Replacement Wiper Blade Recommendations (for my W212)
Long time since I've posted but I've been searching for a new pair of wiper blades for my 2012 E250 CGI for a while now and thought I'd reach out for some advice. I've tried a few Bosch and Trico ones here in Australia but they just don't seem to last in the Aussie heat. I'm finding that after about 6 months they seem to fail quite badly to the point where they streak across the windscreen and need to be replaced.
I've been recommended Wipers Direct Mercedes Benz E Class Replacement Wipers by a friend but before I buy I'd like to know if anybody has any other recommendations for wiper blades that I can get in Australia? Don't want to spend any extra money on wipers if I can avoid it!
Cheers,
Currently I am using the Michelin sold at US Costco.... I extracted the refills: perfect match
The longest lasting upgrade BLADES ARE SILICONE based. The black rubber under solar UV exposure has limited performance.
The long story short is the angle of the car wiper arm is factory biased such that the blade is forced to skip instead of wipe properly.
Once you twist the arm angle couple degrees, the blades wipe normally like any Lexus.
Here this is a great coverage about the arm angle MB insist on screwing up
Hope this helps
I have these on my car (not an MB) and they're great! We do have MB wipers on the grocery getter and they are also great.
1. Yet another wiper blade attachment design is not going to save the planet.
2. Selling blade refills (just the rubber part) rather than an entire blade assembly with 6 plastic adapter pieces might.
