Sponsored by: CARiD
AC not cooling: P064515: The output for the magnetic clutch of the air
Old Apr 24, 2026 | 06:56 PM
  #51
invictus 23's Avatar
s204
Originally Posted by JCM_MB
Well, if the resistance is infinite, i.e. open circuit, the magnet is toast. Have you seen the magnet replacement on sale anywhere? The one I used should be similar, but I have never worked on that specific pulley. Not certain the diameter would be same as the one I used.
Yes i have found the replacement but whats its strange to me is that i dont have neither incoming voltage to the connector.
What can it be ?
Old Apr 25, 2026 | 04:43 PM
  #52
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Why Is This...
What can it be ?
Be aware the SAM Module is smart enough to shut down line controls if it senses "no load" open circuit.
It is unlikely you have both an open electromagnetic clutch *AND* a bad line driver (mosfet or relay).
> TESTING...
-- Use the scanner to energize your clutch coil
-- Use a test light bulb to load the coil circuit to let SAM activate it.
This test should help you confirm only your clutch coil is bad, right?
