Sponsored by: CARiD
Eliminating all NVH
Old Jun 8, 2024 | 06:47 PM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
Eliminating all NVH
Since I've been driving Benzes since my first car right out of college (a 1983 240D manual), I am used to a complete absence of rattles and buzzes (NVH: noise, vibration, harshness) from inside the cockpit. I tolerate a bit of road noise because I don't yet know how to completely eliminate that, but if there are 2 coins in my cup holder and they start to make contact, I have to feel around for the source of the noise and somehow make it go away. I can't help it....
So since I got the E550, I've been going insane because I can't play my music as loud as I would like without activating various vibration/rattle modes around the car. Sometimes the engine or road vibration will also activate them.
I did a frequency sweep today and found two main sources which are loud enough that they may be masking other buzzing:
-the rear package deck speaker area (40 +/- 20Hz)
-the passenger side door (80 +/- 20Hz)
-driver seatbelt (not activated by audio, but still annoying)
From other threads, I gathered that possible sources of the rear speaker area rattle are the child seat retaining mechanisms, the center brake light (CHMSL), and the speaker grill itself (I believe there is a TSB on this, anyone have it?)
The passenger door noise is coming from the door card itself vibrating heavily. It's probably intermittently contacting something on the inside so I need to pull it off and apply foam to the places where this can happen. I think I saw a thread about that somewhere but I'm still looking for it.
The driver seatbelt latch mechanism by the side of the seat slides against the seat as the driver's body moves making an occasional creaking sound. I might see if putting some plastic safe dry lube on it shuts it up for a while. Otherwise, I'm not sure how to address this without adding an ugly patch of material to the side of the seat or putting a boot on the seatbelt latch mechanism.
Once I can get the speaker area and door taken care of, I'm sure I will find other culprits. I had a rattle from my center console that went away by opening the sliding cover, but that has gone into hibernation for now...
Edit: I found a TSB for the seatbelt noise, surprisingly:
https://www.tsbsearch.com/Mercedes-B...91-10-P-060560
Looks like I need to find a "noise reduction service set" and grab some felt from it. It is part number: A 000 983 71 10 and it looks like this:
(w124performance.com)
Old Jul 1, 2024 | 02:29 PM
ChuangTzu's Avatar
Looks like I have a new source of NVH: blown passenger side front door speaker...
Old Jul 1, 2024 | 10:06 PM
JettaRed's Avatar
Veteran: Army
You and @S-Prihadi need to get together. He likes disassembling his car.
Old Jul 2, 2024 | 01:40 AM
S-Prihadi's Avatar
Old Jul 2, 2024 | 04:04 PM
ChuangTzu's Avatar
He's definitely the first (only?) person I'm going to hit up whenever I'm in Indonesia!
Old Sep 19, 2024 | 09:36 PM
ChuangTzu's Avatar
New source is my front brakes. They groan and creak a few times after coming to a complete stop and starting to pull away again...
Old Sep 20, 2024 | 03:54 AM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
after the brake job our indie mechanic did along with the B service at 50k or so miles, our 2016 E350 wagon's brakes have been absolutely smooth and quiet.
Old Sep 20, 2024 | 06:33 AM
JettaRed's Avatar
Veteran: Army
Re-reading this thread (and just getting hearing aids at my wife's insistence), there is something to be said for being deaf at higher frequencies.
Old Sep 20, 2024 | 06:52 AM
S-Prihadi's Avatar
Me at 57 years old, I can't hear above 15Khz
But most mechanical noises in our car does come close to 15 Khz....so no worry.
I have not seen old CRT TV anymore, that thing supposedly its flyback transformer is humming at +-15.75Khz.
When CRT TV or Monitor was still in use, I can hear them humming....but me much younger back then.
Get a good headphone and you can use this one : https://onlinetonegenerator.com/hearingtest.html
I am fortunate that I am very sensitive to low frequency rumble even at low magnitude, the one low enough to be felt and not only heard.
Old Sep 20, 2024 | 07:57 AM
JettaRed's Avatar
Veteran: Army
My problem! My latest hearing test results.
Just kidding! Please keep this between us.
Old Sep 20, 2024 | 10:46 AM
ChuangTzu's Avatar
I have notch loss somewhere in the middle of the range, but certain frequencies also get distorted to be even more annoying. I guess I'm not old enough yet... :P
Old Sep 20, 2024 | 11:44 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Back in the late 90s, I had a similar hearing test. Once done, I was asked why I was there, my results were normal for a man in his late 30's. I answered, "Apparently I am not hearing well, " and the audiologist replied: "you are married, correct?". I started laughing. My ex was not happy when I mentioned it to her.
Old Dec 8, 2024 | 11:57 AM
ChuangTzu's Avatar
Adding a link to this other NVH thread for future use:
https://mbworld.org/forums/e-class-w...duction-6.html
