Chasing Mercedes E350 Misfire
Let's look at the basics and retrace our steps. Gasoline combustion requires the right amounts of air, fuel, compression, spark, and timing. (Timing affects compression and spark.)
Here u go...........
Over 3 meter per second is deemed as misfire.
So, your camshaft timing numbers are similar to mine and the OP's. (My numbers have the intake cams on top.)
I turned the crank and that bk2 intake vvt isn’t making any noise, I can hear oil pumping out of it but I’m assuming that’s normal op? It won’t line up with the other 3 Cams tho. What do I do? Do I put everything back to get more data or do I start on that 1 vvt adj.
Engine OFF as tested by David : bk2 ( Bank 2 ) intake vvt isn’t making any noise, I can hear oil pumping out of it but I’m assuming that’s normal op? It won’t line up with the other 3 Cams
If we assume the lock on that suspected VVT is good, the only way I see that it won't line up with the other 3, is because the reference to see it lining up is the TONE WHEEL .
So if TONE WHEEL shifted, David won't be able to align it with the other 3.
If chain too stretch at Bank 2, both Intake and Exhaust VVT will be out of alignment, because them two share the same chain.
V8 or V6, its the same for timing chain layout.
David, you checked via method below, see at hole of cam-pos sensor the TONE WHEEL edge : Right ? PDF Attached as Check Position of Camshaft.pdf
You can also confirm by 1 more method, but you need to open up the VVT mini window like below : PDF attached as Cylinder 1 at 40 degrees after TDC.pdf
Happy wrenching .....
One member here has done so and he put micro welding so that it wont move.
You need to remove the camshaft to fix that.
Now you only removed the magnetic solenoid of VVT right , below : ? Otherwise how do you see the oil valve of the VVT
You want to look at your current measurements via scan tool, give a couple VERY gentle taps, then rescan and review new measurements. Once in the range, stop. If lucky, it will hold that position like mine did.
This is completely outside of WIS or any such instruction, and only provided as a do at your own risk idea. Failure will require camshaft replacement most likely
Oil filler cap is on the opposite bank of this shifted wheel, if I adjust if from vvt cover removed how will I check measurements?
I can only advise that if the parts in front of Bank 2 plate block its removal on your engine (as they do on m278)…there’s a LOT more work involved (rabbit hole). Hopefully it’s more spacious given smaller motor etc.
Also, at this point I think the decisions on best path forward must be made by you. How thorough, how much effort and expense, etc. A truly thorough job here may cost you $1-2k DIY, and would certainly cost you well over $7-9k dealer easily. You might get lucky with some shortcut…and you might not. I wouldn’t be able to sleep well without evaluating the timing situation fully. YMMV as they say
Bk1+2 camshaft timing marks
Bank2 Intake: VVT Gear + camshaft reluctor wheel
> The stunt we're trying to acomplish is not replace pricey camshaft that holds reluctor... we want not to damage anything in the process!
Normally this is fuel rail+ injectors+ sparkCOPs+ valve cover... we're cutting big corner in parts+ labor.
Choices are...
- CPS port
- VVT Gear cover
Both choices are good:
- Opening gear cover requires replacing "one-time-use aluminum" screws plus fresh RTV seal after cleaning both surface sides.
- Monkey port is much quicker for sure! More crank pulley work to position adjust, align, adjust, align...
You decide!
Opening VVT cover lets you see VVT alignment marks and check if VVT Gear are PASS: ( locked good) or FAIL: (lock pin wasted).
The limp tensioner is a must service part that leaks much needed oil pressure.
You will definitely know if VVT needed or not.
To that extent see what's next....
>> WEIRD !!
the numbers don't show Bk2-i being out of place and no correlation code!!!
similar B1 vs. B2 numbers... from CPS
Gents: this means we're not done troubleshooting and need to pay attention to our timing marks assumptions... Opening VVT cover sounds like a real option if CPS port not matching.
we're missing a piece in that puzzle.
this adjuster seems toast. I didn’t know if I can upload a video here so I uploaded to YouTube lol.
https://youtu.be/yVhrLP7pvVg?feature=shared
here are the timing marks as well, seem ok? Well if the timing isn’t off, what the hell is causing the misfire!!!
Your Bk2-Intake Gear is confirmed history/shot...
that's why camshaft reluctor had a chance to get banged out of position.
Now how about Bk-1 ?
Lets complete the timing inspection of 4x Gear + reluctors.
++++ RECAP-05 BEING:
- Cyl.1 physically insp.: ok!
- Cyl.1 plug/Cop swapped: ok!
- Cyl.1 misfire DTC... LEAN?
- CPS Oily exhaust: bad!
- Dry Lambda + ECU harness: ok!
- HPFP+Tank pressures both: ok!
- Bad B2In VVT (
prelim. "no clunk") - Reluctor may be shifted ?!? <<<<
Low oil pressure -> weak chain tensioners -> VVT wears out -> tone ring slips --> $$$$
that's the predictable MB setup we've learned to expect:
"One thing must leads to the next one!"
Ignoring VVT rattling leads to shifting reluctors for bigger repair job. The engine failures are expertly engineered.
Improve oiling to cancel this early on.
Decide if you want to revisit soon or replace Bk1In now and be done!
Perhaps Bk-1 was worked on and owner got tired of all the milkin'
Bk-1 has the worst job driving the dry HPFP... it goes first.
see date codes on gear parts if nearly match to guess age...
