Sponsored by: CARiD
W212 M271 intermittent ECT sensor issue
Old Oct 26, 2022 | 05:00 PM
Wail maghazi's Avatar
E200 CGI blueefficiency 2010 W212
Hello all,
for the past year i had an intermittent ghost issue with my ECT sensor, as it sometimes fluctuate irregularly, from constantly sitting still at 85 degress and then suddenly drops to 30 and back again to 85 and sometimes it disconnects entirely and then reconnect, the weird thing is at the same time the ambient temperature sensor starts acting up as well, from having a 25 degrees reading to suddenly giving 65 degrees, both of the temperature sensors act up at the same time and there is no pattern, sometimes it appears as soon as i start the car and sometimes after driving for a while, and sometimes with the engine off and ignition on, it just fluctuate around, honestly it's really frustrating and weird, i checked the wiring of the ect no apparent damage, i checked the resistivity of the wires and i had a 0.8 ohm reading which i think is good, i replaced the sensor but still the issue exits,
i am unable unable to pinpoint the exact reason for the issue, if it was an ECU issue it should have affected the other sensors as well since they all have the 5v reference voltage, i checked the wiring diagram for both sensors, it appears that the ECT is connected to the ECM directly while the ambient temperature sensor is connected to the front sam unit, my theory is that the ambient temperature sensor might be faulty and affecting the reference voltage of the ECT sensor,
any advices regarding this matter or if someone encountered a similar issue?
Old Oct 26, 2022 | 05:11 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Originally Posted by Wail maghazi
Hello all,
Internally broken wire? Loose connection/pin? Intermittent connection due to motion? Perhaps checking around the connectors
Old Oct 26, 2022 | 07:40 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Screwed up GND....
Sounds like a poor GND screw shared by the ECU & SAM for these 2 circuits.
The fact both temp sensors dance together is a great clue... find out exactly what it is they have in common.
It's not 100% guaranteed to be a bad shared GND... no only 90% LOL
Anyway it's going to be interesting to work this out
Old Oct 27, 2022 | 12:40 AM
S-Prihadi's Avatar
Wail,
Aside from making sure having a clean ground as Cali pointed out and all the wiring checks you done, some questions please :
01. Which sensor di you replace ? ECT ?
02. Read this : https://mbworld.org/forums/e-class-w...ip-sensor.html
03. I assume you are "reading" ECT and AAT data from your instrument cluster...yes ?
Get a scanner or an OBD2 gauge and remove the Instrument Cluster from the equation. You see, Instrument Cluster is a processed data and a 2nd hand data from ECM or Front SAM.
Just in case you Ins-Cluster is the bad dude.
If you use a scanner, the ECT and AAT data is more direct from ECM for ECT and Front-SAM for AAT
Now do the wire wiggle test at sensor body, full length wire harness and the ECM & Front SAM connector and see what happen.
Is your M271 the EVO one as in M271.8 ?
I have with me M271.8 EVO ECM wiring , but on a C200 W204. It should be the same for W212 if the engine is the same.
DE18LA (M271Evo, 271.8XX)
At ECM if a pin ID is 31, that is Ground, but since this is not the common W ground. This is "clean" ground the Z7/43.
The ECM W common ground is W16/5 OR W16/6 depending if Left Hand Drive or RHD. Again I am using C200 W204 as reference for the engine bay side grounding. But you will understand the logic if on W212 and I am sure you have complete wiring diag.
I spent time on this M271.8 EVO for a friend. Misfire, whacky one, intermittent.
The ECM was the bad dude and one of the female connector at the ECM big connector was also bad contact for Ignition 1 trigger.
Well, the ECM connector was remove/re-connected so many times during the test, no surprise the high amperage baby sized 1.2mm MLK of Ignition 1 female connector at the ECM connector goes "tired",
afterall this is a 20-50 insertion cycle class male and female connector in use. This engine is still using the dummy COP coil which its driver is at the ECM and not at the COP itself.
