, too.
Old Oct 22, 2022 | 11:50 AM
KlausPA's Avatar
E350 Wagon
How much is the asking price?
Old Oct 22, 2022 | 01:56 PM
RA72825's Avatar
Offer $2,500
Old Oct 22, 2022 | 10:07 PM
Ash305's Avatar
e 550
Asking 7k.
Old Oct 22, 2022 | 10:08 PM
Ash305's Avatar
e 550
I however didn't not hear any metal clanking sound to point it as cylinder scoring. Can anyone verify if points mentioned in this video are relatable
Old Oct 23, 2022 | 07:00 AM
ygmn's Avatar
2015 E400 Sedan
for that price on a 2020 - Something is seriously wrong.
Why waste your time unless you are a mechanic with time to fix this car..
Too many misfire codes -
Old Oct 23, 2022 | 05:07 PM
RA72825's Avatar
it’s a 2012?
Old Oct 23, 2022 | 05:21 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Black smoke won't be oil. Don't these codes point to misfiring and thusly poor fuel combustion?
Old Oct 24, 2022 | 01:51 AM
Ash305's Avatar
e 550
One more thing to add. I was digging a little deeper and found that the engine actually had 175k miles (mostly highway)back in 2021 and then it was sold to someone else. But the odometer currently says it's at 75k. I'm not certain if a digital odometer could be rolled back easily, so I was guessing that the owner changed the ECU and thus leading to poor ignition and what not. Because like you guys expressed, even I feel it to be strange for someone to abuse an engine that it messes with the internal components.
Old Oct 24, 2022 | 07:14 AM
chassis's Avatar
2017 GLE350 4MATIC
What is your next step? Are you going to buy this car?
Old Oct 24, 2022 | 07:29 AM
RA72825's Avatar
Yes, the digital ODO can be manipulated to easily knock 100K miles off.
Old Oct 24, 2022 | 01:51 PM
Fliplegend's Avatar
S212 E350 Estate
As if you needed another red flag.
Old Oct 24, 2022 | 07:52 PM
2013 ML350 Bluetec
There are too many cars out there with verifiable histories to get too interested in this one.
