Cheers I bought a 2011 e250 150 kw and the problem is that after some time it works and some driving ,heating salong -top up coolant message pops up. Then I looked under the hood and the coolant level had dropped, removed the cap on coolant, it was as if the pressure was released and the level rose again to normal lvls. The same thing happens the next day, etc. It seems that this problem occurs after the salon heating is set to max, but at the same time, it could also just be a coincidence. Does anyone have experience with such a thing, what should be prepared for?
S-Prihadi
close
- Join DateMay 2018
- LocationJakarta-Indonesia
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2014 - W212.065 - E400 ( M276.820, 3 liter Turbo) RWD not Hybrid
Liked:6,549 Times in 3,956 Posts
This can only happen when and if your coolant hoses can expand beyond its normal size aka it is asking for $$ already
By expanding, it can take more coolant volume, thus the reservoir bottle coolant level goes down.
If heater core is the one you suspect, its total hose length is quite long if based on my engine.
This also means your engine has coolant shut off valve towards the heater core HVAC in the cabin.
Air bubble trapped in HVAC heater core and its related hoses.....can also contribute some
CaliBenzDriver
close
- Join DateApr 2019
- LocationSilicon Valley
- Vehicle(s) I driveW212 MY'14 M276-3.5NA @75kMi
Liked:6,776 Times in 4,765 Posts
The long story short is Mercedes coolant system leaks either slowly (monthly) or rapidly (weekly) or productively (daily).
MB coolant level must be maintained at regular intervals with matching chemistry.
>>Do not open HOT system under pressure (200°F shower causes burns!) - When you say "pressure is released" is a bit worrisome... cold system has zero pressure: ok!
-- Check coolant level cold only... just like with tires control!
-- Tell us how you car is driven as this impacts heat production by engine and release by radiator.
-- What size leak... S-M-L?
> Here the questions may be :
-- what leaks ?
-- what does not leak??
-- what leaks ?
-- what leaks ?
I don't see no leaks, When i open the coolant cork it releases like some air psshing sound and the coolant levels rise back to normal.Originally Posted by CaliBenzDriver
The long story short is Mercedes coolant system leaks either slowly (monthly) or rapidly (weekly) or productively (daily).MB coolant level must be maintained at regular intervals with matching chemistry.
-- what leaks ?
CaliBenzDriver
close
- Join DateApr 2019
Quote:
All good: back to normal is where coolant level should be. Originally Posted by Indrek555
Quote:
https://vimeo.com/manage/videos/1031844024 a small video of the issue this is opened after drive ,after initial release and fill it slowely fills rest up allso.Originally Posted by CaliBenzDriver
CaliBenzDriver
close
- Join DateApr 2019
Quote:
This confirms your coolant tank is low!!Originally Posted by Indrek555
-- DO NOT OPEN your coolant circuit with HOT engine temperatures: dangerous burn!
-- Do top off coolant tank with COLD ENGINE ONLY using compatible MB coolant.
-- Locate LEAK where coolant is going....
-- Coolant does not evaporate under sealed pressure. You have a leak.
It all slowelly fills back up after air is out.Originally Posted by CaliBenzDriver
This confirms your coolant tank is low!!-- DO NOT OPEN your coolant circuit with HOT engine temperatures: dangerous burn!
ExploreCaliBenzDriver
close
- Join DateApr 2019
Quote:
safety first Originally Posted by Indrek555
MB Specialist can pressure test your coolant circuit to find leak at failed radiator crimps or engine oil cooler.