So all 4 baby sized 1.2mm MLK male & female connector of Ignition triggers at ECM body and ECM connector carries 10 AMPS per firing. Stupid design, because the connector at the COP itself is the robust 2.8mm one, I believe SLK 2.8
The female connector usually is the one that goes bad first always, because it has the "springy-ness" function which weakens after too many insertion cycle.
OK...good luck with the wiggle test and using scanner/OBD2 gauge.
Old Oct 27, 2022 | 12:58 AM
S-Prihadi's Avatar
I forgot to add : https://mbworld.org/forums/e-class-w...inda-liar.html
Above is what I meant as "processed" data of how Instrument Cluster shows you the coolant temp.
So if the liar-chip got drunk, it may do what it does to your coolant displayed value
Old Oct 27, 2022 | 10:16 AM
i checked around the connectors and measured the wires, still no luck.
Old Oct 27, 2022 | 10:17 AM
That is surely a possibility I'll review the circuit diagrams once more to find if there is a shared ground between them.
Old Oct 27, 2022 | 10:22 AM
Originally Posted by S-Prihadi
Wail,
i replaced the ECT, actually i confirmed the readings using an OBD scan tool, the sensors are in fact giving the same readings as the instrument cluster, i wanted to avoid stripping down the wires from the PE insulation as those are hard to come by where am from but it looks like the problem might possibly lie within a faulty ground cable, I'll check the wiring diagrams, strip down the cables and test them properly and I'll let you all know what i found.
Old Oct 27, 2022 | 10:54 AM
Wail,
later I'll retrieve the location for all ECM W common ground locations and check them one by one, i'm starting to believe it is infact a grounding issue according to the diagram the Z7/43 connector sleeve supply ground to the ECT, CPS and the intake air temperature sensor, from time to time the ecm actually throws some CPS voltage errors, the issue might lie within a faulty ground from the W common Grounds, or the Z7/43 Connector sleeve, or even the wire supplying ground from the ECM pin 33 to the connector sleeve Z7/43, but i am more inclined to an issue within the W common ground because the AAT sensor is connected to front sam not the ECM so it has to be a specific W ground point supplying both the ECM and the Front sam and accordingly affecting both AAT and ECT grounds. By the way did have luck finding the AC water drain points on the w212, I'm truly curious about their condition since i don't see any water dripping from the vehicle.
Old Oct 27, 2022 | 11:31 AM
S-Prihadi's Avatar
The HVAC drain hoses, 2 of them and above the tranny tunnel
If you want to get more water out from HVAC system do a sudden braking, even at low speed and more water will ooze out.
Or jump accelerate or use brake torque to dance the car rear suspension, more water from HVAC will ooze out.
This is the LEFT side one, in green. The two hoses are not of equal height, do note.
LEFT SIDE ONE
RIGHT SIDE ONE, higher
ADD, close up view
SOURCE OF THE HOSES AT HVAC ASSY- Suposedly from W212 E350
The hoses, this is from E550 W212. See one is taller.
Old Oct 27, 2022 | 11:38 AM
S-Prihadi's Avatar
Well, my W212 ground if for engine bay and the MAIN ONE for engine starter/block, I cleaned them all already and they are beefed up too and also for ECM
The trunk one also done, cleaned and tigtened and marked. Any red line marker on my car bolt/stud/nut, that is my doing.
Interior ones I have not done anything to it. Cali have done a lot of his interior ground points.
My grounding points work : https://mbworld.org/forums/e-class-w...ving-them.html
The follow up of the grounding thingys is ..........
For alternator superb charging algo, solution is KILL the LIN connection to it and let alternator work its own magic using its own charge controller and not by stupid ECM charging algo.
Old Oct 27, 2022 | 12:31 PM
S-Prihadi's Avatar
Wail,
Since I done some work on my friend's M271.8 EVO, here is what I have in my archive which may save you time.
