2010 e350 M272 coolant hose concern
Are these hoses healthy or are they due to be replaced? Are they even the correct ones? I find it weird that they are skinny at certain angles. My gut feeling tells me something is odd but perhaps this is a MB design.
Thanks in advance.
This hose isn't showing the depression that is visible in your hose.
This hose looks similar.
I forgot to mention the mileage - 108K. I hooked up my Autel MK808 and looked at the service history that was documented in the ECU.
I need more time to study the maintenance history. I did find many entries. I am mainly looking to see if the transmission fluid was changed. I have a slipping 1st to 2nd gear when driving slow or using the shift paddles. Not so much when I give it some throttle. Anyways, another thread for this issue. I do see lots of transmission issues related to solenoids.
Figure 1 pan would require red fluid
Figure 2 pan would require blue fluid
I will take a look under the car and call the dealer to cross reference.
I know the TCM - solenoids and some other parts tend to go bad. You end up having to replace or repair it. I just hope it ends up being something like components rather than having to replace the entire trans.
Going back to the coolant hoses. I notice mine is pretty much touching the oil cooler. Do you have a plate between or is the hose stiff enough that it doesn’t flex onto the cooler?
Does the temperature stay at a good level while driving? It should hover around 90* C
