Rear sub-frame rusting/rotting
pierrejoliat (01-16-2023)
oh, FYI, your car is a 212.088, so places where it says stuff like... "Model 212 (except 212.074/075/076/077/092/274/275/276/277/292)" would apply (since 088 isn't listed).
I do wish I knew where there was a table clarifying what all the submodels of 212 are... there's a LOT. For example, my wife's facelift 4matic wagon is a 212.288 (and, I believe, 212.2xx are all wagons).
The following 2 users liked this post by Left Coast Geek:
CaliBenzDriver (01-17-2023),
pierrejoliat (01-18-2023)
Received 1,546 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
https://oil-change.info/mercedes-ben...-oil-capacity/
Alternatively, looking at the menu selection from XEntry, there is a list of all models under a given designation.
The following 2 users liked this post by juanmor40:
#32
This is the parts list my mechanic got from Mercedes to replace the rear subframe on 2012 w212 E350 sedan 4Matic Sport package. The prices are Mercedes shop/wholesale prices from my dealership.
207-350-97-02 Cross-Member 1x $1,215.00
205-352-07-00-64 Stop Plate 1x $12.15
205-352-08-00-64 Stop Plate 1x $12.15
001-990-11-03 Suspension Cross-Member Bolt 4x $10.26
000000-004723-64 Hexalobular Bolt 2x $2.43
001-990-66-03-65 Screw With Feature 2x $3.11
230-990-00-40 Front Cross-Member Washer 2x $1.89
000000-008268-64 Suspension Control Arm Nut 1x $2.97
000000-008269-65 Nut 10x $2.03
002-990-62-54 Drive Shaft Nut 3x $2.16
000-490-13-41 Exhaust Clamp 2x $17.39
204-492-00-81 Catalytic Converter Gasket 1x $16.88
Subtotal: $1,376.61
Subtotal: $1,376.61
#33
Received 4,295 Likes
2014 - W212 - E400 ( M276.820, 3 liter Turbo) RWD not Hybrid
Long time ago I looked at the documents for changing those 4 bushings and I still can't really understand 25.1 amd 25.2 : I marked red
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1156/d1_65cf7cfe77a5bb39ed4af6934bbfe9f8117e98c8.jpg)
Anyone care to explain ?
To me it sounds like welding new blank thread bore is a must and the bolts are like self tapping ones which create its own thread.
Or the meaning of RE-CUT is like below ?
https://www.autoserviceprofessional....g-benz-warning
https://mbworld.org/forums/attachmen...king-bolts.pdf
pierrejoliat (01-26-2023)
#34
They just mean you need to run a tap through the bolt hole to clean out the old thread sealer from the factory bolts. I did it this past weekend and not a big deal to do at all but certainly did clean out the derbies in the threads. I just used a M12 x 1.5 tap to clean up the threads in the bolt holes.
The following 2 users liked this post by Jim Ma:
Baltistyle (03-26-2023),
S-Prihadi (01-26-2023)
#35
Sweet, thanks.
In my language if I translate it from English, sounds not like bore cleaning with TAP.![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Thanks for clarification.
#36
Received 1,488 Likes
Subtotal: $1,376.61
Subtotal: $1,376.61
https://www.ebay.com/itm/363630400365
#37
Looks like a popular item on eBay, an aftermarket one seems to be in the $780 range and it fits other cars too like the C class. Could probably find one in a junkyard in a southern or western state with no rust.
hahahaha, I love those 'badges' on the add. Wow, "PROFESSIONAL SELLER"
yeah, i'm going to trust off brand aftermarket chinese steel under my rear suspension, sure.
#38
#39
The warranty on rear subframes has been extended to 20 years. Call Mercedes-Benz USA with your Vin number. You may get a pleasant surprise.
