Sponsored by: CARiD
Strange sound from the back of the car
Old Jan 15, 2024 | 02:43 AM
keeepwalking's Avatar
w202, w212
Hi, everyone. My car is w212 with m272 engine, 4 matik. I force the engine a little and release the gas pedal quickly. I hear a knock sound from the back of the car. The car is at "P". Does somebody know what can be the problem? Here is a video (at the 15th second).
Old Jan 15, 2024 | 01:24 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
goodness
I listened to your video twice: it sounds rather good
Now you're going to need to SCAN you car instead of listening to its engine.
Old Jan 15, 2024 | 05:50 PM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Same as what @CaliBenzDriver said...I don't hear anything...
Old Jan 15, 2024 | 06:18 PM
shortcut!
my first thoughts were even my GDI does not sound that good with its own rattling orchestra.
If this is engine has a "balance shaft"... question the chain tensioner prior to balance shaft looseness. This will help absorb chain slack to remove freeplay.
FORGET about the high cost of pulling the engine out to replace old shaft.
Old Jan 15, 2024 | 10:26 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I do hear the knock at about 16" ... Sounds like someone tapping a metal pipe with a ball peen hammer, or like something settling back into place after engine torque is released.
How are your transmission mounts?
Old Jan 16, 2024 | 02:05 AM
w202, w212
That description is exactly how it sounds. It comes not from the engine (I am pretty sure about that). I hear it from the back. The engine and the transmission mounts are new and the car has not got any vibrations at all.
Old Jan 16, 2024 | 02:36 AM
S-Prihadi's Avatar
How old + mileage and sagging is the 4 pcs exhaust rubber hangers ?
This type : https://www.fcpeuro.com/products/mer...mer-2034920444
Old Jan 16, 2024 | 02:51 AM
w202, w212
I should check them. The car is 2010.
Old Jan 16, 2024 | 02:56 AM
S-Prihadi's Avatar
Also there are 2+2 bolts securing the CAT. Which if on my engine, the mounting point is to CAT welded L-plate towards the tranny.
Check if those bolts loose or lost.
ADD IMAGE
When the 2 engine mounts are replaced, usually the exhaust need to be removed* ( *for my engine ). so maybe these 2 + 2 bolts were not tight or whatever.
Old Jan 16, 2024 | 09:31 AM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
MB has a 20 year (yes, 20 year) warranty on the suspension sub-frame in the rear due to corrosion issues. Probably not related, but dealerships are supposed to check it out for you and repair or replace.
Or could it be a body?
Old Jan 16, 2024 | 11:36 AM
JettaRed's Avatar
Veteran: Army
I think I heard, "Let me out! Let me out! Help! Somebody help me!"
You need to run the sound through a signal processor and filter out the car noise.
Old Jan 16, 2024 | 03:54 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
I might suggest getting it up on a lift and with someone standing underneath to pinpoint that noise
