2013 E350 4matic sedan Suspension options
Thanks!
you can look at fcpeuro or pelicanparts dot com for complete kits of original parts to preserve normal chassis handling.
Don't overlook both sway bar springs!
Their soft bushings cause them to become bouncy and ruin shocks in the process.
The links are much easier to get to and replace and are really cheap. They're almost certainly shot though. A great, quick performance upgrade. I just did my fronts.
The sway bars on some of these cars are a right ***** to change though. The front sway bar on the sport 4matic W211s for example...
By the way, I still have a set of front and rear swaybars for a W211 4matic sport if anyone needs them (never got around to swapping them out before the car was totaled)....
Our F/R sway bars are made special with bushings 1/8" thick vulcanized directly on the bar.
Typically the $200 spring bars are supposed to be replaced when bushings become useless.
However there are excellent Chinese bushings available at wholesale prices on AliExpress based on diameter.
Can these bushings adapt well???
WHEN IT COMES TO UPRATED SUSPENSION BUSHINGS - AT K-MAC we have the experience of manufacturing longer then anyone else - Since 1964 !
WITH PROUDLY IN-HOUSE MANUFACTURE - not sourcing CCP imports (in fact bushings for virtually every model Mercedes Benz 1968 to 2024).
The 4 front “highest wearing” bushings we have also included BOTH “CAMBER AND CASTER” ADJUSTMENT AS WELL.
SPECIALLY DESIGNED SO “BOLT-ON” - NO SPECIAL TOOLS OR NEED FOR CONTROL ARM REMOVAL.
BECAUSE OEM THERE IS NOW ONLY BASIC TOE (DIRECTIONAL) ADJUSTMENT.
Brought about through cost cutting and ever increasing speeds of new car assembly lines. Stopping to adjust is no longer an option. Now Front Camber and Caster along with rear Camber is set to suit showroom height conditions.
NO LONGER ABLE TO ADJUST TIRE CONTACT ANGLES SPREAD LOAD MORE EVENLY.
PUTTING ONUS BACK ON OWNERS TO FUND COSTLY PREMATURE TIRE REPLACEMENT. With passengers side excess edge wear through high cambered roads or edge wear both sides through altered height - extra passenger loads or lowering. Fitting wide profile tires or curb knock damage.
SAME WITH REAR SUSPENSION.
Uprating of the two main rear suspension bushings and also same time providing rear Camber adjustment. Kit also uprates the two Toe bushings (and doubles the existing adjustment range).
THIS REAR KIT CAMBER BUSHES CAN BE REPLACED ALSO WITHOUT SPECIAL TOOLS OR NEED TO REMOVE CONTROL ARMS.
REMAINING REAR BUSHES ARE FITTED TO THE 6 MULTI LINK ARMS. Replacing, uprating these bushes significantly reduces rear end flex. Allowing “tauter response and traction”. Especially when applying power to lane change / overtake.
SEE SPOILER
AUDI to VOLVO - Experience Resolving OEM Suspension Shortcomings (and costs) Since 1964 !
https://www.kwsuspensions.com/produc...-35225069.html
In production now 31 years (1993) - 1,000’s adjuster kits sold. Allowing adjustment to change tire contact angles - spread load more evenly.
Squeak - only if time of alignment the 2 bolts not fully tightened. Stressed, highlighted (see sample instructions - Spoiler showing W212 4MATIC Front and W124 Rear sheets).
It’s basic - allowing the hardened teeth inner bushings and the external hardened teeth washers to fully clamp - Otherwise noticeable noise (movement from brake and acceleration). If ignored yes destruction of clamp teeth, bush failure !