Raj1471 (04-27-2023)
#40
Thanks for the post. Just got the car back from the dealer with the rear subframe replaced under warranty. Got lucky that the dealer was able to get the subframe (believe it is backordered). Found out about the extended warranty by chance when I called the dealer to get a quote and was told that my VIN had the extended warranty on the subframe. MB not really advertising the extended warranty as I did not get any communication from them! Now on to the corroding rear hydraulic brake lines! The fun never stops with the W212s!
#41
Hi. Do you know if this corrosion could cause water to get into the floor of the car? I have a situation where the floor behind the driver's seat has twice now filled with water about 1/2 way up. No water is dripping down from anywhere, and the Mercedes Dealership is telling me that it will cost over $8,000 to fix it (event though they don't know what the problem is yet) or if I submit to my insurance, they will say it's "totaled." It's a 2012 in excellent condition with only 50,000 miles. It happened after driving in the Southern California rains, but I didn't drive through any flooded areas -- just normal water on the roads. Any help is appreciated!
#42
ccryan67 (04-01-2023)
#43
https://mbworld.org/forums/e-class-w...ain-plugs.html
https://mbworld.org/forums/e-class-w...6-e-class.html
https://mbworld.org/forums/e-class-w...ak-points.html
#44
Hi, very sorry to hear about your situation. However, don’t think the rotting subframe is the culprit. Not saying no in absolute terms but very unlikely based on my understanding of the subframe situation. Have they removed the carpets to see if there are any hole in the car floor thru which the water is coming? Are the seats dry? Did it happen one time or happens all the time driving in the rain? Just behind the driver side or both sides of the passenger area? Rear doors properly sealed? And is the moonroof properly sealed? Keep us posted on what you find out.
#45
An example, all recent MB are designed similarly
Is the front footwelll wet as well? Or dry? If dry. I will check B pillar and headliner for wet spots. Still dry? Check door seals are not worn, dried and allow water in.
I do not recall if the W212 has drainage on the floor, usually with a rubber groomet. anyone has seen the floor w/o the carpets?
#46
Thank you for responding. They want to charge $8,000+ to remove the carpet and seats to "find the problem." Yes, it happened once before in March 2022 -- same exact problem, same place, only the well behind the driver's seat & not up on the seat. Seats are dry. NO sign either time of any water dripping down from anywhere. All seals are fine. The Dealer says the car is "totaled" because there are computers and wiring under the carpet area that could be damaged. In March, 2022, they just dried it and said they couldn't find any problems. My insurance is saying it's totaled too for the same reason. I'm distraught because the car is in excellent condition and only has 50,000 miles on it and I just put 4 new tires on it last year. I was wondering if I should take it to another Mercedes dealer and have them replace the subfloor AND ANY OTHER DAMAGE IT MAY HAVE CAUSED. If it corroded underneath, could it cause water to pool in this area? Any suggestions are welcomed! I also noticed that other Mercedes models (324,000 of them) are being recalled for water accumulating in the spare tire wheel wells and causing damage to the fuel pump control units. Could this be related?? Is the spare tire wheel well on the left side of the car? I'd check, but my insurance has taken the car.
the spare well on our E350 wagon is centered under the floor of the trunk and I believe the E350 sedans are the same.
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/1280x960/i_pnkcqqn_x2_06087f77f67128c55ed482464664927d2ab2ffba.jpg)
You mentioned a C350, I'm not sure what those are like.
Deborah C (04-01-2023)
#47
I was just informed that my car will not pass PA State Inspection because of this problem. I company that inspected my car spoke with the local MB Parts Manager's and "'it's supposed to be covered by MB Extended Warranty (based on product VIN)". I have an appointment with MB to correct this issue. I'm trying to find out more about this issue, is the complete repair covered by this Extended Warranty or just the part(s) involved.
#49
Thanks I hope so.
My car will no longer pass PA State Inspection. I just spent $1,775 to get my car Inspection and had to get for 2 new tires, new front brakes, pads and rotors, oil change, etc. I was informed that based on my VIN, it is covered by an Extended Warranty, and I have an appointment to get it repaired.
#50
Thanks I hope so.
jhopper9 (06-12-2023)
