Sponsored by: CARiD
W212 sudden stop
Old Apr 8, 2024 | 07:12 AM
douglas0210's Avatar
W212 E250
W212 sudden stop
Hi everyone
My 2011 W212 250 CGI has been experiencing sudden engine shutdowns since last year, with all signal lights on the dashboard turning on. I have checked the readings with an OBD scanner and the results are as follows. I took it to the garage for its annual check-up, but they were unable to find anything wrong. Can anyone help regarding this issue? Many thanks!!Car Scanner ELM OBD2
Version: 1.102.7/1.102.7/iOS
DTC report
Connection profile: Mercedes-Benz OBD-II / EOBDDate: 30/1/2024 7:45:47 PM
VIN: WDD2120472A513805
OBD-IIOBD-II
DTCs: 1
P126F(00) [0x126F00] Archive (inactive)
Status: Confirmed, Test failed since last DTC clear
Engine control unitEngine control unit
DTCs: 1
Transmission control unitTransmission control unit
DTCs: 7
U0121 [0xC121] Archive (inactive)
Data bus, anti-lock brake system (ABS) control module - no communication
Status: Validated and stored in non volatile memory
U0100 [0xC100] Archive (inactive)
Data bus, engine control module (ECM) A - no communication
Lost Communication with ECM/PCM A
U0126 [0xC126] Archive (inactive)
Data bus, steering position sensor control module - no communication
U110B [0xD10B] Archive (inactive)
U0167 [0xC167] Archive (inactive)
Data bus, immobilizer control module - no communication
U0164 [0xC164] Archive (inactive)
Data bus, AC control module - no communication
U0141 [0xC141] Archive (inactive)
Data bus, body control module (BCM) A - no communication
ABS control unitABS control unit
DTCs: 8
C074A(00) [0x474A00] Archive (inactive)
C074B(00) [0x474B00]
Status: Confirmed, Test failed since last DTC clear, Warning indicator requested
C074C(00) [0x474C00]
C0752(00) [0x475200]
C0754(00) [0x475400]
C0755(00) [0x475500]
C0756(00) [0x475600]
C1752(00) [0x575200]
Old Apr 8, 2024 | 08:48 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Too many error codes listed to start.
Standard practice is to record original codes (one above)
Delete ALL the codes
Start the vehicle and scan again
Check for new codes, select the most likely to trigger other codes, and go from there.
While doing that, how old are your batteries? Have you checked your batteries' voltages ? Either with a voltmeter, or using the car's cluster
Old Apr 9, 2024 | 12:11 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CRYPTIC ENUMERATION
Do yourself a favor, invest in a $150 scanner tool.
It will automatically translate fault codes with English descriptions.
Right now your partial list of computer codes are meaningless. Unless someone sort things out, this report will remain ...
Old Apr 9, 2024 | 09:13 AM
JettaRed's Avatar
Veteran: Army
Beat me to it!
Old Apr 11, 2024 | 09:57 PM
W212 E250
I’ve cleared all codes and scan again and found P060C and P126F.
Battery has been replaced since last annual check on December 2023.
Old Apr 11, 2024 | 10:17 PM
JCM_MB's Avatar
P126f key be related to eco start/stop if your car has it
P060C is related to ECU processor error
However, w/o an MB additional specific codes, it is just a hint where to look next
Old Apr 12, 2024 | 01:37 AM
W212 E250
The key low battery signal is always on, regardless of whether I replace the battery in the drawer or go to the grocery store to get a new one. I'm not sure if it is related to P126f or not.
Old Apr 13, 2024 | 02:08 AM
S-Prihadi's Avatar
Old Apr 13, 2024 | 08:45 AM
JettaRed's Avatar
Veteran: Army
Do you have a second key? Use that one.
(If you don't have a second key, GET ONE. They're not cheap, and a Mercedes dealer can program a new fob without needing a working key, but you don't want to be stranded or unable to drive over a weekend or holiday.)
Try removing the push-to-start button and use your key. Does that fix the codes?