ECM FUSES ASSIGNMENT
Fuse 6 (10A) >> Engine computer, connector F (body side ) pin 15
This circuit 15 is power feed (relay's pin 30) for Relay M, engine crank
Fuse 22, 23,24 & 25 via relay N, is also circuit 87M
Fuse 22 (15A) >>> M4/7 cooling fan
Fuse 22 >>> X26 pin 5 >> Z7/36z1 & Z7/36z2
Z7/36z1 >> R39/2 full load operation vent line heater element if march 2011 ---NOPE
Z7/36z1 >> Y49/2 exhaust camshaft solenoid
Z7/36z1 >> Y49/1 intake camshaft solenoid
Z7/36z1 >> G3/2 oxygen sensor upstream of CAT
- Z7/36z2 >> B6/16 exhaust camshaft hall sensor
- Z7/36z2 >> G3/1 oxygen sensor downstream of CAT
- Z7/36z2 >> Y31/5 Boost pressure control pressure transducer ( solenoid)
- Z7/36z2 >> R48 Coolant thermostat heating element
- Z7/36z2 >> Y101 Divert air switchover valve
- Z7/36z2 >> Y16/2 Heating system shut off valve
Fuse 23 (20A) >>> X26 pin 4 >>> Z7/5
Z7/5 >> Y94 Quantity control valve >>
Z7/5 >>> B6/15 intake camshaft hall sensor
Fuse 24 (15A) >>> X26 pin 2 >>> Z7/35z2
Z7/35z2 >> to all 4 ignition coils ( T1/1 to T1/4 ) pin 1 ( power )
Fuse 25 (15A) >> Engine Computer , connector F (body side ) pin 3.
Fuse 27 (7.5A) >> Engine Computer , connector F (body side ) pin 16. 30z special.
***Sensors/component direct from Engine Computer**
Connector M ( engine side ) pin 33 >> Z7/43
Z7/43 >> B17/8 Charge air temperature sensor ( intake air after aftercooler )
Z7/43 >> B11/4 Coolant temperature sensor
Z7/43 >> B70 Crankshaft hall sensor ( the other pin from Z27/41 connection )
Connector M ( engine side ) pin 68 >> Z7/41
Z7/41 >> B70 Crankshaft hall sensor ( the other pin uses Z27/43 connection )
Z7/41 >> M59 Intake manifold swirl flap actuator motor ( 1 other pin from Z7/43 )
Z7/41 >> B28/15 Pressure sensor upstream of compressor impeller
Z7/41 >> B4/6 Rail pressure sensor ( HP fuel pump rail )
Z7/41 >> B28/7 Pressure sensor downstream of throttle valve ( 1 other pin from Z7/44 )
Z7/41 >> B28/6 Pressure sensor upstream of throttle valve ( 1 other pin from Z7/44 )
Connector M ( engine side ) pin 53 >> Z6/8
Z6/8 >> B6/15 intake camshaft hall sensor
Z6/8 >> B6/16 B6/16 exhaust camshaft hall sensor ( 1 other pin from Z7/36z2 fuse 22 )
Connector M ( engine side ) pin 95 >> Z7/35z1
Z7/35z1 >> Y76/1 Fuel injector Cyl 1
Z7/35z1 >> Y76/4 Fuel injector Cyl 4
Connector M ( engine side ) pin 94 >> Z7/35z3
Z7/35z3 >> Y76/2 Fuel injector Cyl 2
Z7/35z3 >> Y76/3 Fuel injector Cyl 3
Accelerator Pedal. 5 wires
I hope the Z7/43 splice is not at the part where the engine wire harness is rubber molded.
I was looking for the capacitor and I could not find it, it is inside the freakin' rubber moulding of wire harness
I was looking for this capacitor......... the C4
If the M271 non turbo, below is the C4 location.
