MB OEM Battery
Received 3,448 Likes
MY'14 W212 M276 3.5NA @60kMi
good voltage
The more complex 12.6V float-voltage control system doesn't save significant amount of gas to make up for its complexity.
A fully charged battery under 14.4V uses the same current load as under 12.6V... zero amp, no load.
Anyway this complexity is here to stay:
- 14.9V deceleration high-charge
- 14.4V bulk charge rate
- 13.7V absorption rate
- 12.6V float rate
Above numbers are all perfectly good voltages associated with the different battery charge level.
Any deeping below 12.3V is a disfunction that drain while-driving extreme conditions.
The following 3 users liked this post by CaliBenzDriver:
Received 1,128 Likes
12 E350 4Matic 13 E350 4Matic AMG Sport
Yes Cali, I should have identified the author of the encyclopedia, LOL
The following 2 users liked this post by pierrejoliat:
CaliBenzDriver (02-26-2024),
redaotrosh (02-28-2024)
power tips
-- The ECU quickly bulk charges MAIN Batt to 80% with burst of 14.9V
-- then all the way to 100% fully charged with normal legacy style voltage 14.4V, 13.7V the way it used to be without smart charging.
-- then 12.6V float voltage to hold charge while supplying 100% of every electrical loads.
Great! All of that is the perfect way it's supposed to work.
However battery and chassis power are wired to help disrupt modules with noisy power.
> POOR ENGINE - CHASSIS STRAP:
While in this topic, you get to understand how there can be two strong power sources:
ALT (engine) and the Batt (chassis).
When the single chassis strap is oxidized by road projections the chassis load can no longer see ALT as a source and only see BATT as source.
OMG... BAD NEWS!
You may be reading this thinking what do I care?? Keep it in the back of your memory somewhere!
Personally I remember Master Surya at some point dealing with his GND with fat *** cables... but did not hit home why I would be doing that later myself.
Rule No1: everything Master Surya touches in depth is Golden. I really think we need an Index
WHY: the oxidized strap offer enough drop voltage under load to make the battery become a better supplier over ALT minus dropped voltage caused by our favorite poor GND strap.
If you are dealing with marginal battery performance... Install a SECONDARY GND STRAP!
It is cheap easy way to sanitize weird power glitches and tired batteries issues. No code
> BATT SENSOR:
-- The battery negative terminal has a smart sensor that measures the battery internal heat in addition to voltage and current.
-- The temperature is used to slow down charging rate in case the battery is overheating. Legacy charge circuit used to not have this data.
The following 2 users liked this post by CaliBenzDriver:
pierrejoliat (02-26-2024),
