2016 W212 E350, Bilstein B6 Upgrade.
I am on my 28th vehicle and I have had Bilsteins on numerous cars, they have never let me down. So this past week I ordered Bilstein B6 all around. TLDR: Night and day difference. Big bumps, small bumps, washboard, dips, driveways, you name it, huge improvement. Now it basically rides about 95% as firm as my 330e, about 50% of people might say the 330e ride is too firm. Which brings me to this: If you are the type who values comfort above all else, I would go with the B4's that are quite a bit more forgiving. However, if you are like me and place a priority on ride composure and controlled handling, then you will be happy with the B6's. These shocks have fixed the most glaring flaw on my E350.
The '85 300D was riding on a cloud and had the (lack of) handling to go with it.
The '05 E320CDI was nice n tight.
I found my '13 E350 to be sporty enough.
Moving into my ML350 showed me just how stiff the E suspension is. The ML clearly ain't no sports car.
I started with B4 all around.
I would not want B6 on my front for my road. Thus I tried B6 at the rear first to feel how it is. https://mbworld.org/forums/e-class-w...gine-data.html
My wheel is 18" only, standard size, not 19" or insane 20".
I like a more tied-down ride and the stock E-Class is not exactly that way. I'm not sure how much of the mushiness (especially in front rebound) I'm feeling is worn shocks and how much of it is just the way the stock tuning is set up. It would suck to get new stock replacements (like B4s) and find out my old shocks were actually not worn haha.
For the B6 upgrade, I'm wondering about bump compliance. I'm in LA, too. What's it like on, say, La Brea Ave just north of Wilshire?
I'd love to hear more of your impressions now that you've driven them for a while. Thanks!
i miss that German stiff feeling and confidence in turns.
did your upgrade give you that feeling? If so please let me know everything you replace, and a good place to purchase.
Knowing what I do about Bilsteins, the B6 will be another level beyond that. B6 is made for sport valving for stock springs. B8 is for lower/stiffer springs.
The part numbers for what I installed on my car are Bilstein 24-166874 . I also used these upper mounts, since the shocks do not include them. Note about the mounts: everywhere you check will tell you that these mounts do not fit. For some reason in the USA everyone wants to sell you generic shocks that already have mounts on them and nobody lists a replacement mount. If you check overseas, you will will find that the above linked mount fits the W212 E350. This is what I have on my car.
Nope, still has the airmatic setup in the rear with the B6s and lowering links.
It was generally agreed that the MB OEM option is too soft of a ride, and tends to start wearing out between 65k - 80k miles. Those that had made the change felt that the B4, while still offering a nice ride, was a step up in sportiness from the OEM. While some liked the B6, those that had tried them recommended caution in selecting them, suggesting that they are a little on the harsh side.
I picked up B4 kits (front and rear) from FCP and installed them about 25k miles ago on my '14 E350. So far I've been very happy with the B4, and would definitely consider them a better option than the MB OEM.
