Sponsored by: CARiD
W212 Reversing Not Poss, consult workshop
Old Nov 19, 2023 | 03:45 PM
omar.shak's Avatar
Mercedes E300 Blutechybrid 2014
Exclamation W212 Reversing Not Poss, consult workshop
Hello guys, i have mercedes e300 blutechybrid,
Every morning the error ( Reversing Not Poss, consult workshop ) was appear,
Gearbox goes to D \ P smoothly, but when i set to ( R ) it still goes to ( N ) AND i try 2nd and 3rd times till it goes to ( R )
any solutions !?
Old Nov 19, 2023 | 06:12 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W212 forum...
Old Nov 19, 2023 | 07:34 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
As always, start with the codes that are present. Whatcha got?
Old Nov 20, 2023 | 12:52 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
PRND shifting chaos
ISM related?
what's current mileage?
Old Nov 20, 2023 | 02:10 AM
Omar.sh's Avatar
Mercedes Benz E300 bluetech hybrid
current millage : 180,000 KM
Old Nov 20, 2023 | 02:25 AM
Either you are able to scan your car for fault codes
or drop it at MB specialist for diagnosis
95% chance ISM shifter is involved.
Old Nov 20, 2023 | 07:32 AM
Omar.sh's Avatar
thanks friend, but what about gearbox transmission conductor plate 1?
is it cause the error !?
Old Nov 20, 2023 | 10:30 AM
S-Prihadi's Avatar
Sure it can be also the problem, because the solenoids and valves which can make REVERSE gear and clutch engage is at the Valve Body + Conductor Plate Combo.
Usually the conductor plate is the one to go first...because it is electronic.
Get a proper scanner and report DTC