Old Oct 28, 2022 | 07:21 AM
HVAC Actuators....
bottom Left
Bottom Right
FYI: these HVAC actuators are solderless! The HVAC core unit uses 7 or 8 of them, all identical part.
8x tiny connections to feed stop/go torque
dry gearset actuator opened
Old Oct 28, 2022 | 09:17 AM
S-Prihadi's Avatar
U itchy hand you Cali
Old Mar 17, 2023 | 07:45 PM
Hello all,
first of i’d like to thank all of you for participating in this thread, and sorry i took so long to respond I’ve been dealing with this intermittent issue and i still i am, but i think i got to the bottom of it,
i’ve tested all the wires for the ECT and ambient Temperature sensor and the ECM ground wires, as well as every ground wire available in the wiring the diagram, checked all sensor connectors for signs of oil, I’ve even went as far as replacing the ecm and sensors but still haven’t solved this issue.
the only thing I’ve noticed is upon wiggling the female connector for the ecm, it causes the issue to disappear for a couple of weeks, i am starting to think that the issue lies within the ECM’s female connector. I will have this female connector replaced and re-pinned. As i think it is the culprit.
upon completion of replacement I’ll let you all know what happened.
Old Mar 18, 2023 | 09:53 AM
S-Prihadi's Avatar
Well, I did mention similar problem I had, back then...........post #4
Old Mar 18, 2023 | 10:04 AM
Yes, I’ve seen the post, if not for you I wouldn’t have even considered it (i never would have thought that these male female connectors might have an insertion cycle you’re a genius and a life saver i truly appreciate your assistance) , i went and searched for your thread, to figure out how to re-virginize (in love with the term&#128514 the female connector.
Old Mar 18, 2023 | 10:38 AM
S-Prihadi's Avatar
You best re-confirm first what actually is the problem :
01. Poor fit of female terminal
0r
02. Corrossion at the cable core mid way, its broken but still toucing.
Shaking test can produce result, I mean the negative result you are looking for even for condition 02.
For 01 it is easy, you buy the male terminal of the correct version/size and test its friction.
Buy from here is one possibility. I bought a lot from them : https://www.automotive-connectors.co...=2&q=+terminal
I also bought from here : https://www.finjector.com/eng/search...%25201.2&t=all
For 02 a loaded 3 amps test would be good enough for 0.5mm cable and 1 to 1.5mm cable you test 5 amps and bigger cable 2.5mm one you test at 10 amps. Each test 30 seconds is good enough.
While doing so, "massage" and shake the cable. This is lots of work as you need male terminals suitable for the other end of the cable too and accessing them.
Becareful when doing 02, as this is injecting power be it +12V or -12V, so all sensor/devices at the other end of the cable has to be disconnected and car battery disconnected too, surely ECM has to be disconnected too.
Example what I bought and I am not done yet actually.
I basically tried to buy many types as I do note exactly know what my W212 uses , until I de-pin some. Even WIS/EPC is not say very helpful at female terminal level.
I even buy some from MB Indonesia a few each so that I can measure and see how they look like :A003 982 73 26 terminal female, 0.75 - 1mm, MLK 1.2
A003 982 70 26 terminal female, 0.5mm, MLK 1.2
A048 545 03 28 terminal MALE, 0.75 - 1mm, MLK 1.2
A014 545 25 26 terminal female, MQS
A013 545 44 26 terminal female, MQS, 0.5-0.75mm
A041 545 28 28 terminal MALE, MQS, 0.5-0.75mm
A009 545 81 26 terminal female, SLK 2.8, 0.75-1mm
A009 545 82 26 terminal female, SLK 2.8, 1.5 to 2mm
A013 545 16 26 terminal female, SLK 2.8, 0.75-1mm
A035 545 73 28 terminal MALE, SLK 2.8, 0.75-1mm
A000 540 39 05 SLK 2.8, Cable kit with Female and Male terminal 1mm
