Sponsored by: CARiD
P1885 code questions
Old Aug 16, 2024 | 11:08 AM
Wyowolf's Avatar
2015 e350
My son's car has been getting this code. I hooked up my code reader and. took pics of all the codes.
When I run the live data it's showing all 4 cams in spec? not sure what im not seeing here.
2015 e350
also how do I clear the intake blocked ice code? ive tried and it keeps coming back
thank you very much
Old Aug 16, 2024 | 12:21 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Did you already try deleting ALL codes? Turn off the car, cluster OFF, start the vehicle, and rescan to see which codes are back.
I would swap the Intake Camshaft Position Sensor between banks 1 and 2. Rescan, if the message switches banks, you know the sensor is toasted.
When you are disconnecting the position sensors -> CHECK for oil in the connectors.
Old Aug 16, 2024 | 12:57 PM
Wyowolf's Avatar
2015 e350
yes a couple times. ok thank you I will do that.
sorry forgot I did replace the sensor already
Old Aug 16, 2024 | 01:26 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
chassis gone wild
2015 e350
thank you very much
We need to read full report to see the extent of this disruption on CAN-C VIP's. Now you're only showing a 3x modules. All modules interact and disfunction together.
It looks very much like a soft-crash... could be "oil-in-harness" or perhaps old undersized relays (30g found under 8.5VDC)
You can tell the ECU is crazy calling a CURRENT fault on the camshaft position you are showing to be perfect.
- Were the old CPS failed before replacement ?
- What the current engine mileage ?
- Any rattling involved (cam wheel) ?
Right now you could:
  • reboot the chassis (batts out 10mn)
  • clear faults
  • rescan
  • drive 25mph roads
  • rescan
  • compare results
I would keep out of highspeed roadways for safety against limp-modes or until you get this all sorted out.
Old Aug 16, 2024 | 06:53 PM
Wyowolf's Avatar
2015 e350
  • clear faults
  • rescan
  • drive 25mph roads
  • rescan
  • compare results
thank you!
not sure how I can read more modules?
I got the code before and replaced it but it didnt change, I didnt notice any excessive oil on the connection.
how do I reboot the chassis?
battery out for ten min? correct ? ok ill have him do that.
I really dont understand the ice faults... ive tried to clear them several times... pretty sure there is no ice there..
No rattling , but there is a leak in the AOS or whatever its called near the rear of the engine.
I think 109kish
it does take longer to start from cranking, maybe 1 full second or so.
other than that its been a great running car, no real issues before this. bought it I think in 2019?
Old Aug 16, 2024 | 09:22 PM
49/11/33...
your chassis runs with 49 computers out of which 11 of them report 33 faults. Super bad ones can also be missing silent units.
We want to see the complete set or at least all 11 faulty units.
Reboot chassis by disconnecting BOTH batteries for 10mn (without shorting the leads!).
  • clear faults
  • rescan
  • drive 25mph roads
  • rescan
  • compare results
Old Aug 18, 2024 | 12:29 PM
Wyowolf's Avatar
2015 e350
49/11/33...
  • clear faults
  • rescan
  • drive 25mph roads
  • rescan
  • compare results
here is what I have
File Type: pdf
Old Aug 18, 2024 | 12:54 PM
JCM_MB's Avatar
I would check the health of the battery. Scan says 8.5V -> dead battery.
Once properly charged, or best NEW, delete and rescan. Those should NOT be back.
Too many communication errors- wonder if there is poor contact on the CAN connectors, or some central module, Gateway?
With those voltage levels, the computers cannot work reliably
Old Aug 18, 2024 | 02:39 PM
dealing with faults....
here is what I have
4x camshafts position checks
What happens after you clear current faults?
Are you able to shade most faults?
The initial report shows a low voltage event... we'd like to identify
Old Aug 18, 2024 | 04:04 PM
Wyowolf's Avatar
2015 e350
bought a new battery today and will replace and see how that works, good idea, I should have thought of that myself...
Old Aug 18, 2024 | 04:06 PM
Wyowolf's Avatar
2015 e350
ive tried to clear them and they won't.
