Sponsored by: CARiD
Chasing Mercedes E350 Misfire
Old Oct 24, 2024 | 03:12 PM
  #51
Tdavid1's Avatar
Originally Posted by Jaybird123
My m278 Bank 2 (passenger side US). I only replaced the intake adjuster (right side one in picture, nearer center of motor)
how do you know which one is bad?
Old Oct 24, 2024 | 03:35 PM
  #52
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
INSPECTING to PLAN FIXES...
Originally Posted by Tdavid1
interesting… would that help my misfire/out of time as well?
You can experiment to pioneer this answer.
I hate to over promise... 90% likely possible ***
If your Cyl.1 misfire is indeed...
from bad VVT cam timings and
not swamped Cam+Lambda sensors or
lost cylinder compressions.
See we've gone a long way from in-tank pumps...
you need to Visually Inspect the VVT Lock-pins + Lambda connectors + CPS (+ compressions) to come up with solid plan to save time/money.
Ultimately if you do the right fix once only:
it's a victory for you and team MS!
*** you can try while you're getting ready for big fix surgery day.
Even my 15w40+ provides necessary idling pressure to position VVT at idle (as witnessed by rapid cold start idle sequence).
Last edited by CaliBenzDriver; Oct 24, 2024 at 04:05 PM. Reason: poor oiling causes rattling
Old Oct 24, 2024 | 04:11 PM
  #53
Tdavid1's Avatar
So do I just unplug the solenoid and run the car? Or do I need to check the pins first? Sorry a little confused on this. I should check compression first before I do anything though.
Old Oct 24, 2024 | 04:25 PM
  #54
yes unplug but need oil upgrade.
Thin stock oil does not have the pressure needed to work HPFP without lock-pins.
Old Oct 24, 2024 | 04:27 PM
  #55
Tdavid1's Avatar
I just did an oil change on it with W40. Is that good enough to test?
where is this solenoid located exactly?
Old Oct 24, 2024 | 04:34 PM
  #56
OIL HYDRAULICS TIPS
.... that's unlikely great pressure but not wrong either. No worries I am still on w40 as well with a 15w40 (+200mL:15w50) on my way to 5/10w50.
Anyway at least this is fresh clean oil, not thin 0w40 sheared into W30 range.
Precise hydraulic VVT work needs predictable pressure (ie. free of wild steps).
VVT actuation are dynamically pre-mapped ie. needs learning time.
The pump solenoid connector is located on bank-1 side of crank balancer pulley.
​Tape or tie down harness so it doesn't go meet spinning balancer...
+++ Actual results are limited by oil pressure ie. viscosity range combined with temperature.
BTW engine oil temperature is linked to viscosity.
So the target oil viscosity is not an exact number but an experimental range I believe near 5/10/15-W50 based on engine, driving style, location...
Old Oct 24, 2024 | 06:12 PM
  #57
Tdavid1's Avatar
Tried it, ran fine for about a minute and then started misfiring again.
I did a compression test too, seems ok?
What you guys think my next step is? Lol
Old Oct 24, 2024 | 06:22 PM
  #58
Your Cyl.1 is now reported good:
  • bore scope fine
  • compression fine
  • new plug
  • Replaced injector
  • (coil/boot?)
Your engine condition qualifies your chassis to stay on the road for another 100kMi.
Now check VVT Gear lock pins by manually rotating crankshaft CW ... if you hear "clunk" at fixed positions (bank1+2): you then open up VVT covers L+ R to witness VVT skiping forward
then you'll know for sure condition of VVT Gear.
Old Oct 24, 2024 | 06:33 PM
  #59
Tdavid1's Avatar
  • bore scope fine
  • compression fine
  • new plug
  • Replaced injector
  • (coil/boot?)
Now check VVT Gear lock pins by manually rotating CW crankshaft... if you hear "clunk" at fixed positions (bank1+2): you then open up VVT covers L+ R to witness VVT skiping forward
then youll know for sure condition of VVT Gear.
Ok, found oil in 2/4 CPS connectors and these sensors itself seem damaged.
Old Oct 24, 2024 | 06:42 PM
  #60
Tdavid1's Avatar
No clicking noise heard, put it at 53 degrees and checked. All seem to line up except bank 2 intake side, possibly why I have that code for the bank 2 CPS..
Old Oct 24, 2024 | 06:45 PM
  #61
CHECKING ITEMS....
I see... you have confirmed oil in CPS Harness...
> Next go open upstream Lambda connectors to inspect oily plug.
> Next go open ECU connector to inspect oily plugs
--> then you'll know what's in your cards.
(We may have free fix for no harness needed)
There is a good chance your failed CPS are telling stories to ECU
meaning VVT Gears may be ok - Not proven bad so far.
Old Oct 24, 2024 | 06:55 PM
  #62
Tdavid1's Avatar
okay...
Next go open Lambda connectors to see if oil made it down there...
Next go open ECU connector plugs
No oil in lambda connectors or ecu..
Just both exhaust side CPS. Could that be why they were reading so high? Or is that vvt actuator jumped?
Old Oct 24, 2024 | 07:00 PM
  #63
Very Nice!!! You've saved a big PITA + $10k cash.
Answer is nope because it was your intakes reading wild.
Meaning you likely have bad VVT Grar lock pins because the intake CPS are not wet.
