Sponsored by: CARiD
Starter life expectancy
Old Nov 1, 2022 | 12:05 PM
corsair944's Avatar
2015 C63 Coupe
Hi,
What life is everyone seeing out of your starters? I have my daughters 2013 E350 pretty much disassembled on the left side of the engine and the starter looks pretty original. As much trouble as it looks to get back in there, should i replace now as "preventive maintenance"
Thanks everyone
Old Nov 1, 2022 | 12:11 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
pretty good units!
Originally Posted by corsair944
Hi,
Thanks everyone
The starter guts are solid but the brushes are extra soft carbon that wears short - Change the brushes.
As far as life span, it directly depends on driving habits city/hwy, ECO stops... In general these starters are not bad troublemakers.
Old Nov 1, 2022 | 01:23 PM
Fliplegend's Avatar
S212 E350 Estate
Hi,
Thanks everyone
The starters for cars with the start/stop feature are built robust but as you already mentioned, you are already there and it's in a tight place so personally, I would replace it. While you are in there, you may as well do the motor mounts.
Old Nov 1, 2022 | 02:17 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
The only starter I had to replace on MB was 1998 SL500 at 196,000 miles.
Replacing the brushes would be good maintenance, but good luck finding supplier for them.
You don't have ECO shutdowns?
Suppose starters for those engines are 8x stronger than for 1 without the option. Mine with ECO is at 150k miles still turning strong.
Old Nov 1, 2022 | 02:23 PM
corsair944's Avatar
2015 C63 Coupe
I already got new motor mounts, thats why Im so far into it. still debating on the starter
Old Nov 2, 2022 | 07:58 AM
Fliplegend's Avatar
S212 E350 Estate
If it was fine before and you are debating, forego the replacement. You already know how to get to it so IF you need to get back in there, it should be much faster.
Old Nov 2, 2022 | 08:25 AM
DFWdude's Avatar
2016 E350 Sport
There have been very few threads here regarding starters, so I think they are likely good for the lifetime of the average car (under 200K miles).
The electric starter in my 2001 C-Class is still going strong after 169,000 miles.
Old Nov 3, 2022 | 04:09 AM
ygmn's Avatar
2015 E400 Sedan
remove it and go get it tested as a minimum at local auto parts store
Per owner's manual and the DUMB ECO thingy
MB says starters are now more robust and designed for all the starts they would do using ECO STOP/START
