W212 HID Low Beam Issue
Hoping I can get some advice from experienced indy and/or owners. 2011 W212 4Matic, with active headlights.
Recently I realized that my passenger side lowbeam/high beam stopped working. Symptoms I have found so far:
1) every time I start the car, the HID turns on; it turns off after a short time
2) no error message on the dashboard
3) replaced HID bulb, no change
4) had a shop looked at it, they thought it was because my actuators were failing and not keeping the headlight at low beam, therefore somehow the system turns off the headlight to avoid hurting other people's eyes...the thing is that when I start the car, I can see the headlight "calibrating" itself, the the passenger side beam does do "extra movement" to bring the light to the driver side level
I thought it was the ballast failing, but the shop told me otherwise. wondering if anyone can share some experience and provide advise. A new headlight assembly is VERY expensive as you probably know, trying to see if I can avoid that.
Thank you in advance.
Otherwise, its not easy to troubleshoot.
They thought or they see the data from a scanner ?
Not always issue has DTC or trigger a DTC
Below has ZERO update fee :
A decent MB only scanner like this one :https://mbworld.org/forums/e-class-w...onal-more.html
or all brand scanner this one :https://mbworld.org/forums/e-class-w...tool-a30m.html
Is what you need.
Is what you need.
212-820-12-39 Headlamp Assembly, Right
Right. E350. Without night vision sys.. To 12/2/10. E550. E400 hybrid. Without E63 AMG with bi-xenon lamps.
212-820-16-39-64 Headlamp Assembly, Right
With bi-xenon. Right. E350. With night vision sys.. To 12/2/10. E550. E400 hybrid. Without E63 AMG with night vison.212-820-96-61 Headlamp Assembly, Right
E350, e350 bluetec, e550. Right. Without e63 amg, without bi-xenon lamps.
I would think my car falls into the "with bi-xenon" category but without the night vision, so it should be the 1239 part number. However the 1239 part number has been discontinued...searching on ebay or other places, they have different part numbers and/or with "AFS".
So I have two questions that I hope someone can help me:
1. is the AFS what I have? Is it the same as "Adaptive Headlight"? My headlight does go up/down/left/right base on my steer wheel input
2. searching ebay they have bi-xenon part numbers like 2128202259, 2128206061, will these work?
Is there any more economical alternatives than replacing the entire headlamp assembly?
On ebay, there are a several different P/Ns that they claim would fit for 2010-2013 model. Do I have to replace with the exact P/N or any P/N that is for 2010-2013 model would work? Are all Xenon models with the actuators?
Thank you
Thank you
I am wondering if there is a place where I can crosscheck all the Mercedes part numbers? I called the dealer, they would not tell me what are the part numbers that would fit my car (of course, not surprised)
There is one on ebay with P/N 212-820-7259 that is supposedly fits the model year, it looks genuine, but I googled up and down, no result with that part number anywhere. I googled my current part number, 212-820-6061, a couple of places came up, at least it is recognized.
Very confusing when not able to confirm the part details with part number.
Says it supercedes your part number, so get this part number and you'll be good with programming
212-820-12-39, 212-820-30-59, 212-820-43-61
nothing related to the P/Ns I have.
maybe I am missing something?
Also AFS is just cornering lamps , Adaptive Frontlight System