Now spin crank CW to hear "clunk" on intake sides
++++ RECAP-01 BEING:
  1. Confirmed good Cyl.1
  2. Oily exhaust CPS
  3. Likely 2x bad Intake VVT gears???
  4. Dry Lambda + ECU
Old Oct 24, 2024 | 07:01 PM
  #64
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
If you have electronic contact cleaner around, spray all the CPS connectors on both sides, wait until they are dried and you can give a short run afterward just to see what else shows up before oil makes it through the CPS again.
Start filling up your FCPEuro cart with CPS, and xxx.
Old Oct 24, 2024 | 07:06 PM
  #65
Tdavid1's Avatar
No clicking noise at all. So do I replace the CPS and test it? Or do I also do that one VVT actuator that seems to be jumped? But that actuator is on bank 2 and I was getting a cyl 1 mis…
Old Oct 24, 2024 | 07:08 PM
  #66
This does not add up... let me think.
Your wild VVT timings is on both intakes and locks preliminary checked to sound ok.
Camshafts reluctors shifted... both intakes??
You can visually check for weird timing marks through CPS holes. ($$$ camshafts?)
That's entirely possible given rattling was ignored long enough.
> SOMETHING ELSE does not add up:
Can not have bad camshaft reluctors with good VVT!!!
Either both items bad or VVT only.
physically Inspect timing marks though CPS holes,
youll see them skip forward while rotating crank.
++++ RECAP-02 BEING:
  2. Conf. bad oily exhaust CPS
  3. Likely good VVT (prelim. "no clunk")
  4. Dry Lambda + ECU
Old Oct 24, 2024 | 07:16 PM
  #67
JettaRed's Avatar
Veteran: Army
This is interesting. I am having no problems with my car, yet my cam adjustments are very similar to yours. The engine was running at the time. Tomorrow I will check with my Autel and XENTRY to see if I have different values. Not sure if your VVT is broken or not.
Old Oct 24, 2024 | 07:35 PM
  #68
INTERESTING DISCREPANCIES... ?? Autel ??
both intakes near 37° (Max ref'ed as 23)
scanners don't seem to agree on acceptable range.
Autel fault cam positions out of range where iCarsoft does not.
Since JR's engine is good and OP says his engine "runs well": AUTEL likely WRONG!!!
Time to see Xentry as reference
OP original DTC/CEL is Cyl.1 Misfire.
Old Oct 24, 2024 | 07:38 PM
  #69
Tdavid1's Avatar
Hmm all I can think of then are the CPS giving ECU false info? Do I just replace them and put everything back and check? Btw I didn’t replace the spark plugs I just switched them and it stayed at cyl 1.
but are isn’t that intake bank 2 cam adjuster out of time? Why are all those lining up the same except that one at 53 degrees..?
Old Oct 24, 2024 | 07:48 PM
  #70
FUNNELING TOWARDS SHORT LIST
The way this seems to add up better is...
ok VVT gears until visually proven unlocked/bad.
Wet exhaust CPS can *not* screw up intake position - - Autel scanner likely has bad firmware loaded (update!!)
Good job on testing Cyl.1 moving plug around is totally fine.
Did you move coil as well?
(these hot engines can/do fry 100kMi coils)
+++ NEED A VISUAL inspection
on Cam position skipping or not
then we'll know big job or small job.
camshaft timings holes
Confim 4x cam static marks line up
Confirm VVT Gears dont skip foreward .. unlocked
Old Oct 24, 2024 | 07:59 PM
  #71
Tdavid1's Avatar
Yeah coil is swapped too. Just did a software update on scanner. Now I have to put everything back together tomorrow and rescan? :/
should I do anything before putting stuff back?
Old Oct 24, 2024 | 08:01 PM
  #72
yes, inspect 4x camshafts static timing marks right now.
There's a YT video or...
simply rotate FWD only until cams reluctor mark + crank are all lined up (Rwd will use sloppy chain slack... no-no!).
We're almost done pounding all the nails on this thing - - So far a good auction deal
++++ RECAP-03 BEING:
  1. Cyl.1 physically insp.: ok!
  2. Cyl.1 plug/Cop swapped: ok!
  3. Cyl.1 misfire DTC... LEAN?
  4. CPS Oily exhaust: bad!
  5. Likely good VVT (prelim. "no clunk")
  6. Dry Lambda + ECU: ok!
  7. HPFP+Tank pressures both: ok!
Q: THEN WHAT'S CAUSING LTFT ??
Old Oct 24, 2024 | 08:06 PM
  #73
JettaRed's Avatar
Veteran: Army
The CPSs are going to be oily because they sit in the valve cover and there is oil thrown around by the cams. I don't think they are damaged but replacing them may not be a bad idea. Please, please, please, get Genuine CPSs. I swapped mine out with Delphi brand, which is usually good, and had a 50% failure rate. I put the old ones back in.
I recommend you get these and use them between the wiring harness and the CPSs and Cam solenoids.
Old Oct 24, 2024 | 08:10 PM
  #74
Tdavid1's Avatar
yes, withess 4x camshafts timing marks right now.
There's a YT video or simply rotate FWD only until everything is lined up (Rwd will use sloppy chain slack... no-no!).
Will do tomorrow..lamee ik lol. I have to remove both those cam covers to see timing marks right? Are they yellow marks? All the yt videos are guys checking them from CPS ports but I don’t see anything.
Old Oct 24, 2024 | 08:20 PM
  #75
Yes only CPS ports nothing else.
Forget popping any covers... nooo!
at least you can see if camshafts skip forward loosely yes/no.
If cams are not loose then GREAT
timing marks may be missing: no problem.
So far none of this fixes LTFT...
