Sponsored by: CARiD
S212 coolant low?
Old Oct 25, 2022 | 07:06 PM
p30amg08's Avatar
08 E63 AMG P30, 2013 S550, 09 E63, 14 E63 S Wagon, 14 E350 Wagon(current), 13 C63 P31 (current)
S212 coolant low?
Had an error message ive never seen in my 2 plus yrs of ownership.
Coolant low.
Error went away after driving 2 miles
We have had a drop in Temps recently but don't know if that's related.
Any advice?
Old Oct 25, 2022 | 07:41 PM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
The coolant level in your photos shows low. The appropriate level of the fluid should be where the black plastic and white plastic on the reservoir meet. If you top off make sure you get the right color fluid and wait till the engine has cooled to open the reservoir cap.
Old Oct 25, 2022 | 08:43 PM
p30amg08's Avatar
Thank you for responding.
I wonder why it got low. No leaks under the car. Drives fine. Doesn't over heat.
Old Oct 26, 2022 | 07:33 AM
S-Prihadi's Avatar
The volumetric expansion coefficient per 1 Celcius for 50/50 coolant mix is below and its volumetric expansion at 10C to 110C.
Source
https://www.engineeringtoolbox.com/c...ts-d_1262.html
https://www.engineeringtoolbox.com/v...ion-d_315.html
So when filling up coolant to its max line ( white plastic gone, touching a bit of black plastic ) was say 30C hotter or at 35C than when inspected at 5C, don't be suprise to see equivalent of 120 cc volume change.
Old Oct 26, 2022 | 07:41 AM
Raj1471's Avatar
https://rxmechanic.com/how-much-coolant-loss-is-normal/
"How much coolant loss is normal?
A coolant leak is bound to happen with issues within the radiator or engine, but there are chances of depleted coolant levels with no trace of leakage. A minute amount of Coolant might evaporate as it’s not a closed system entirely due to the availability of an overflow reservoir. However, with time, the Coolant flows within the engine and radiator; the chemical agents, after exposure to high temperature, lose their natural balance and get evaporated without any significant leakage. As the engine gets old, the Coolant evaporates more and more. As a usual calculation, it is found that for every year an engine passes by, the coolant level drops to 0.25% in 4 months provided that the engine is functioning well and with no leakages or damages.
0.25″ inches quarterly makes 1 inch for every year. This evaporation of the Coolant is expected due to extreme temperatures, which turn the water element within the Coolant into steam. Due to this, it is advised to clean the radiator after a couple of years and change the Coolant alongside in order to prolong the engine’s life."
Old Oct 26, 2022 | 12:19 PM
p30amg08's Avatar
Source
Wow. Great. Thanks for posting
Old Oct 26, 2022 | 11:19 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Raja, no leak is expected in a closed circuit. When coolant is low, it has leaked out and gone somewhere!
My $70k W212 leaked coolant since the first day... I could smell it my garage along with the standard engine oil leak.
Unfortunately for owners, US Benz are built with standard mystery leaks... easily fixed under $1,000.Ea. 👏
Old Oct 27, 2022 | 02:00 PM
p30amg08's Avatar
Spoke with SA. He said no leaks. Just need top off. Happens as Temps changes and as water evaporates over time.
