Rad fan on high speed
Cooling fan for the past month or two starts to run up to full speed shortly after starting the engine. Scanned for codes, other than one for a damaged left rear wheel speed sensor, nothing in the ECM or AC modules.
Live data shows the AC controller (when turned off) is at 1% for fan speed however the ECM fan control speed ramps up to 90% shortly after starting the engine.
Engine coolant temp via the scan tool looks completely plausible.
The AC pressure though shows 21 bar which in my world is over 300psi. I hooked up a set of gauges to the high and low side, with the AC off and outside temp at 8c, the pressures are both in the 50psi range.
So, it appears that the AC pressure switch is bad. My question is, will such a high pressure reading to the ECM cause it to command the fans on high?
If so, next step is to examine the harness at the switch and have the system discharged to install a new switch.
If the high reporting AC pressure (even with the AC turned off) does NOT cause the ECM to command the fans to 90%, what next?
Thanks, Dave
Thanks, Dave
Thanks, Dave
You've crossed all the T's including harness inspection!
The ECU reads "300.Psi" as A/C pressure where in fact your gauge set says 50psi.
This is sensed by a voltage measurement through a variable resistor - Check for water oxidation on both sides of the connector.
Then RTV Silicone all the low hanging connectors you see around there ... the MB wiring seals leak!
you on the other hand are questioning 21bar when your high side pressure sensor is good for 0-35bar
Plus your AC controller receiving pressure data is the one that sets the target fan speed and communicates that request to your ECU
I think you need put the gauges on and record while running the H and L pressures
Our dealer has 6 pressure switches in stock and says they are a common failure item. I'm waiting for the ok to have the system discharged so I can replace the switch.
Dave
glad we could help you stay on course to enjoy MB ownership.
