Sponsored by: CARiD
Coolant MB SPEC for Class 2014 / 212.080 / M276.952
Old Apr 18, 2023 | 04:55 AM
michaelyjko's Avatar
E300 M276
Hello,
Coolant MB SPEC for E Class 2014 / 212.080 / M276.952
I hear MB325.6 (not 325.0) applies to those with build date of May 2014 and thereafter.
I am very confused because I don't know the build date. Couldn't find the info on any stickers on the car! I only know delivery date (July 23, 2014)
Vin decoder doesn't provide the info.
How can I be sure about the coolant spec?
Thank you!!
Michael
Old Apr 18, 2023 | 12:41 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
YLW...BLU
Originally Posted by michaelyjko
Hello,
Thank you!!
Michael
Your OEM coolant is either Yellow/Gold or Blue/Turquoise color.
Both are nearly identical chemistry with no significant difference or advantage. The best coolant chemistry is silicone based but it's not compatible with these cars.
Look at what's in use now, reuse the same either Ylw or Blu. Hopefully no one used the old Green stuff on your engine.
Old Apr 18, 2023 | 05:27 PM
E300 M276
Thank you for your help.
Old Apr 19, 2023 | 10:27 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Also should be listed in your owners manual
Old Apr 19, 2023 | 10:36 PM
E300 M276
https://operatingfluids.mercedes-ben...sheet/310.1/en
It says - Backward compatibility only; Products from 325.0/326.0 are not allowed in vehicles produced after 04/2014
So I think 325.6 is a safer choice?
Old Apr 20, 2023 | 12:31 AM
konigstiger's Avatar
'71 Pinto
Provide VIN.
https://operatingfluids.mercedes-ben...sheet/320.1/en
325.6 Antifreeze or 326.6 Premixed
https://operatingfluids.mercedes-benz.com/sheet/325.6/en
https://operatingfluids.mercedes-benz.com/sheet/326.6/en
Old Apr 20, 2023 | 12:33 AM
E300 M276
Vin-WDDHF8BB0EB071313
Thank you!
Old Apr 20, 2023 | 09:12 AM
Look in your door jamb drivers side for build date, if before 4-2014, blue, if 5-2014, Pink. Looks like they changed it in the last 2-3 months of production of the '14 models
Old Apr 20, 2023 | 09:18 AM
chassis's Avatar
2017 GLE350 4MATIC
Thank you!
Ignore color recommendations. MB spec from the operating fluids site is definitive.
Old Apr 20, 2023 | 09:21 AM
Old Apr 20, 2023 | 10:47 AM
'71 Pinto
File Type: pdf
