Sponsored by: CARiD
2011 E550 OEM left intake tube
Old May 5, 2023 | 10:01 AM
Sashki81's Avatar
2011 Mercedes E550 4-Matic
Does anyone know where I can find part #2730902582 it’s for a left OEM air intake tube? I know there are many aftermarket ones available on eBay and Amazon but they don’t quite fit well it’s a bit too short. Any advice or recommendations would be much appreciated. My left one ripped so I need to replace it or fix it. Any suggestions guys?
Old May 5, 2023 | 05:40 PM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Have you tried FCP Euro? I and others here highly recommend them. Their lifetime warranty on pretty much all of their parts is incredible. I just received an email from Pelican Parts and apparently they are adapting FCP Euro's business model of lifetime warranty as well.
Old May 6, 2023 | 10:42 AM
Sashki81's Avatar
I haven’t but I will check them out. From what I heard they’re pretty pricey.
Old May 6, 2023 | 10:48 AM
PeterUbers's Avatar
https://a.co/d/3lYfsUq
use this
discussed here:
https://mbworld.org/forums/w212-amg/...pipe-m157.html
Old May 6, 2023 | 11:22 AM
Sashki81's Avatar
The link you provided doesn’t work
Old May 6, 2023 | 02:14 PM
PeterUbers's Avatar
fixed
Old May 6, 2023 | 02:35 PM
Sashki81's Avatar
Great, thank you! And that would work just fine?
Old May 6, 2023 | 03:08 PM
PeterUbers's Avatar
Just measure your tubes and make sure it'll fit / as in the thread I referenced people seem to say it works well. You may need some type of all purpose adhesive to secure both ends (Loctite adhesive, high temp silicone etc)
Old May 6, 2023 | 03:27 PM
Sashki81's Avatar
Perfect! What about just buying an aftermarket ones off of Amazon or eBay? Would you recommend a little less seem to work for some people from what I heard they’re just a little shorter than the OEM
Old May 6, 2023 | 03:40 PM
PeterUbers's Avatar
Something like this may help the length issue
contact the seller before purchasing to confirm it'll fit or check measurements
https://a.co/d/2aXzs9n
Old May 6, 2023 | 05:01 PM
Sashki81's Avatar
Well I purchased this one from Amazon and it was a little too short. How could I tell if the one you’re mentioning is longer? Btw here is the link to the one I purchased. Thanks for your help by the way.
Air Intake Duct Hose 2720903582 Replacement for Mercedes-Benz W204 A207 C207 S212 V212 W212, Shroud To Air Filter Housing (Left + Right) https://a.co/d/6bcWYy1
Old May 6, 2023 | 05:04 PM
PeterUbers's Avatar
this was too short despite the accordion style extensions?
Old May 9, 2023 | 11:11 AM
Cos215's Avatar
E550
Hey I've gotten the left one from Auto Haus before:
https://www.autohausaz.com/pn/UR-2720903582
Old Jan 29, 2024 | 12:18 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Look for 2nd hand ones of a W164 ML..They are all plastic and don't have the fabric component that typically tears. V6 and V8 lengths may vary. My ML has 170km.on it and they will last the lifetime of the car. A real lifetime, not a Mercedes "lifetime".
Old Jan 29, 2024 | 01:06 AM
Sashki81's Avatar
@BlackML550 will that one fit my vehicle even tho it’s for a completely different model? I have the 2011 Mercedes E550 4 Matic. Thanks!
Old Jan 29, 2024 | 01:20 AM
BlackML550's Avatar
You should google images of the w164 ML550 (2006 to 2011) airbox or engine bay. The air box will probably be the same as yours as should be the distance to the front radiator support. The intake may be different, but you might be able to match them up with your original ones. Some image searching will allow you to see any differences.
Also look at what Rock Auto has available https://www.rockauto.com/en/catalog/...ke+hose,6344le
W164 ML550 engine bay below
