How is the trunk lock supposed to seal?
Water gets inside the trunk LID and drips out of the lock mechanism when I open it. The water isn't leaking past the trunk lid into the trunk, it's leaking into the inside of the trunk lid itself. This huge hole is the most likely culprit right now. My dealer parts guy tells me there is no gasket that is supposed to be here.
Can anyone snap a pic of theirs to confirm that the button is supposed to be sticking OUT of the lid? Also, does anyone have a link to a guide for replacing this part so I can see how it mounts internally and what is involved in opening this up to see why it's improperly mounted?
Thanks.
Edit: it looks like the bracket is sold separately as part # 204-758-00-14, but I'm not sure if this is the problem here...
This part doesn't show up in the catalog anywhere, so my take is this was someone's half-assed attempt to fix the leak without identifying the problem first.
Can someone confirm this piece is extraneous?
Edit: this piece could also have been added as a half-assed fix for ANOTHER leak that I haven't found yet. And it might have actually served this purpose at some point...
windshield rubber seal and trunk lock
I recall the lock appreciated getting my brake-caliper silicone formula.
MY HOND-A-CURA 3.2TL LINER: EXACT MATCH 👏
MB Transmission light years away from Honda's transaxels suppliers.
So I'll just find an appropriate adhesive and stick this one back on...
As soon as it gets back above freezing, I'm going to do a proper water intrusion test to confirm where the water is actually entering from. Maybe the gap around the lock mechanism is a red herring.
self-sealing rubber pins ...
These little guys 8x pieces total go from rain collection area directly into trunk area.
One missing and trunk payload becomes a profit center on either side premium accessories.
If leak at the trunk door itself, it can only be from the side lights.
Sorry, I did not remove the plastic plate covering the mechanical key slot.
But I have its rear view photos.
THE LIGHT BOX
No 1 is trunk open switch, so it is not mechanical, it is electric PUSH BUTTON SWITCH.
Thats alll.....
There is a 1cm layer of foam as seal for these rear light.
See the foam up close.
Good question.
Nope, no hole going into trunk inside. I did some Sherlock Holmes......
https://baza.drom.ru/novosibirsk/sel...-87112685.html
https://www.ebay.co.uk/itm/264679863785
So MB made an "external lip" for that chrome piece
https://lagabasen.com/visa-produkt?part=AS-81873364#
Your question made me worried too....of leak
It appears that water could be entering at one or more of these areas to collect inside the trunk lid, though the Star would be my first look. I wonder if there was ever collision damage to the trunk lid and it was replaced.
Still we need to check these when they go older
STAR
https://www.deutsche-parts.co.uk/a21...uine-part.html
Nylon grommet for STAR
https://www.ebay.co.uk/itm/121665668515
Number plate female rivet. Item 240 in EPC
https://mercteil.com/mercedes-benz-a...are-part-XOvY3
Why is it we boys are always looking at HOLES ???
I'm going to go over every single possible leak point in the trunk after I fix this stupid leak in my cooling system at the interface to the windshield washer reservoir.
