Got a Launch X431 Elite 2.0 Pro and threw my first codes
- Control Unit Fuel pump (N118):
- P254000 Low Pressure Fuel System Sensor Circuit Range/Performance (possibly fuel filter)
- P012D Turbocharger/Supercharger Inlet Pressure Sensor A Circuit High
- a206 The current vehicle identification number is incorrect or not present
- 9561 The PIN for theft protection is wrong or not present (please don't try to steal my head unit)
- Central Gateway(CGW[ZGW]):
- U103888 Communication with the diagnostic CAN bus has a malfunction. Bus OFF
- C156E00 Calibration of the vehicle level was not performed (this is related to the headlamp module)
- Driver Side SAM (N10/1):
- B181E2A The sensor for the engine hood has a malfunction. There is no signal change.
- B221D49 The rain sensor has a malfunction. There is an internal electrical fault.
- Keyless Go(N69/5):
- B1F8C14 The upper sensor of the rear switching module has a malfunction. There is a short circuit to ground or an open circuit.
- Parktronic (N62)--360 degree camera:
- UD14786 Communication with the control unit "Head unit" has a malfunction. There is an incorrect signal.
I know a lot of people would wish they didn't have the Launch thingy so they could remain blissfully unaware since the car still drives fine and there are warnings on the dash, but I feel good having some more warning.
I didn't intend to ask any questions here, since I haven't put much legwork into this stuff myself yet, and most of these codes are probably BS/old, but I have spent some time trying to figure out where/what the turbocharger inlet pressure sensor is and where it can be found. Mercedes apparently doesn't call it this, or I'm a dumbass.
Compared to the W211, the W212 feels like a launch vehicle in system complexity (perhaps not one designed to any airworthiness standards)...
KeylessGo is not essential but it causes battery drain and that rains troubles on the while chassis
The fuel pump, Turbo and F-SAM are high up on the top list.
I'm surprised the calibration code did not return UNLESS a calibration was performed and the code was not cleared. The hood code is probably due to the hood being open when you ran the scan.
I am curious about the 20-page report from the dealer. Was this a Mercedes dealer or just the place you bought the car from?
A simple battery disconnect or a relay removed at the wrong time..... can give you STORED codes enough to scare most people
Wait till you see a W213 and with a 48V system dumb-azz el-cheapo hybrid engine.
- Rain/Light sensor (RGLS)
- B221D49 The rain sensor has a malfunction. There is an internal electrical fault. (CURRENT and STORED)
- KOMO/mbrace -Communication Module Telematics Servies/Emergency call system
- B15D814 The cable for audio muting has a malfunction. There is a short circuit to ground or an open circuit. (STORED)
- Driver-side SAM - Front Signal Acquisition and Actuation module (N10/1)
- B221D49 The rain sensor has a malfunction. There is an internal electrical fault (CURRENT and STORED)
- Keyless GO (N69/5)
- B1F8C14 The upper sensor of the rear switching module has a malfunction. There is a short circuit to ground or an open circuit. (CURRENT and STORED)
- B1F8D14 The lower sensor of the rear switching module has a malfunction. There is a short circuit to ground or an open circuit. (STORED)
- Parktronic (N62) --360 Degree Camera
- U014786 Communication with the control unit "Head unit" has a malfunction. There is an incorrect signal. (STORED)
- ECM - Engine Control Module (ME)
- P012D00 Pressure sensor upstream of the turbocharger has a short circuit to positive. (STORED)
- FSCU - Control Unit Fuel Pump (N118)
- P254000 The signal for the pressure sensor of the low-pressure fuel circuit is implausible. (CURRENT and STORED)
Some of these have different descriptions because there are two places to read them in the interface and they give them in slightly different ways. Interesting that stored codes would be showing when I just did the reset. Also interesting that the lower sensor of the rear switching module is now STORED when it wasn't even a code before. Keyless GO works perfectly fine including the touch to lock and unlock functions. Also the rear camera works fine as well.... The rain sensor also works kinda OK. It worked better on the W211, but it definitely still functions on this car...
The report must be at work but when I find it, I'll post some snippets.
- P254000 Low Pressure Fuel System Sensor Circuit Range/Performance (CURRENT and STORED)
- P012D Turbocharger/Supercharger Inlet Pressure Sensor A Circuit High (STORED)
- a206 The current vehicle identification number is incorrect or not present (STORED)
- 9561 The PIN for theft protection is wrong or not present (STORED)
- U103888 Communication with the diagnostic CAN bus has a malfunction. Bus OFF (STORED)
- C156E00 Calibration of the vehicle level was not performed (this is related to the headlamp module) (STORED)
- B181E2A The sensor for the engine hood has a malfunction. There is no signal change. (STORED)
- B1F8C14 The upper sensor of the rear switching module has a malfunction. There is a short circuit to ground or an open circuit. (STORED)
- B1F8D14 The upper sensor of the rear switching module has a malfunction. There is a short circuit to ground or an open circuit. (STORED) (I forgot to note this the first time)
- UD14786 Communication with the control unit "Head unit" has a malfunction. There is an incorrect signal. (STORED)
- B142E31 The GPS antenna has a malfunction. The signal is not present. (CURRENT and STORED)
You don't want to have to get a new key. Over $660 for a complete key.
EDIT: Actually, with a 2014, you might be able to find a locksmith that can program the key fob. Things changed with the 2015 model year and you MUST get a dealer to program a new fob. I did find a locksmith online that sells NEW OEM fobs for $99 (versus $424 from the dealer) with exact FCC ID and other numbers as you would get from the dealer, if you ever need one. It comes with a key blank that can be laser cut by any competent locksmith. The site is www.northcoastkeyless.com. I bought one and couldn't use it, so I was able to return it for a full refund.
https://northcoastkeyless.com/produc...zdc11-iyzdc12/
You realized that new faults go straight into "Stored" status and the LPFP is actively disfunctioning.
--1-- TOP PRIORITY:
I would tackle the in-tank 3-phase fuel pump module first.
This module sources its GND in the passenger side of trunk near the R-SAM.
This is a VIP-Module networked directly with engine CAN-C and provides fuel volume to HPFP. It has to work right.
Before you take everything apart reproduce the problem so you know the difference after fixing.
See what the pressure sensing does.... I think it is erroneously flagged due to poor GND circuit.
I don't know where pressure sensor gets its GND, separately?
--2-- Goofy module status:
-- New Stored faults are called transients... caused by marginal painted GND posts.
-- Organize a GND cleaning campaign as a repsir item before anything else to save time.
-- Disconnect batteries when disturbing GND circuits.
-- In that order:
- -- Trunk L+R
- -- Front footwell L+R
- -- Engine bay /chassis
- -- Chair cross-beam
All equally amazing.
I forgot something.
01. Make it a habit to keep track of the modules making the report/DTC. This is important.
When one module is down, the one reporting it will be its buddy modules.
02. When all modules are running, keep track of their QUANTITY. This seems simple but is important.
So at a glance by modules count, you can tell by QTY which module is missing/offline.
Yes, take photos of all the modules name for your own database.
Take a read here to see how whacky the content of the DTC can be from simple power loss and various scanners DTC response towards the same test/power-loss
https://mbworld.org/forums/e-class-w...276-820-a.html
Does this happen to anyone else?
Am I existing in a parallel universe?