I did buy a new battery will charge and replace and see what happens after that
note, I just checked I replaced it 4/22 so its not very old at all... it still could be bad I supposed... I did disconnect both batteries
Old Aug 18, 2024 | 06:53 PM
Lead-acid batteries get sulfated as soon as they get drained flat... even a fresh battery can be short lived.
I am surprised the STORED codes will not clear...
There a chance your ECU received "oil-in-harness" - Have a look at ECU connectors while your battery is disconnected.
Old Aug 18, 2024 | 06:59 PM
JCM_MB's Avatar
On the intake ice code, I would disconnect the sensor, scan it again and see if it changes to open circuit. If the code remains, either a dead sensor or @CaliBenzDriver suggested there may be a poor connection to the ECU
You can also try deleting while disconnected, reconnect, rescan
Old Aug 18, 2024 | 10:14 PM
killer low voltage... CTEK!
Juan, I think the ICED THROTTLE fault is from when the ECU went wild on 8.5Volts.
The question is what produced all that chaos...
-- Jump-started flat battery (user error!)
-- Genuine ECU issue (CPS... Oil-In-Harness...)
-- Combination of jump starting with pre-existing issues
Some of these cars eat batteries because of unstable CAN-B modules... thenk a CTEK float charger is a great workaround + bi-monthly reboots to sanitize sleepless CGW.
​​​​​​We want to understand what helped this chassis become unreliable.
Old Aug 18, 2024 | 11:11 PM
Wyowolf's Avatar
2015 e350
never been jumped since ive owned it roughly 5 years.
I left everything disconnected overnight and will retry in the morning.
which sensor is for the ice fault?
Old Aug 18, 2024 | 11:23 PM
JCM_MB's Avatar
Read document for M276. The intake temperature sensor is B17/1 . Check legend anyways
https://mbworld.org/forums/e-class-w...ml#post8114371
Old Aug 18, 2024 | 11:46 PM
KONIGSTIGER
was da man!!
Old Aug 19, 2024 | 08:52 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
KONIGSTIGER
was da man!!
I’ve not seen him around. What’s the word? Did he move to a new platform?
Old Aug 19, 2024 | 10:28 AM
JettaRed's Avatar
Veteran: Army
Does XTOOL use the same software file that other brands use? I know there are some brands that use the same core vehicle file. The XTOOL is using version V22.10. I know my LAUNCH Creader Elite 2.0 BENZ recently updated to V50.26.
Last edited by JettaRed; Aug 19, 2024 at 12:40 PM. Reason: Changed the software version from V53.XX to V50.26..
Old Aug 19, 2024 | 11:25 AM
Wyowolf's Avatar
2015 e350
Originally Posted by JettaRed
Does XTOOL use the same software file that other brands use? I know there are some brands that use the same core vehicle file. The XTOOL is using version V22.10. I know my LAUNCH Creader Elite 2.0 BENZ recently updated to V53.XX (I think).
I have no idea what it uses. it will send reports in PDF to my email I know that.
Old Aug 19, 2024 | 12:45 PM
JettaRed's Avatar
Veteran: Army
Does your report contain information like this at the beginning?
Old Aug 20, 2024 | 09:43 PM
Wyowolf's Avatar
2015 e350
Replaced battery with new one that I charged overnight. left both batteries unhooked overnight.
no real change in any of the codes, same as before, could not erase them either.
File Type: pdf
Old Aug 20, 2024 | 09:54 PM
JCM_MB's Avatar
Well, down from 33 to 13 is progress.
Now, there is definitely a communication problem. Did you disconnect the ECU and check the connector are extra clean, i.e. no oil?
Old Aug 20, 2024 | 09:57 PM
Wyowolf's Avatar
2015 e350
no I did not disconnect it, but if there is oil I can't see any measurable amount...
I can disconnect the batteries and the eco and try again
car is not really used at this time.
Old Aug 20, 2024 | 10:04 PM
JCM_MB's Avatar
Wondering if there is moisture on the carpets.bthat us where communication bridges are. Or if there have previously been any water intrusion either front SAM, cabin or trunk?
You have already rated this thread Rating: Thread Rating: 1 votes, 2.00 average.
