Sponsored by: CARiD
Fixing the clicks, creaks and other interior noises
Old Apr 12, 2024 | 10:59 PM
Bruce Hubbard's Avatar
W212
Some annoying noises in the doors and interior panels when you drive over bad road surfaces.
The clips that hold the side cushions can move in the slots, so can the clips that hold the rear seat.
I fixed them in position with a tube of silicone applying some to each end of the clip (arrowed)
The door panels have screws that secure trim parts and can work loose, so I tightened them all
There are loose cables and things floating around that need to be strapped down
I bought a roll of adhesive backed 10mm foam to cut in strips as required to hold things down or pad between things and the door panel
Some bracket type clips that hold the trim panels on roof lining at the rear need to be packed between the clip and the roof to stop them moving
I packed between the two bolt fixing of the door panel to the door with the 10mm foam
The bolts that hold the panoramic sunroof had worked loose and you hear a "crack" when going over bumps
I pulled the roof lining down to access the bolts and retightened them (there are Youtube videos how to do it)
I didn't use any thread locking glue though, I'd rather just retighten them again.
There are a couple of small screws tucked away that are easy to miss so take care that you have tightened them all
Old Apr 13, 2024 | 01:25 AM
S-Prihadi's Avatar
A lot wire silencing foam from MB becomes dust in my country at 8th year.
If you open up the Pano Roof control, you will find it there as one of the example.
I suggest you buy fleece type cable tape ( silencer ) from TESA too.
They have 2 types, one is silencer/fleece and one is abrresion resistance.
These two are what MB/BMW uses.
Pano roof bolts loosen is given and will happen. I thread lock them and now all good for the last 3 years.
If you do not already have the 2 special pano roof lubricant from MB, I suggest you get them and do it once per 2-3 years.
Attached PDF
File Type: pdf
Old Apr 13, 2024 | 01:31 AM
S-Prihadi's Avatar
Test your headliner like below :
See if yours is like mine..........
The noise maker
Old Apr 13, 2024 | 01:41 AM
S-Prihadi's Avatar
Here for you to test on your car, the noise makers on mine
https://mbworld.org/forums/e-class-w...e-measure.html
When you know your car exterior better, here are the noise makers
https://mbworld.org/forums/e-class-w...ise-maker.html
Old Apr 13, 2024 | 10:32 PM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
I have 2 major NVH problems on my W212: the front passenger door and the rear speaker grill. I understand the factory published a fix for the speaker grill, but I think I need to do the door like you did here. Whatchya gonna do...
